Topic: foo_youtube (Read 440923 times) previous topic - next topic
Re: foo_youtube
Reply #1525
e.g. m4a ids 256 and 258 have the same channel layout (per mediainfo), and there is also a several other codecs with id 258 (m48, mp3, aac, wav, and flac)
Re: foo_youtube
Reply #1526
These are YouTube video stream format codes, defined by Youtube.
There are several listings of the format codes available in the web, see here or here.
Codes 258 and 256 are both audio-only and have a m4a audio container which can contain different codecs (usually aac). 258 has 386kbps bitrate, 256 has195kbps.
Re: foo_youtube
Reply #1527
I actually made an account here only for this request:
Please, PLEASE add a filter to search only YouTube Music official music uploads (those music videos with static cover art and "Provided to YouTube by *record label*" in the description.
These uploads:
1. Have much higher audio quality (they are usually transcoded from lossless sources), than regular music videos.
2. Have no audio effects or pauses related to the video
This would turn foobar2000 into a usable light and 0 ads YouTube Music client.
I have no idea how to implement such filter, but I can't imagine it being too hard, you can just filter out the videos that don't have "Provided to YouTube by *record label*" in their descriptions.
NewPipe on Android somehow goes a step further and allows you to filter for YouTube Music albums and playlists, that would be a game-changer.
Btw the component is already great as it is, thanks for developing it.
Re: foo_youtube
Reply #1528
When I start foobar YouTube source search panel follow the colors I have configured
But changing tab and coming back it start using white background with white fonts
I tried with stable and dev versions, both have the same behavior
Re: foo_youtube
Reply #1529
Love this plugin, but I just downloaded the 64-bit beta of v2 of Foobar, so I was wondering if there'll be 64 bit versions available in the future?
"foolish humans, no matter how you try to cover the sky with your hands - is the sky truly smaller than your grasp?" - Gran Kain
Re: foo_youtube
Reply #1530
^ Try foo_youtube 3.9 beta 2 which is 32/64-bit. See change log ('details' link) -
3.9 beta 2 (25-Sep-2022)
  • added 64-bit version for 64-bit foobar2000 v2.0
  • changed minimum requirements to foobar2000 1.5 (was 1.3), Windows XP SP3 (was SP2, at least on paper), and processor with SSE2 instruction set (was [probably] not required)
  • updated foobar2000 SDK to 2022-08-10, switched to Visual Studio 2022
  • included node.js in the package, so corresponding binary (Maintenance Third-party Binaries Javascript) now has an option Bundled (Node.js). This option is the default one now
Re: foo_youtube
Reply #1531
I am a little confused about the behaviour of this component with regards to where fetched items are playlisted. Sometimes new playlists are created (at the bottom of a long list of playlists), other times they are added to the currently focused playlist (at the bottom of a long list of songs!)
Neither of these behaviours are ideal for me and I'd personally find it more helpfui to have fetched URLs always added to a playlist specified in preferences (e.g. "YouTube".) Have I overlooked an option to do this?
Re: foo_youtube
Reply #1532
If you don't like that behaviour, you can configure it so it always fetches the results to a specified playlist. Click on the "youtube.web" text to see the options. "wipe before add" option may also be help for your use case, or fetching videos only (i.e. no playlists).
Re: foo_youtube
Reply #1533
Hmm. The Destination options visible in your screenshot are missing from mine. (EDIT: I found it, but it looks like it's a feature of the YouTube Source Panel and not visible under the View menu.)
I was unaware of this menu as it has not been my modus operandi to use YouTube Source Search or a panel, instead searching in browser, copying links and then opening the dialogue for the "Add multiple URLs" option found in the File menu. Changing the setting seems not to affect the behaviour of the Add URLs option.
Re: foo_youtube
Reply #1534
I used the version of foo_YouTube3.9beta2 and it's pretty good. But I found that it doesn't work with madVR on foobar2000 v2.0 64-bit, showing can't show madVR in the console info. Please how do I solve this problem.
Re: foo_youtube
Reply #1535
Youtube Source 3.9 beta 2 (foo_youtube) (2023-05-22)
foobar2000 v2.0 64bit Default UI
I'm sorry for the delay.
The setting screen does not support Dark-Mode.
Thank you for your support.
SHURE SRH1840, SENNHEISER HD660S, Beyerdynamic DT 1990 PRO, HIFIMAN HE5se, Ultrasone Performance 880, AKG K712 PRO, SONY MDR-1AM2, Bowers & Wilkins P7 Mobile Hi-Fi, Bose QuietComfort 45, SONY WH-1000XM3 (made a Upgrade/Balanced Cable by myself) Shall I write more?
