Topic: SqrSoft Compressor/Limiter (Read 2334 times) previous topic - next topic
Hello ...
1st post to this forum.
I've downloaded and installed the SqrSoft Compressor/Limiter (foo_dsp_sqrcomp.fb2k-component). I'd like to add it into a tab in one of the panels on foobar2000. However, the Compressor/Limiter does not show up as a select-able UI Element.
Would some one please explain (or point me to) what I'm missing in the installation process of the Compressor/Limiter?
Thank you!
Re: SqrSoft Compressor/Limiter
marc2k3 ...
Thank you for the feedback; very much appreciated!
It's quite unusual for DSP components to have a UI element. You'll probably need to configure it under File>Preferences>Playback>DSP manager.
hello, i have the same issue, but when i go to  File>Preferences>Playback>DSP manager
i just can activate or not the plugin.
Normally, i should have a plce where i can't tune DB limits as another limiter ?
After you add the DSP to the "Active" list, if its options are adjustable a "..." box should appear on the right side next to the "x" box.  Click the "..." box to bring up the options.
Thx !
Can we have this component updated to use with Foobar2000 2.1 x64?
• Join our efforts to make Helix MP3 encoder great again
• Opus complexity & qAAC dependence on Apple is an aberration from Vorbis & Musepack breakthroughs
• Let's pray that D. Bryant improve WavPack hybrid, C. Helmrich update FSLAC, M. van Beurden teach FLAC to handle non-audio data
