Thanks for the quick reply. When I searched for the settings.txt file in %appdata%, I was looking for the string, "cuetools" (DOH ) As you say, %appdata%\CUE Tools\ is the folder location. [Search Term: Where is the CUETools configuration file located]
RESOLVED
00. Note: Prior to resolving this issue, I switched to Foobar2000 and was able to generate tracks from my FLAC image file + Cue Sheet.
0. Rename the "settings.txt" file that was used when the errors were generated > "settings_ERROR.txt".
1. Close CUETools program (if it's running).
2. Rename "settings.txt"
3. Launch the CUETools program. This will generate a clean default "settings.txt" file.
Currently, Errors are NOT being generated when output is on EITHER my shared network drive OR the C: drive.
UNABLE TO REPRODUCE
I am currently unable to reproduce the conditions that caused the Exception Errors. I tried to reproduce the previous error by replacing the "settings.txt" file with the one that was present when the error message was generated earlier (make a copy and rename "settings_ERROR - copy.txt" > "settings.txt", etc.) However, the CUETools output is currently being generated without error.
NOTE
In the same folder as "settings.txt", there is a file called, "LocalDB.xml.z". Not sure if this has anything to do with why the error was generated. (Neither 7-Zip nor RAR seem to be able to open this file on my Windows 7 system.)
1. SETTINGS.TXT
(File that was used yesterday, when Errors were generated)
LastMOTD=5247667131402137698
ChoiceWidth=1067
ChoiceHeight=602
ChoiceMaxed=0
InputPath=R:\AUDIO BOOKS\Homers Iliad\CD 2.cue
DefaultLosslessFormat=flac
DefaultLossyFormat=mp3
DefaultNoAudioFormat=flac
DontGenerate=1
OutputPathUseTemplates=0
UsePregapForFirstTrackInSingleFile=0
ReducePriority=1
FileBrowserState=0
ReportState=1
CorrectorLookup=0
CorrectorOverwrite=1
CorrectorFormat=flac
WidthIncrement=246
HeightIncrement=0
Top=14
Left=1635
Profiles=verify convert fix
Version=204
ArFixWhenConfidence=2
ArFixWhenPercent=51
ArEncodeWhenConfidence=2
ArEncodeWhenPercent=100
ArEncodeWhenZeroOffset=0
ArNoUnverifiedOutput=0
ArFixOffset=0
ArWriteCRC=0
ArWriteLog=1
ArWriteTagsOnVerify=0
ArWriteLogOnVerify=0
PreserveHTOA=1
DetectGaps=1
AutoCorrectFilenames=1
KeepOriginalFilenames=0
SingleFilenameFormat=%filename%
TrackFilenameFormat=%title%
RemoveSpecialCharacters=0
SpecialCharactersExceptions=-()
ReplaceSpaces=0
EmbedLog=1
ExtractLog=1
FillUpCUE=1
OverwriteCUEData=0
FilenamesANSISafe=1
CreateEACLOG=1
DetectHDCD=1
Wait750FramesForHDCD=1
DecodeHDCD=0
CreateM3U=0
CreateCUEFileWhenEmbedded=1
Truncate4608ExtraSamples=1
DecodeHDCDToLossyWAV16=0
DecodeHDCDTo24bit=1
OneInstance=0
CheckForUpdates=1
Language=en-US
SeparateDecodingThread=1
WriteBasicTagsFromCUEData=1
CopyBasicTags=1
CopyUnknownTags=1
CopyAlbumArt=1
EmbedAlbumArt=1
ExtractAlbumArt=1
MaxAlbumArtSize=300
