Topic: [Not My Release] EsPlaylist (Read 336925 times) previous topic - next topic
Reply #250
ssenna, thanks for fixing the sorting.
Reply #251
There is some request.
1. Split title TF config to Layered view and Flat view.
I think Layered view title width is narrow.
For example:
-%album%
Layered view-> the movie OST
Flat view-> the movie Original Sound Track
2. inline editing on Flat view.
3. Layered View only mode.(like Graphical Browser, and track menu popup assign to middle click.)
Thank you.
Reply #252
The search bar is awesome, it looks like the search from Winamp  . Thank you a lot.
It'll be more awesome if i can change the search bar position , place it at the end of playlist look ugly for me
Reply #253
Layered view margin adjustment is nice.
However, I think that the rightmost margin is needless.
|=panel edge
_=margin
a=artwork
Now:
|a_a_a_|
Better:
|a_a_a|
Reply #254
@ssenna: Could you make the cover list look like the one in iTunes? I'm not saying that foobar2000 has to look like iTunes. But I like it when you select a cover then only the album's songs are expanded. NOT the whole library, like EsPlaylist does. And if the expanded album list shows the cover, too. Also, it would be great if the user could choose not to automatically select all songs of an album. Do you think you could be going to implement this?
Reply #255
It is already possible if you check the option "Display Only Focused Group" in Grouping Settings.
However it would be great if we can select for exemple an artist, then with focused groups, see his albums covers, and then when clicking on the cover, see all the albums of the artist in the playlist view instead of all the library or only the album selected !
Reply #256
EsPlaylist v0.1.1.0 beta 6a (2010/08/08) released.
Changelog:
  • added : Search Bar.
  • changed : sorting with force-sorted=on in Browse Library mode, again.
  • Misc bug fixes (beta 6a)
  • Made Searchbar position selectable. (beta 6a)
Download EsPlaylist v0.1.1.0 beta 6a
Reply #258
that space has always been there separating the title from the side info.
Reply #259
I'm experiencing a little bug with the new %<xxx>% behavior for multiple artists.  If I send a selection to my playlist that includes both artists who share a multi-artist track, I get duplicates of that track in my playlist.  It's obvious as to why this happens, but it would be nice if there was a workaround for this behavior.
Also, although I love the new search bar, I have a few small suggestions.  For starters, the "..." button for selecting the search tag(s) seems to be the wrong type of control for this behavior.  I think it would make more sense if this button were to be replaced with a standard drop-down menu.  Not only would its behavior be more consistent with standard Windows controls, but we could easily see which search parameters are selected without clicking the "..." button to check.
Also, the ability to edit and add custom search tags would be nice.  I'd like to be able to search my %lyrics% tag, for instance.
Reply #261
@ssenna: Can we have not just side info but also "bottom info"? I for example like to display just %album% and %album artist% below the cover. For little text like that, a side info is very space consuming. If you do bottom info, then please have the album displayed in a different color (not black), like the side info currently does.
Also, it would be great if the user could choose to display a cover shadow.
And finally, maybe I already mentioned that, would be great if nothing at all is selected when you open a cover. By default, currently all songs of that album are selected. It would look more pleasant to the eye if there is no selection. And I don't think there's a need to select everything by default. Or please make it switchable via an option if some users insist on this selection behavior.
Reply #262
would it be possible to have something like %es_subgroup_length% but for album average bitrate (%es_subgroups_bitrate%) maybe?
Reply #263
Hey ssenna, thanks for your last update, now my foo is really cool ). I hope this is my last request too
Is it possible to shuffle (or album repeat) songs only in the search result ? I think it'll usefull when i want to shuffle only for artist (or songs) i searched.
Reply #264
+1
Reply #265
yeah I'd like some "bottom info" below the album art in flat view. I don't see why it shouldn't just be the side info displayed that way in flat view, though. either would work i guess
Reply #266
Just to be sure, because this problem drives me crazy and no one else has complained about this: Is it to be expected (if yes, why?) that all songs of an album that you open in EsPlaylist get selected, or is that just a bug of my personal foobar2000 setup?
And apart from that, I have a cosmetic feature suggestion:
(Left side: EsPlaylist, right side: DUI Playlist; both under Windows 7)
As you can see, the colors differ and even the heights of the title columns are different (+1 Pixel in EsPlaylist).
EsPlaylist's colors (alternating rows and blue group titles) are darker.
EsPlaylist's selection color looks different.
EsPlaylist's title columns' height is bigger.
I suggest when EsPlaylist runs under DUI, for asthetic reasons it should use the exact same title columns' sizes and the same playlist colors like DUI does with its default playlist.
Reply #267
EsPlaylist obeys the windows system colours. default UI playlist view does not. open the preferences or even windows explorer and you'll see they use the "proper" aero blue the same as EsPlaylist.
Reply #268
EsPlaylist v0.1.1.0 (2010/08/13) released.
Changelog:
  • changed/fixed : some behaivour of Searchbar.
  • changed : adjusted color of group header line(in case of custom color mode).
  • added : support auto-complete in inline tag editing .
  • added : %es_group_header%
Reply #269
Yep happens here too. I agree it would look better if they weren't selected.
As for the colours thing, one solution is to change your system colours and make foobar use them, then other programs will also match your foobar colours.
Reply #270
Thanks for the latest update!  The searchbar's new modifications are great.  I just have one small bug with it, though.  When searching for "All", the search does not take into account any custom added tags.  "All" only searches the default tags.
I think it does that on purpose.  It's quite useful if you don't have "Always Display Only Focused Group" checked.  Though when that option is checked, I can see how selecting all of the tracks could be annoying.
Reply #271
So what exactly is/is the purpose of %es_group_header%?
Also, I don't know if it's been requested yet... But a great addition would be the ability for ES Playlist to remember the level ESplaylist was at foobar's start up.
Reply #272
%es_group_header% is useful for me.
Because it is can switching TF of group text.
For example:
-Group header is available.(it is longer on Layered view)
XXX artist's special collection.
-Group header is not available.
special collection.
TF:
$if(%es_group_header%,%album%,$if2(%short album%,%album%))
You can 'Original Sound Track' -> 'OST' by this function.
$replace(
%album%,
'Original Sound Version','OSV',
'ORIGINAL SOUND VERSION','OSV',
'Original Soundtrack','OST',
'ORIGINAL SOUNDTRACK','OST',
'Original Sound Track','OST',
'ORIGINAL SOUND TRACK','OST',
'O.S.T.','OST',
@ssenna:
Why scroll to top position when playback new track?
this behavior is inexplicable.
or it occur only my environment?
Thank you!
Reply #273
Default UI playlist view uses or derives from system colors, (GetSysColor) but not theme colors. (GetThemeColor)
Also, when I switched my desktop theme to Windows Classic, the background color for the currently selected track became a dark blue that rendered the black text nearly unreadable. Oh, and all the fields of playlist items that were offscreen became "NEIN" until I switched active playlists, although I can't reproduce that now.
Reply #274
Great component.
I have one small request with the new search bar. It would be nice if the button to "clear all" was at the end of the search bar itself (i.e. like the search bar in foo_facets and iTunes).
