Jeez, since I did a format I've got in a right state here, tried re-importing the library and it won't pick up the track titles any more
Thanks again for the reply, I'm not really sure what I'd prefer, I'll admit I do like the icons very much on yours and think a few of them would be very useful, but ultimately I'm swayed towards the minimilist look of the original, but if I could find a way to put the browser at the top (I'm using Panels UI btw, you said that'll complicate things, but is it still possible?) - cool that you can remove the horizontal scroll bars too!
What do you mean it won't pick up the track titles anymore?
Anyways it's possible to add the browser on top, but like I said it involves coding. Go back to my modified version real quick, and then go to preferences, Panels UI, and then edit layout. Right around the middle, there's a code that looks like this
// PerTrack
$panel(Info,Track Display,$sub(%_width%,239),6,233,330,)
$panel(Seekbar,Seekbar,$sub(%_width%,232),338,222,13,)
$panel(Lyrics,Lyric Show,$sub(%_width%,233),430,225,$sub(%_height%,440),)
$panel(Playlists Dropdown,Playlists Dropdown,$sub(%_width%,232),400,222,22,)
$panel(Infoo,Track Display,$sub(%_width%,205),355,115,20,)
$panel(Playlist,Single Column Playlist,10,200,$sub(%_width%,250),$sub(%_height%,200),)
[b]$panel(Browser Genre,Browser Panel,1,3,150,198,)
$panel(Browser Artist,Browser Panel,150,3,236,198,)
$panel(Browser Album,Browser Panel,385,3,$sub(%_width%,625),198,)[/b]
That's the code to insert a panel, specifically the browser panel on top. As you can see, there's three different ones, with the dawxxx's layout, it's a bit hard to fit three of them in, without stretching out the window size. But if you really wanted to do it, you would have to put a similar code in the same place you found that code, but in his layout.
$panel() = you put a panel somehwere on the layout
Browser Album = name you want to give the panel, you can name it whatever you want
Browser Panel = *must always use that name in order for the browser panel to display*
The first two numbers after Browser Panel defines the position of the panel(x,y), the last two numbers define the dimension of the panels(length,width).
You're going to have to modifty the position and dimensions yourself to fit the windows, I can't give you specific numbers because I don't know the dimensions of your foobar. Play around with the numbers until you get it working.
