Topic: FLAC 1.0.3 Released (Read 11794 times) previous topic - next topic
FLAC 1.0.3 Released
Yes, it's finally here.  See the homepage for details, but here's a summary:
- 10-15% decoder speedup
- 24-bit input support restored
- more robust plugins
- new metadata block for Vorbis-style tags
- vastly improved metadata editor
- fixed bug with pipes and Windows
- new libFLAC++, a C++ object wrapper around libFLAC
- new metadata editing interface in libFLAC and libFLAC++
- and more...
http://flac.sourceforge.net/
http://flac.sourceforge.net/news.html#20020703
The new metadata interface and/or metaflac should be especially useful to frontends as they make tagging with Vorbis tags very simple.
Josh
FLAC 1.0.3 Released
Does it work on non-x86 systems now?
GCP
FLAC 1.0.3 Released
Very cool... I've been waiting for this some time now...  All that is missing now is a powerful tag support that can rename files on extraction in whatever way you want using the tag data...
FLAC 1.0.3 Released
Woo!
Congrats Josh!
/me wanders off to play with the new release...
FLAC 1.0.3 Released
GCP
Not sure what you mean... FLAC has had solaris-sparc binary releases from the beginning and darwin-ppc since 1.0.1.  It should build almost anywhere you'd expect it to.  Somebody mentioned a problem on 64-bit Alpha's but someone else said it worked fine.  Hell, it even runs on an ARM 10 in the PhatBox.
There's EasyTAG or Tag; hopefully they'll add support for Vorbis tags in FLAC.
Josh
FLAC 1.0.3 Released
Both Frank Klemm and Monty were complaining they couldn't get FLAC 1.0.2 to decode files on non-x86 systems.
GCP
FLAC 1.0.3 Released
Fast compile of Flac 1.0.3 available at RareWares.
Regards;
Roberto.
FLAC 1.0.3 Released
Yeah, Frank routinely claims FLAC "doesn't work" but won't give any details even when I ask directly.  I haven't heard anything from Monty about it but I would give that more credibility.  There are no bug reports filed about it and people are using it routinely on all kinds of systems and have been since 1.0.  But I would welcome any specifics.
Josh
FLAC 1.0.3 Released
Josh
Well, I was thinking/hoping for native support within the executable and setting all the "output rules" via the command line... Not via an external application...
FLAC 1.0.3 Released
Excellent Josh  I shall update the dBpowerAMP codecs in the next few days.
If I read the announcements correctly (ok haven't had chance download it yet <slap wrist>), what is the full story with tags - previously there were ID3v1 andv2, now the SDK defaults to Vorbis tags? does the SDK emigrate old tags to new tags?
FLAC 1.0.3 Released
Whenever I use the new version of the Winamp plugin to play a FLAC file I get a message saying:
ERROR: invalid/missing FLAC metadata
I then click OK and in the Winamp playlist window, instead of showing the file name, it shows:
Invalid FLAC File: ""
The file still plays.  However, I don't get the error message if I use the previous version of the plugin.
Since the files I had were encoded with FLAC 1.0.2, I tried decoding them and re-encoding (with FLAC Frontend) using the newer encoder, but I still get the same error message.  I tried this with the bundle downloaded from the FLAC website and also the versions from Rarewares.
I'm using Win98SE and Winamp 2.80.
Thanks,
Rob
BTW, rjamorim, the FLAC bundle zip (dated 2002-07-04) I downloaded from your site doesn't have the files for the frontend in it.
FLAC 1.0.3 Released
The API knows nothing about id3 tags except how to skip them.  The plugins support id3v1 and there are some patches in for id3v2.  So basically all id3 tagging is done with external tools and flac plays nice with them.
Vorbis tags are new and supported by the API and metaflac, but there are no command line options to set them in flac yet and the plugins don't read them yet.  But with the new metadata interface it is much easier to add support for these.
Josh
FLAC 1.0.3 Released
Excellent, I think monkeys went the same sort of way - id3 tags then the API natively supported tags and that worked out well.
For a codec to work well it should read all 3 types, for flac files with existing id3 tags it should try to keep with them, for new files it should always use the new format. It shall be done
FLAC 1.0.3 Released
Same problem here (Win2000 & Winamp 2.80).
FLAC 1.0.3 Released
With this new Flac 1.03 Winamp-plugin, I also get the same problems as rocketsauce & Speek did:
then the file shows as Invalid FLAC File: ""
But the file plays fine and show correct length...
FLAC 1.0.3 Released
I don't have win2k but I'll try some other boxen tonight and try and reproduce it.
Josh
FLAC 1.0.3 Released
Just to add my 2 cents, it happens on XP and Me too.
FLAC 1.0.3 Released
OK, I have the fix here.  Winamp wasn't following it's own plugin spec...
Josh
FLAC 1.0.3 Released
I have noticed that FLAC is available for my home operating system, a console only NetBSD box. But what I really need is a command-line program that can play FLAC files outright; something like a flac123.
Does anyone know if anyone is working on such a beast?
Agent69
FLAC 1.0.3 Released
There's a flac123 in flac-tools .
Josh
FLAC 1.0.3 Released
just for future reference: which part of plugin specs was it this time ?
(yes, i know how much wa2 plugin specs suck better than anyone else)
FLAC 1.0.3 Released
From in2.h:
void (*GetFileInfo)(char *file, char *title, int *length_in_ms); // if file == NULL, current playing is used
Winamp is sometimes calling this function for the "current playing file" case with 'file' not set to NULL, but instead pointing to an empty string (i.e. "").
Josh
FLAC 1.0.3 Released
Hey Josh. Do you expect to gain any better compression in the near future?
You thinking to add some better algorithms like better stereo decorrelation?
According to Florin, it increased Monkey's compression quite a bit.
http://www.monkeysaudio.com/cgi-bin/YaBB/Y...8125336&start=4
Juha Laaksonheimo
FLAC 1.0.3 Released
I think this was based on a private conversation between Matt and Florin... I can't figure out what's special about the technique they are using from just the MAC code, unless it's specific to the adaptive predictor.  FLAC already does the mid-side decorrelation.
I am open to improvements but it is not my main focus for a few reasons.  One, the more exotic the techniques, the more chance of running into patents.  Also, higher compression seems to significantly increase the decoder complexity.  WavPack is probably the only exception here; a low complexity adaptive method is still appealing.
There's only a few percent left to gain and I think now a codec's value is in the features.  But like I said, I'm open to alternatives if they fit in with the above goals.
Josh
