Topic: Topping D90SE MQA instructions (Read 441 times) previous topic - next topic
Hello folks,
I'm having problems in setting up the application to support MQA, after having spoken to Topping following all their instructions on how to set up the application so the DAC can play as well as display on the screen that it is playing such files, I can't solve the problem.
ASIOProxyInstall-0.7.2.exe
foo_out_asio.fb2k-component
foo_input_sacd.fb2k-component
I followed a pdf guide that I will upload.
They also told me to not select the DAC as the default output device , which made no difference in my case.
Re: Topping D90SE MQA instructions
I have no clue, but try this more recent stuff... Clean install Foobar 2.0 beta 8 portable, then these 2 components:
https://sourceforge.net/projects/sacddecoder/files/foo_out_asio%2Bdsd/
https://sourceforge.net/projects/sacddecoder/files/foo_input_sacd/
Then try your audio, or these streams with metadata:
http://stream.radioparadise.com/flacm
http://stream.radioparadise.com/mellow-flacm
http://stream.radioparadise.com/rock-flacm
http://stream.radioparadise.com/world-etc-flacm
MQA is a scam anyway.
WASAPI EVENT OR PUSH + 16 BIT OUTPUT, NO DITHER.
I try the latest beta like you said and it's working there the only problem I'm facing is that some of my components are not compatible with the latest V2 version of the app.
Specifically I need the
Enhanced spectrum analyzer
Waveform seekbar
Mathaudio headphones EQ
But it doesn't import .dll files which is a bummer.
Did you try the 2 components I listed with Foobar 1.6 (SACD, ASIO)?
https://mathaudio.com
https://www.foobar2000.org/components/view/foo_wave_minibar_mod
https://www.foobar2000.org/components/view/foo_headphone_eq
There are many people on this forum updating components to work with Foobar 2.0, search and ask around.
User installed component dll's go in here? Foobar\profile\user-components
yes I tried installing the two components without success so I installed the V2 and everything is working perfectly now I absolutely love the dark theme thank you very much for your help