ArLogToSourceFolder=0
ArLogVerbose=1
FixOffsetToNearest=1
ArLogFilenameFormat=%filename%.accurip
Advanced=<CUEConfigAdvanced>
= <CoverArtFiles>
= <string>folder.jpg</string>
= <string>cover.jpg</string>
= <string>albumart.jpg</string>
= <string>thumbnail.jpg</string>
= <string>albumartlarge.jpg</string>
= <string>front.jpg</string>
= <string>%album%.jpg</string>
= </CoverArtFiles>
=</CUEConfigAdvanced>
ExternalEncoder0Name=cuetools
ExternalEncoder0Extension=wav
ExternalEncoder0Lossless=1
ExternalEncoder0Settings=<WAVWriterSettings />
ExternalEncoder1Name=MAC_SDK
ExternalEncoder1Extension=ape
ExternalEncoder1Lossless=1
ExternalEncoder1Settings=<APEWriterSettings>
= <EncoderMode>high</EncoderMode>
=</APEWriterSettings>
ExternalEncoder2Name=libFLAC
ExternalEncoder2Extension=flac
ExternalEncoder2Lossless=1
ExternalEncoder2Settings=<FLACWriterSettings>
= <EncoderMode>5</EncoderMode>
=</FLACWriterSettings>
ExternalEncoder3Name=VBR (libmp3lame)
ExternalEncoder3Extension=mp3
ExternalEncoder3Lossless=0
ExternalEncoder3Settings=<LameWriterVBRSettings>
= <EncoderMode>V2</EncoderMode>
=</LameWriterVBRSettings>
ExternalEncoder4Name=CBR (libmp3lame)
ExternalEncoder4Extension=mp3
ExternalEncoder4Lossless=0
ExternalEncoder4Settings=<LameWriterCBRSettings>
= <EncoderMode>256</EncoderMode>
=</LameWriterCBRSettings>
ExternalEncoder5Name=ttalib
ExternalEncoder5Extension=tta
ExternalEncoder5Lossless=1
ExternalEncoder5Settings=<TTAWriterSettings />
ExternalEncoder6Name=libwavpack
ExternalEncoder6Extension=wv
ExternalEncoder6Lossless=1
ExternalEncoder6Settings=<WavPackWriterSettings>
= <EncoderMode>normal</EncoderMode>
=</WavPackWriterSettings>
ExternalEncoder7Name=cuetools
ExternalEncoder7Extension=m4a
ExternalEncoder7Lossless=1
ExternalEncoder7Settings=<ALACWriterSettings>
= <EncoderMode>3</EncoderMode>
=</ALACWriterSettings>
ExternalEncoder8Name=FLACCL
ExternalEncoder8Extension=flac
ExternalEncoder8Lossless=1
ExternalEncoder8Settings=<FLACCLWriterSettings>
= <EncoderMode>8</EncoderMode>
=</FLACCLWriterSettings>
ExternalEncoder9Name=cuetools
ExternalEncoder9Extension=flac
ExternalEncoder9Lossless=1
ExternalEncoder9Settings=<FlakeWriterSettings>
=</FlakeWriterSettings>
ExternalEncoder10Name=wma lossless
ExternalEncoder10Extension=wma
ExternalEncoder10Lossless=1
ExternalEncoder10Settings=<WMALWriterSettings />
ExternalEncoder11Name=wma lossy
ExternalEncoder11Extension=wma
ExternalEncoder11Lossless=0
ExternalEncoder11Settings=<WMALossyWriterSettings>
= <EncoderMode>98,_96_kHz,_5.1_channel_24</EncoderMode>
=</WMALossyWriterSettings>
ExternalEncoder12Name=flake
ExternalEncoder12Extension=flac
ExternalEncoder12Lossless=1
ExternalEncoder12Settings=<UserDefinedEncoderSettings>
= <Path>flake.exe</Path>
= <Parameters>-%M - -o %O -p %P</Parameters>
= <SupportedModes>0 1 2 3 4 5 6 7 8 9 10 11 12</SupportedModes>
=</UserDefinedEncoderSettings>
