Topic: Different results from EAC, PerfectTunes, dbpoweramp and CueTools (Read 1382 times) previous topic - next topic
This is the result I get in EAC:
TOC of the extracted CD
     Track |   Start  |  Length  | Start sector | End sector
        1  |  0:00.32 | 13:16.00 |        32    |    59731
        2  | 13:16.32 |  8:38.00 |     59732    |    98581
        3  | 21:54.32 |  9:44.00 |     98582    |   142381
        4  | 31:38.32 |  8:08.00 |    142382    |   178981
        5  | 39:46.32 | 10:05.00 |    178982    |   224356
        6  | 49:51.32 |  4:00.00 |    224357    |   242356
        7  | 53:51.32 |  9:57.00 |    242357    |   287131
        8  | 63:48.32 |  9:42.00 |    287132    |   330781
Track  1
     Peak level 99.0 %
     Extraction speed 5.0 X
     Track quality 100.0 %
     Copy CRC 3D009306
     Cannot be verified as accurate (confidence 11)  [19B05A64], AccurateRip returned [AB39BC9F]  (AR v2)
     Copy OK
Track  2
     Pre-gap length  0:00:03.00
     Peak level 79.1 %
     Extraction speed 6.0 X
     Copy CRC 26815147
     Accurately ripped (confidence 2)  [CB0735BF]  (AR v2)
     Copy OK
Track  3
     Peak level 90.9 %
     Extraction speed 6.7 X
     Track quality 99.9 %
     Copy CRC 1068460A
     Accurately ripped (confidence 2)  [CECCBF40]  (AR v2)
     Copy OK
Track  4
     Pre-gap length  0:00:04.00
     Peak level 96.0 %
     Extraction speed 7.2 X
     Copy CRC 655FC041
     Accurately ripped (confidence 2)  [2481B885]  (AR v2)
     Copy OK
Track  5
     Pre-gap length  0:00:06.00
     Peak level 95.4 %
     Extraction speed 8.1 X
     Copy CRC 28022405
     Accurately ripped (confidence 2)  [66E2CD79]  (AR v2)
     Copy OK
Track  6
     Pre-gap length  0:00:05.00
     Peak level 79.7 %
     Extraction speed 8.2 X
     Copy CRC 82B4FBAE
     Accurately ripped (confidence 2)  [7FCC6E99]  (AR v2)
     Copy OK
Track  7
     Peak level 45.3 %
     Extraction speed 8.7 X
     Copy CRC 1D2A02F8
     Accurately ripped (confidence 2)  [200E5EF7]  (AR v2)
     Copy OK
Track  8
     Peak level 92.4 %
     Extraction speed 9.1 X
     Copy CRC 1742A4AE
     Accurately ripped (confidence 2)  [ABB529BC]  (AR v2)
     Copy OK
 7 track(s) accurately ripped
 1 track(s) could not be verified as accurate
Some tracks could not be verified as accurate
No errors occurred
End of status report
---- CUETools DB Plugin V2.1.6
[CTDB TOCID: YzSj1DfQdzeu12zGvS7TgnEhROA-] found
Submit result: YzSj1DfQdzeu12zGvS7TgnEhROA- has been confirmed
Track | CTDB Status
  1   | (28/29) Accurately ripped
  2   | (29/29) Accurately ripped
  3   | (28/29) Accurately ripped
  4   | (29/29) Accurately ripped
  5   | (28/29) Accurately ripped
  6   | (28/29) Accurately ripped
  7   | (28/29) Accurately ripped
  8   | (28/29) Accurately ripped
This is the result from PerfectTunes:
  Track 1: AccurateRip Verified Confidence 11, Pressing Offset +658 [ARv2 CRC 4A4AD29A]
  Track 2: AccurateRip Verified Confidence 11, Pressing Offset +658 [ARv2 CRC 32EBAFE6]
  Track 3: AccurateRip Verified Confidence 11, Pressing Offset +658 [ARv2 CRC 39DE470F]
  Track 4: AccurateRip Verified Confidence 11, Pressing Offset +658 [ARv2 CRC 5C79E574]
  Track 5: AccurateRip Verified Confidence 11, Pressing Offset +658 [ARv2 CRC 038D96D1]
  Track 6: AccurateRip Verified Confidence 11, Pressing Offset +658 [ARv2 CRC 04583FAF]
  Track 7: AccurateRip Verified Confidence 11, Pressing Offset +658 [ARv2 CRC 2FD5CECE]
  Track 8: AccurateRip Verified Confidence 10, Pressing Offset +658 [ARv2 CRC 087985F6]
Finally, dbpoweramp says the first track is ACCURATE (11) and the rest are all ACCURATE (2).
What does this mean?
Re: Different results from EAC, PerfectTunes, dbpoweramp and CueTools
It means the confidence 2 result for track 1 is likely 2 people with different results, so it is not in the database. EAC does not do pressing offsets so it not able to verify track 1, whereas dBpoweramp can against the different pressing.
The CUETools DB Plugin shows results from the CUETools DataBase (not the same as AccurateRip).
korth
But I have a confidence 11 result for track 1, across EAC, dbpoweramp and PerfectTunes.
I realise that. What of PerfectTunes and dbpoweramp though?
PerfectTunes, dbpoweramp and CueTools all state that ALL tracks are accurate. Why does EAC disagree?
See spoon's post. Track 1 is probably not in the database for your pressing. EAC cannot check against a different pressing so track 1 cannot be verified as accurate. EAC shows you that the first record found (and does not match your pressing) contains 11 entries.
PerfectTunes and dbpoweramp show the rip as accurate by checking against a different pressing.
The CUETools DataBase shows the rip as accurate. It stores all pressings of the same CD together.
edit: added link
korth
Think I'm starting to understand!
So is the rip accurate or not?
Three programs say that it is accurate.
When EAC says "Cannot be verified as accurate" that doesn't necessarily mean the rip is not accurate.
korth
