Topic: File Operations -Move / Rename / Copy - stricmp Vs MusicBrains Picard (Read 261 times) previous topic - next topic
Greetings!
I have a file rename operations script that works pretty much as I wish. Forgive me as I"m just recently looking at my music lib from many years ago, only now considering fixing some things which are out of order.
As I have a few different file types Incl mp3, flac, mpc, I have my lib setup like E.g. M:\my_music_lib\mp3 ; M:\my_music_lib\flac ; M:\my_music_lib\mpc ; etc.
I thought my script automatically made the filetype folders, but I could be wrong. Also, MusicBrains Picard claims to use the foobar2000 format scripting syntax. But, when I use the following in Picard, it throws an error, unknown function: $stricmp.
My script is:
$replace(%filename_ext%,%filename%,)/$if2($if($stricmp($left(%album artist%,4),The ),$substr(%album artist%,5,5)'/'$substr(%album artist%,5,244)', '$substr(%album artist%,1,4)'/',$left(%album artist%,1)'/'%album artist%'/'),$if($stricmp($left(%artist%,4),The ),$substr(%artist%,5,5)'/'$substr(%artist%,5,244)', '$substr(%artist%,1,4)'/',$left(%artist%,1)'/'%artist%'/'))$if(%album%,$if($or($stricmp(%album artist%,Various Artists),$stricmp(%album artist%,Various)),%album% '(Various Artists)'$if($isgreater($num(%disc%,2),0,'disc number true','disc number false'),'[disc '%disc%']/','/'),%album% $if($isgreater($num(%disc%,2),0,'disc number true','disc number false'),'[disc '%disc%']/','/')),'[UNKNWON ALBUM]/')$if(%artist%,%artist%,$if(%band%,%band%,'[UNKNOWN ARTIST]'))$if(%album%,' - '%album% $if($or($stricmp(%album artist%,'Various Artists'),$stricmp(%album artist%,'Various')),'(Various Artists) ',)$if($isgreater($num(%disc%,2),0,'disc number true','disc number false'),' [disc '%disc%']',),' - [UNKNOWN ALBUM]')$if(%tracknumber%,'- '$num(%tracknumber%,2),' - 00')$if(%title%,' - '%title%,' - [UNKNOWN TITLE]')
maybe overkill, but apparently worked in the past, in foobar2000 it works of course.
I guess I"m asking two things.
#1.) Is there a function that I can use so so I would have a path such as:
my_music_lib\EXTension\Alpha-char-of-artist\Artist\Album\file.extension
where, EXTension above would be either [drive:\]my_music_lib\mp3 | my_music_lib\flac | my_music_lib\mpc ?
#2.) understanding this isn't a MusicBrainz Picard forum, do you have a suggestions regardless for a compatible script/ how to do the $stricmp() there?
thank you!
EDIT: the script above actually does make the file-type subfolder. For some reason (which I suspect is a folder permissions issue, as the target drive is a "slave" to a new Win 11 system.
Probably nothing y'all can help me with. I didn't realize it was already making the folder as desired.
https://imgur.com/xotevg5 [working]
vs
https://imgur.com/HGKePww [no results]
Lastfm as PSU_Strummer. i used to play guitar on stage. that was fun. now i enjoy listening to it on foobar2000
Re: File Operations -Move / Rename / Copy - stricmp Vs MusicBrains Picard
$stricmp isn't a MusicBrainz scripting function https://picard-docs.musicbrainz.org/v2.6/en/functions/list_by_name.html
I think $rsearch could be used instead to achieve the string comparison. But I'd ask on the MusicBrainz community forum in the Picard section if you have no luck.