ExternalEncoder13Name=takc
ExternalEncoder13Extension=tak
ExternalEncoder13Lossless=1
ExternalEncoder13Settings=<UserDefinedEncoderSettings>
= <EncoderMode>2</EncoderMode>
= <Path>takc.exe</Path>
= <Parameters>-e -p%M -overwrite - %O</Parameters>
= <SupportedModes>0 1 2 2e 2m 3 3e 3m 4 4e 4m</SupportedModes>
ExternalEncoder14Name=ffmpeg alac
ExternalEncoder14Extension=m4a
ExternalEncoder14Lossless=1
ExternalEncoder14Settings=<UserDefinedEncoderSettings>
= <Path>ffmpeg.exe</Path>
= <Parameters>-i - -f ipod -acodec alac -y %O</Parameters>
= <SupportedModes />
ExternalEncoder15Name=VBR (lame.exe)
ExternalEncoder15Extension=mp3
ExternalEncoder15Lossless=0
ExternalEncoder15Settings=<UserDefinedEncoderSettings>
= <Path>lame.exe</Path>
= <Parameters>--vbr-new -%M - %O</Parameters>
= <SupportedModes>V9 V8 V7 V6 V5 V4 V3 V2 V1 V0</SupportedModes>
ExternalEncoder16Name=CBR (lame.exe)
ExternalEncoder16Extension=mp3
ExternalEncoder16Lossless=0
ExternalEncoder16Settings=<UserDefinedEncoderSettings>
= <Parameters>-m s -q 0 -b %M --noreplaygain - %O</Parameters>
= <SupportedModes>96 128 192 256 320</SupportedModes>
ExternalEncoder17Name=oggenc
ExternalEncoder17Extension=ogg
ExternalEncoder17Lossless=0
ExternalEncoder17Settings=<UserDefinedEncoderSettings>
= <Path>oggenc.exe</Path>
= <Parameters>-q %M - -o %O</Parameters>
= <SupportedModes>-1 -0.5 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 6 6.5 7 7.5 8</SupportedModes>
ExternalEncoder18Name=nero aac
ExternalEncoder18Extension=m4a
ExternalEncoder18Lossless=0
ExternalEncoder18Settings=<UserDefinedEncoderSettings>
= <EncoderMode>0.4</EncoderMode>
= <Path>neroAacEnc.exe</Path>
= <Parameters>-q %M -if - -of %O</Parameters>
= <SupportedModes>0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9</SupportedModes>
ExternalEncoder19Name=qaac tvbr
ExternalEncoder19Extension=m4a
ExternalEncoder19Lossless=0
ExternalEncoder19Settings=<UserDefinedEncoderSettings>
= <EncoderMode>80</EncoderMode>
= <Path>qaac.exe</Path>
= <Parameters>-s -V %M -q 2 - -o %O</Parameters>
= <SupportedModes>10 20 30 40 50 60 70 80 90 100 110 127</SupportedModes>
ExternalEncoders=20
ExternalDecoder0Name=takc
ExternalDecoder0Extension=tak
ExternalDecoder0Path=takc.exe
ExternalDecoder0Parameters=-d %I -
ExternalDecoder1Name=ffmpeg alac
ExternalDecoder1Extension=m4a
ExternalDecoder1Path=ffmpeg.exe
ExternalDecoder1Parameters=-v 0 -i %I -f wav -
ExternalDecoders=2
CustomFormat0Name=flac
CustomFormat0EncoderLossless=cuetools
CustomFormat0EncoderLossy=
CustomFormat0Decoder=cuetools
CustomFormat0Tagger=0
CustomFormat0AllowLossless=1
CustomFormat0AllowLossy=0
CustomFormat0AllowEmbed=1
CustomFormat1Name=wv
CustomFormat1EncoderLossless=libwavpack
CustomFormat1EncoderLossy=
CustomFormat1Decoder=libwavpack
CustomFormat1Tagger=0
CustomFormat1AllowLossless=1
CustomFormat1AllowLossy=0
CustomFormat1AllowEmbed=1
