Topic: EAC extract to BOTH .flac & .alac (Read 2155 times) previous topic - next topic
Is there a way for EAC to extract & convert audio to both formats at the same time?
Some clever batch wrapper that can be used in the external compressor field?
sebus
Re: EAC extract to BOTH .flac & .alac
Maybe you could add a batch inbetween the compressor and EAC an use it to link via %1 %2 etc.
If it is an option you could use foobar2000 to duplicate the folder to flac or alac after it has been made.
REACT http://wiki.hydrogenaud.io/index.php?title=REACT may will help you. The downside of it it works only with older EAC versions. I'm still using REACT and EAC 0.99pb5 since years and it "works for me".
.halverhahn
That is what I am hoping that somebody might have done. My needs are really not extensive. REACT as it is (with downgrade required) is just too much hustle
In fact it is easier to just use MediaHuman Audio Converter as recommended in this thread
It uses ffmpeg for alac creation, any better/worse than qaac?
sebus
Or use TAC for conversion using qaac
EDIT
Seems that it still uses ffmpeg for alac!
