Topic: Loading multiple playlists causes a crash (Read 971 times) previous topic - next topic
This particular crash has happened a couple of times now - since I started using panels in fact.
So I believe there may be a connection there - but I'm not techincally gifted enough to validate that claim.
The crash occurs when attempting to load mulitple playlists.  However if I load one playlist at a time - Foobar behaves normally.
I'm open to any suggestions as to how I may improve stability and retain functionality.
System:  WinXP SP2, Athlon XP1800+, 512 Ram
--Crash Log-----
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 7C911E58h
Access violation, operation: read, address: 00000000h
Call path:
WinMain=>app_mainloop=>menu_manager::run_command(), by GUID=>playlist_loader::load_playlist
Code bytes (7C911E58h):
7C911E18h:  89 5F 4C EB 8F 33 C9 E9 37 FF FF FF FF 75 10 57
7C911E28h:  56 E8 26 FD FF FF EB AE 0F B7 06 8B 4D 10 03 01
7C911E38h:  3D 00 FE 00 00 0F 87 EE ED FF FF 80 7D 14 00 0F
7C911E48h:  85 97 7A 03 00 8B 4E 0C 8D 46 08 8B 10 89 4D 08
7C911E58h:  8B 09 3B 4A 04 89 55 0C 0F 85 9D 00 00 00 3B C8
7C911E68h:  0F 85 95 00 00 00 56 53 E8 1F ED FF FF 8B 45 0C
7C911E78h:  8B 4D 08 3B C1 89 01 89 48 04 74 49 8A 46 05 A8
7C911E88h:  04 0F 85 2F 7B 03 00 8A 47 05 24 10 A8 10 88 46
Stack (0012F058h):
0012F038h:  00000000 A161F588 BF80F470 BC73B708
0012F048h:  00000020 0003055E 02050001 00000000
0012F058h:  00890000 03312000 00000000 0012F138
0012F068h:  7C910D5C 00000000 03312000 0012F11C
0012F078h:  00000000 00000000 03312008 0043B39C
0012F088h:  024A0000 000001F0 00000018 00000000
0012F098h:  0012F070 00000010 0012F514 0012F23C
0012F0A8h:  00000023 00000000 00890000 00000000
0012F0B8h:  00000080 00000021 01000050 00000108
0012F0C8h:  0000EEC0 00890000 0012EF18 1000294B
0012F0D8h:  00040008 00000000 7FFDF000 0012F144
0012F0E8h:  7C80262A 0012F100 7C802600 00000000
0012F0F8h:  00445574 0043B300 00890000 00000001
0012F108h:  00000000 00000000 00000000 00000000
0012F118h:  0101DA28 00008001 0012F07C 0012EC7C
0012F128h:  0012F170 7C90EE18 7C910570 00000001
0012F138h:  0012F180 77C2C2DE 00890000 00000000
0012F148h:  03312008 00000000 77C2C21B 0043B39C
0012F158h:  004394C4 0012F1D0 0012F184 00445468
0012F168h:  0012F14C 0012EC7C 0012F514 77C35C94
Registers:
EAX: 03310AC8, EBX: 00890000, ECX: 00000000, EDX: 00000000
ESI: 03310AC0, EDI: 03312000, EBP: 0012F064, ESP: 0012F058
Crash location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlInitializeCriticalSection" (+0000032Bh)
Loaded modules:
foobar2000                      loaded at 00400000h - 00452000h
ntdll                            loaded at 7C900000h - 7C9B0000h
kernel32                        loaded at 7C800000h - 7C8F4000h
USER32                          loaded at 77D40000h - 77DD0000h
GDI32                            loaded at 77F10000h - 77F56000h
ole32                            loaded at 774E0000h - 7761C000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F01000h
COMCTL32                        loaded at 773D0000h - 774D2000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
utf8api                          loaded at 10000000h - 1000D000h
comdlg32                        loaded at 763B0000h - 763F9000h
SHELL32                          loaded at 7C9C0000h - 7D1D4000h
PAVSKRE                          loaded at 008D0000h - 008FA000h
pavipc                          loaded at 00900000h - 00921000h
PAVHOOK                          loaded at 00960000h - 0098C000h
Secur32                          loaded at 77FE0000h - 77FF1000h
SYSTOOLS                        loaded at 66600000h - 6661C000h
oleaut32                        loaded at 77120000h - 771AC000h
PAVSPROT                        loaded at 00E40000h - 00E72000h
foo_abx                          loaded at 00F00000h - 00F0A000h
foo_ac3                          loaded at 01080000h - 01093000h
foo_albumlist                    loaded at 010A0000h - 010AB000h
foo_ape                          loaded at 010B0000h - 010CF000h
foo_apl                          loaded at 010D0000h - 010DA000h
foo_bitcompare                  loaded at 010E0000h - 010E8000h
