Topic: DRC in new built-in AC-3 decoder (Read 1304 times) previous topic - next topic
Since new built-in AC-3 decoder is using ffmpeg, it is needed to forcefully disable DRC (set -drc_scale to 0) in code or expose this option to user interface, because ffmpeg has it enabled by default - https://www.ffmpeg.org/ffmpeg-codecs.html#AC_002d3-Decoder-Options
I compared new built-in decoder vs ffmpeg with -drc_scale 0 and output level of built-in decoder is lowered because of DRC.
Sample of AC-3 with DRC data - https://www.dropbox.com/s/abewfkx8m8yfdyn/AC3-DRC.ac3?dl=1
Re: DRC in new built-in AC-3 decoder
I presume the same problem now applies to Dolby True HD, DTS, DTS96/24, DTS HD, DTS HDMA and all other variants of Dolby and DTS.
I think that the best option would be to let foobar passthrough such streams (dolby/dts) without decoding them with additional option to decode them but with possibility to change some parameters such as DRC, Dialog Normalisation....
I presume your presumption is wrong.
Problem noted, thanks for reporting.
