Topic: [fb2k v2] Playcount 2003 (Read 4817 times) previous topic - next topic
Re: [fb2k v2] Playcount 2003
I'm calling this 0.1 final.
https://jscript-panel.github.io/other/playcount2003/
- Remove `foo_playcount` importer from main `Library` menu.
- The `Edit` dialog for context menu selections now has built in `Presets`.
- Implement drop down history on the `Edit` dialog text boxes. Only title format patterns are remembered. Other plain text entry is not.
- Add support for importing `JSON` files with `UTF8-BOM`.
General incompetence strikes again. 0.1.1 fixes a bug where the context menu items for marking selections as loved/unloved didn't work. This happened during the edit dialog rewrite and I wasn't paying enough attention. :/
0.1.2 is just very minor file import tweaks for people modifying their own values which I doubt many are.
New download location: https://github.com/marc2k3/foo_playcount_2003/releases
New readme page: https://marc2k3.github.io/foo_playcount_2003/
Hi there again Marc, regarding the %2003_last_played_ago% is there any plan to introduce month(m) and year(y) value instead of overly used week(wk)? just like in $jsp3_since.
Also another title formatting help question, with the last update the code "$substr(%2003_added_ago%,0,$strstr(%2003_added_ago%,d))" will return empty since there is no days(d) in string, since it will return just HH:MM:SS, is it possible to just make it return as "Today" string? Thanks.
Btw, there is small typo in the docs %2003_last_played_ago%`
Regarding the import feature, thanks for adding the presets for foo_lastfm_playcount_sync. However, it seems it had to be done manually. Can it be done in batch just like the previously import from foo_playcount in Library menu? Also a console log for the process would be nice.
Thank you.
For display in JSP3, you can use $jsp3_since with these fields. Instead of using %2003_last_played_ago%, use
$replace($jsp3_since(%2003_last_played%),0d,Today)
I'll look at providing more feedback on edits.
0.1.3 now reports how edits were handled in the Console. Also, the file importer stats are more accurate now.
Docs:
Download:
Reply #32
Thanks for the update.
Regarding the last_played title formatting, I think i got it, here's my noob attempt.
$puts(lp,%2003_last_played_ago%)$puts(week,$replace($substr($get(lp),0,$strstr($get(lp), )),wk,))
$if($get(lp),$ifgreater($get(week),52,$div($get(week),52) years ago,$iflonger($get(lp),8,$substr($get(lp),0,$strstr($get(lp),d)),Today)),)
Reply #34
So 0.1.4 adds these new fields...
%2003_added_ago2%
%2003_first_played_ago2%
%2003_last_played_ago2%
Demo:
Full code:
$font(Cascadia Mono,24,700)
Added: %2003_added%
$crlf()
Added ago: %2003_added_ago%
$crlf()
Added ago2: %2003_added_ago2%
$crlf()
$crlf()
First: %2003_first_played%
$crlf()
First ago: %2003_first_played_ago%
$crlf()
First ago2: %2003_first_played_ago2%
$crlf()
$crlf()
Last: %2003_last_played%
$crlf()
Last ago: %2003_last_played_ago%
$crlf()
Last ago2: %2003_last_played_ago2%
$crlf()
$crlf()
Plays: %2003_playcount%
$crlf()
Loved: %2003_loved%
$crlf()
Rating: %2003_rating%
That font function is only supported in JSP3 Text Display. It can be removed for displaying in ye olde foo_textdisplay / CUI item details.
Reply #35
Thank you very much for the update, it looks wonderful!
Reply #38
0.1.6
Update Edit dialog with Rating field. Although setting the Rating via the context menu was always possible, it wasn't possible to import ratings from foo_playcount. This change allows that.
Docs:
Download:
Reply #39
0.1.7
This works around a horrible bug that prevented library viewers from updating themselves on startup. Apologies to anyone affected.
Docs:
Download:
Reply #40
That was quick! Thank you. Everything is working properly with the Album List Panel again.
Think millionaire, but with cannons.
Reply #41
0.18
The Edit dialog now supports dates in YYYY-MM-DD format. The time will be set to 00:00:00 automatically. Probably more useful for editing the added time and not first played/last played. :P
Docs:
Download:
Reply #42
It's mentioned that immediate data loss will occur both in the readme and here. Can you expand a bit on that? I'm not installing anything that has the potential to wipe out all my playback statistics; it's bad enough when fb2k crashes and takes the current session's with it.
Does this continue to update both the built-in stats and its own? (As far as I can tell, it has its own database too.) How does it work with regular existing tag names? Is it possible to make changes less ruinous by attempting to map old entries to the new pattern?
Reply #43
The readme says it all really..
It's important that settings are decided on before starting as any change causes immediate data loss. foobar2000 will prompt you to restart when changing any setting.
Title format pattern
This is how database records are bound to your tracks. The default of %path%|%subsong% does mean every track will have unique data.
Note
As of 0.1-Beta.6, statistics can survive files being moved or copied when using file operations. Cuesheets/other tracks with multiple chapters are not supported. If that is not acceptable, you should change it to a pattern that makes use of tags instead. You might consider a pattern like
%album artist%|%album%|%date%|%discnumber%|%tracknumber%|%title%
When you pick a pattern, you need to stick with it. That is all.
And data loss occurs when you change from the default simple mode to advanced mode. Pretty much no one needs advanced mode. This logs the date/time of each individual play and the only way you can make use of this info is by extracting it with scripting components like JScript Panel/Spider Monkey Panel. This is going to be beyond most people so most should ignore it and stick with simple mode.
And it obviously only manages its own data. It can't modify the data of anything else. Data can be imported from foo_playcount via the Edit dialog.
Other than a description here...
https://wiki.hydrogenaud.io/index.php?title=Foobar2000:Components/Playback_Statistics_v3.x_(foo_playcount)
Playback statistics are now pinned to a combination of artist + album + disc number + track number + track title information, contrary to pre-3.0 versions which would pin data to file paths.
...no one knows the exact pattern foo_playcount used internally but the example I posted as an alternative to using the path/subsong should be close enough.
Reply #44
This logs the date/time of each individual play and the only way you can make use of this info is by extracting it with scripting components like JScript Panel/Spider Monkey Panel. This is going to be beyond most people...
To add more details about this, in fact anyone could make use of it if timestamps were also provided as dates (since the tag is a string and can be used via TF). Or if TF support was extended with a date<->Unix timestamp function (but that's a foobar2000 native thing).
Then:
"$strstr(%2003_timestamps_date%,YYYY-MM-DD)" GREATER 0
It could also be tweaked to find tracks played on an specific year, month, etc.
I suppose exposing it as a multivalue tag would also work.
2003_timestamps_date HAS YYYY-MM-DD
Note the first example works fine on the original enhanced playcount:
Spoiler (click to show/hide)
So JSP/SMP is not an strict requisite to use it (if dates are exposed too).
Reply #45
Nope, this is technically impossible. It's a single string per field per track.
They are not. Converting potentially dozens/hundreds of timestamps->strings on the fly per track does not sit right with me. If foo_enhanced_playcount does it without slowing down, great. But I'm not going anywhere near that functionality.
Reply #46
No idea how it's done, works perfectly fine on real time and pretty fast. For 90K tracks:
[15:57:43] Search took 0:00.279563
[15:57:43] Search sorting took 0:00.022913
But it's fine if you are not interested, was just adding my experience because it has an utility on queries.