CustomFormat2Name=ape
CustomFormat2EncoderLossless=MAC_SDK
CustomFormat2EncoderLossy=
CustomFormat2Decoder=MAC_SDK
CustomFormat2Tagger=0
CustomFormat2AllowLossless=1
CustomFormat2AllowLossy=0
CustomFormat2AllowEmbed=1
CustomFormat3Name=tta
CustomFormat3EncoderLossless=ttalib
CustomFormat3EncoderLossy=
CustomFormat3Decoder=ttalib
CustomFormat3Tagger=1
CustomFormat3AllowLossless=1
CustomFormat3AllowLossy=0
CustomFormat3AllowEmbed=0
CustomFormat4Name=wav
CustomFormat4EncoderLossless=cuetools
CustomFormat4EncoderLossy=
CustomFormat4Decoder=cuetools
CustomFormat4Tagger=0
CustomFormat4AllowLossless=1
CustomFormat4AllowLossy=0
CustomFormat4AllowEmbed=0
CustomFormat5Name=m4a
CustomFormat5EncoderLossless=cuetools
CustomFormat5EncoderLossy=nero aac
CustomFormat5Decoder=cuetools
CustomFormat5Tagger=0
CustomFormat5AllowLossless=1
CustomFormat5AllowLossy=1
CustomFormat5AllowEmbed=0
CustomFormat6Name=tak
CustomFormat6EncoderLossless=takc
CustomFormat6EncoderLossy=
CustomFormat6Decoder=takc
CustomFormat6Tagger=1
CustomFormat6AllowLossless=1
CustomFormat6AllowLossy=0
CustomFormat6AllowEmbed=1
CustomFormat7Name=wma
CustomFormat7EncoderLossless=wma lossless
CustomFormat7EncoderLossy=wma lossy
CustomFormat7Decoder=windows
CustomFormat7Tagger=0
CustomFormat7AllowLossless=1
CustomFormat7AllowLossy=1
CustomFormat7AllowEmbed=0
CustomFormat8Name=mp3
CustomFormat8EncoderLossless=
CustomFormat8EncoderLossy=VBR (libmp3lame)
CustomFormat8Decoder=
CustomFormat8Tagger=0
CustomFormat8AllowLossless=0
CustomFormat8AllowLossy=1
CustomFormat8AllowEmbed=0
CustomFormat9Name=ogg
CustomFormat9EncoderLossless=
CustomFormat9EncoderLossy=oggenc
CustomFormat9Decoder=
CustomFormat9Tagger=0
CustomFormat9AllowLossless=0
CustomFormat9AllowLossy=1
CustomFormat9AllowEmbed=0
CustomFormats=10
CustomScript0Name=default
CustomScript0Condition0=1
CustomScript0Condition1=0
CustomScript0Conditions=2
CustomScript1Name=only if found
CustomScript1Condition0=1
CustomScript1Conditions=1
CustomScript2Name=fix offset
CustomScript2Condition0=0
CustomScript2Conditions=1
CustomScript3Name=encode if verified
CustomScript3Condition0=0
CustomScript3Conditions=1
CustomScript4Name=repair
CustomScript4Condition0=0
CustomScript4Conditions=1
CustomScripts=5
DefaultVerifyScript=default
DefaultVerifyAndConvertScript=default
GapsHandling=3
MusicBrainzLookup=1
CTDBVerifyOnEncode=1
AccurateRipLookup=1
LocalDBLookup=1
SkipRecent=0
CUEToolsDBLookup=1
OutputAudioType=0
OutputAudioFmt=flac
AccurateRipMode=0
CUEStyle=3
WriteOffset=0
OutputPathTemplate=C:\Temp\CUETools Output
Script=default
2: SETTINGS.TXT
(Currently being used, today. This shows only the DIFF's due to HA.io forum posting limits on max. number of characters)
LastMOTD=5247667611249499334
~snip~
DefaultNoAudioFormat=wav
DontGenerate=0
~snip~
WidthIncrement=0
~snip~
Top=6
Left=1979
~snip~
OneInstance=1
~snip~
~snip~
~snip~
CUEStyle=1
