Topic: Defined naming convention for digital audio files? (Read 8083 times) previous topic - next topic
Right, I'm wondering if there is a defined naming convention for digital audio files? I want to rip my entire CD collection and try and tag it as perfectly as I can with correct names etc. Is there any sort of official or generally accepted naming convention I can follow. For example should a captial A be a or Of be of etc. Should remixes etc. have square brackets or normal brackets e.g. Cafe Del Mar [Alex K Remix] or Cafe Del Mar (Alex K Remix). Should albums which are generally by the same artist but feature a couple of other artists e.g. The Way I Are by Timbaland feat. Keri Hilson have album artist as Various Artists or Timbaland feat. Keri Hilson. This example track listing should give you a better idea of what I mean:
1. The Way I Are
Artist: Timbaland feat. Keri Hilson, Sebastian & D.O.E.
2. The Way I Are (Timbaland vs. Nephew)  <------------- should this be Vs. or vs, should Nephew be in the Artist field???
Artist: Timbaland feat. Keri Hilson & D.O.E.
Album Artist: ??????
Another query I have is when you have got with is with the same as featuring?? Or are they different? Should a disc field be used if there is only one disc i.e. Disc 1 of 1??
Ok then but can other people tell me what they think is best?
I don't quite understand what you expect to be answered in this thread. There's no "best" scheme, since this matter is entirely based on personal preference. One guy prefers "Vs." over "vs.", the next one puts the disc number into the album's name (like "Cult [CD1]" and Cult [CD2]"), another one goes for the "Disc" tag instead. And whether it's the "artist" or "album artist" field, that's filled with the interpreter's name - really, that's up to you.
It wouldn't help you at all, if people began spamming this thread with their personal ideas, since the many possible choices would even be more confusing to you. Hence, decide for yourself.
Seriously, i don't even know what kind of answers you're expecting... everyone has their own way of doing it. For example, i don't use DISC tags (so i have some albums with like 90 tracks), i also use a 3 star rating system, and i remove "the" from artist names. Other people will likely have equally eccentric ways of doing it. So the solution is for you to make a system for yourself and stick to it. There's no standard way of doing things except maybe using the album artist tag to store various artists.
Yes. Have a look at MusicBrainz:
http://musicbrainz.org/
@Exodemia
Just write what's on the cover or don't tag at all if it's only complicating your life (use filenames).
I just had a look, and it seems to me that [a] it is just one more suggestion and even they do need seem in agreement.
http://musicbrainz.org/doc/VersusStyle
Edit: Also it seems the suggestions are limited by their database set-up, and not good tagging practice.
Here is the basic guidelines though: http://musicbrainz.org/style.html (or http://musicbrainz.org/doc/OfficialStyleGuideline)
I'm on a horse.
I don't disagree. But:
a) it's what the OP was looking for;
b) I'm not aware of any alternatives, certainly not on that scale;
c) the users make it what it is via democratic voting procedures;
d) Last.fm will be using their data shortly; and
d) anyone unsure really ought to try it. It saves a huge amount of manual work.
Right. MusicBrainz is confusing. Thanks for that anyway. Ok can I ask what people do in the example I gave with The Way I Are? That's the most important part to me.
How is it confusing?
You run the tagging software, you drag the files you want to tag over an icon, and it tags them! How much easier could they make it?
Just use what you think is best for you, there is no wrong or right way, it's up to the individual.  I have seen some horrible tagging from files from the internet... so I easily change it with Foobar
:Foobar 2000:
:MPC --standard:
:iRiver H320 Rockboxed:
Agreed.  I was not knocking the suggestion - merely pointing out that it is not a de facto standard, and is still confused.
The link I provided to MusicBrainz gives a pretty comprehensive answer...
I would go with the MusicBrainz' suggestion of "vs." for any "versus" tracks, and "feat." for "featuring".
I would either use:
ALBUM ARTIST=
ARTIST=Justin Timberlake
TITLE=The Way I Are (Timbaland vs. Nephew)
ALBUM ARTIST=
  TITLE=The Way I Are (feat. Keri Hilson, Sebastian & D.O.E.)
... or, if the tagging format will allow it, perhaps:
ALBUM ARTIST=
  ARTIST=Nephew
  TITLE=The Way I Are
ALBUM ARTIST=
    ARTIST=Keri Hilson
    ARTIST=Sebastian
    ARTIST=D.O.E.
    TITLE=The Way I Are
The first is probably good enough though.  IMHO.
Edit: Oh, and I wouldn't use a DISC/DISCNUMBER field if there is only one disc, but you can.  Either use DISC=1/2 or DISCNUMBER=1 and TOTALDISCS=2.  I notice that foobar is using DISC=N/M now.
I'm on a horse.
Sure, no problem. And if anyone out there can suggest anything else out there that's approaching becoming a standard, I'd be interested in getting involved.
I once have been fancied by the naming convention used by the uber freaks... Although their encoding standard have been defunct, I believe that their defined naming convention would still be very helpful for someone like the OP in this case.
"Listen to me...
Never take unsolicited advice..."