Re: foo_youtube
Reply #1536
Did a format computer, installing 1.6 Foobar + YouTube 3.8.1 plugin, and trying to make things not lagg on the old computer.
So I was trying to limit the kbps because it seemed to be when they was above 4500kbps then songs lagged.
So I did this... Is this wrong is there some better way to do what Im trying to do ?
( Also so long ago since I install the original Foobar+YT, that it can be that I have forgotten to install some Filters or something els to help against the lagging. )
https://prnt.sc/sFlZkcJhcakE
Here is an example of a song that is only 360p and still lagging on ( AM5, 7800x3D, 64GB 6000mhz 30cl, M2 980 Pro, GPU: 1080 (yes the GPU is a bottleneck, buy new "soon" ) )
Bad Bunny - NI BIEN NI MAL | Cover                     www.youtube.com/watch?v=xdt5KdF22J0
Lagging            mp4      12mb   526kbps      h264   360p      30fps
Re: foo_youtube
Reply #1537
Also there are songs like these one's, that when u click it and check source, there are no information on some versions.
And guess the filter determines no info that "less then X" and it picks that song, even if it results in lagging.
Examples of chill background music that has that error for me and causes lagg in video
www.youtube.com/watch?v=SU1apJTv94o
www.youtube.com/watch?v=QRE6bIaxwZU
www.youtube.com/watch?v=6ZgZPflXOg4
www.youtube.com/watch?v=y2SJnCVWbeU
www.youtube.com/watch?v=5yBaI7-docw
So how would I setup so it ignores these picks since they all seem to lagg if the "no information sources" is picked?
Or add / do some changes that results in songs like these not lagging for me?
Re: foo_youtube
Reply #1538
Go switch:https://github.com/yt-dlp/yt-dlp/releases
Re: foo_youtube bug Playlist Title shows as first song
Reply #1539
Bug: Playlist Title shows as first song
X
ojos-azules-cat
Re: foo_youtube: Bug: Channel name doesn't load till the song is play
Reply #1540
foo_youtube bug: Channel name doesn't load till the song is played [See Video]
GIF Format X
Download MP4 - X
ojos-azules-cat
Re: foo_youtube
Reply #1541
How do you uri encode a multi-value tag on the URL?
fy+https://www.youtube.com/watch?fb2k_mytag=VALUE1&fb2k_mytag=VALUE2&v=civuoU_NE38
Will only use the second value. Adding a ';' doesn't work.
Re: foo_youtube
Reply #1542
https://fy.3dyd.com/help/metadata/
use %3b for ;
 fy+https://www.youtube.com/watch?fb2k_mytag=VALUE1%3bVALUE2&v=civuoU_NE38
Re: foo_youtube
Reply #1543
use %3b for ;
I know I have to encode the ';' as %3b, my point is that doesn't work. It just creates a tag with "VALUE1;VALUE2" value, not a multi-valued tag with 2 values.
Re: foo_youtube
Reply #1544
Maybe this?
I think foobar doesn't show well whether it's a multivalue tag or not, because in both cases foobar displays a semicolon. I have the impression that your screenshot is missing a space and that it's not a multivalue tag.
Properties  >  right clic on your tag  >  Split values...
Preferences  >  Advanced  >  search "Multivalue fields". Has your tag been added?
If you use Mp3tag, it shows the difference since its multivalue separator is \\. To see the difference in foobar, I think you can make a column with $meta_sep(name,sep) , for example $meta_sep(mytag, * ) .
Re: foo_youtube [BugReport] Set metadata so foo_openlyrics works
Reply #1545
X
ojos-azules-cat
Re: foo_youtube
Reply #1546
Trying to get it to parse a YouTube playlist and it only gives a blank, 50 second file. This is a new bug as it was working fine a few weeks ago
Got my API all set up and all, but it spits out this
"Unable to open item for playback (Unsupported file format):
"youtube-dl?url=P8aTFQqwV70" "
Re: foo_youtube
Reply #1547
@mattie
what happens if you replace it?
youtube-dl 2023.06.26.19419 (youtube-dl.exe)
https://github.com/ytdl-patched/youtube-dl/releases
foo_youtube_3.9_beta2
https://fy.3dyd.com/download/
Re: foo_youtube
Reply #1548
or
yt-dlp (yt-dlp.exe)
(ffmpeg.exe, ffplay.exe, ffprobe.exe, yt-dlp.exe) in the same folder
Re: foo_youtube [Feature Request] When playing a song from YouTube and If a song
Reply #1549
When playing a song from YouTube and If a song is in library then play it instead of steaming it
ojos-azules-cat