foo_burninate                    loaded at 010F0000h - 010FB000h
VERSION                          loaded at 77C00000h - 77C08000h
foo_cdda                        loaded at 01100000h - 0110E000h
foo_channel_mixer                loaded at 01110000h - 01124000h
MSVCR71                          loaded at 7C340000h - 7C396000h
uxtheme                          loaded at 5AD70000h - 5ADA8000h
foo_console                      loaded at 01140000h - 01147000h
foo_convolve                    loaded at 01150000h - 0117B000h
foo_diskwriter                  loaded at 01180000h - 01192000h
WINMM                            loaded at 76B40000h - 76B6D000h
serwvdrv                        loaded at 5CD70000h - 5CD77000h
umdmxfrm                        loaded at 5B0A0000h - 5B0A7000h
foo_dsp_crossfeed                loaded at 01220000h - 01226000h
foo_dsp_extra                    loaded at 01230000h - 01245000h
foo_dsp_nogaps                  loaded at 01250000h - 01257000h
foo_dsp_pause                    loaded at 01260000h - 01267000h
foo_dsp_skip_silence            loaded at 01270000h - 01277000h
foo_dsp_soundtouch              loaded at 01280000h - 0128B000h
MSVCP60                          loaded at 76080000h - 760E5000h
foo_dynamics                    loaded at 01290000h - 01297000h
foo_festalon                    loaded at 012A0000h - 013DF000h
foo_flac                        loaded at 013E0000h - 013FA000h
foo_freedb                      loaded at 01400000h - 0142E000h
WS2_32                          loaded at 71AB0000h - 71AC7000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
foo_history                      loaded at 01430000h - 01445000h
foo_id3v2                        loaded at 01450000h - 01476000h
foo_infobox                      loaded at 01480000h - 01493000h
foo_info_samurize                loaded at 014A0000h - 014BB000h
dlgmate                          loaded at 014D0000h - 014E0000h
foo_input_std                    loaded at 014F0000h - 0158E000h
MSACM32                          loaded at 77BE0000h - 77BF5000h
foo_looks                        loaded at 01590000h - 015FD000h
gdiplus                          loaded at 4EC50000h - 4EDF3000h
foo_lpac                        loaded at 01610000h - 01617000h
lpac_codec_api                  loaded at 01620000h - 0162A000h
lpaccodec                        loaded at 01630000h - 01659000h
foo_masstag                      loaded at 01880000h - 01894000h
foo_matroska                    loaded at 018A0000h - 018DF000h
foo_mod                          loaded at 018E0000h - 018E9000h
BASS                            loaded at 018F0000h - 0194A000h
foo_mpeg4u                      loaded at 01950000h - 01979000h
foo_nez                          loaded at 01980000h - 019AC000h
foo_ofr                          loaded at 019B0000h - 019DE000h
foo_oggpreview                  loaded at 019F0000h - 01AED000h
foo_output_std                  loaded at 01AF0000h - 01AF9000h
foo_out_dsound_ex                loaded at 01B00000h - 01B09000h
DSOUND                          loaded at 73F10000h - 73F6C000h
foo_out_ks                      loaded at 01B20000h - 01B2B000h
SETUPAPI                        loaded at 77920000h - 77A13000h
foo_playcount                    loaded at 01B30000h - 01B3A000h
foo_playlistfind                loaded at 01B40000h - 01B4B000h
foo_psf                          loaded at 01B50000h - 01BFB000h
foo_quicktag                    loaded at 01C00000h - 01C0C000h
foo_read_http                    loaded at 01C10000h - 01C2B000h
foo_remote                      loaded at 01C30000h - 01C3B000h
foo_rgscan                      loaded at 01C40000h - 01C4D000h
foo_scheduler                    loaded at 01C50000h - 01C65000h
foo_search_ex                    loaded at 01C70000h - 01C78000h
foo_send_to_pl                  loaded at 01C80000h - 01C89000h
foo_shn                          loaded at 01C90000h - 01C9E000h
foo_shuffle                      loaded at 01CA0000h - 01CAE000h
foo_sid                          loaded at 01CB0000h - 01CF7000h
foo_spc                          loaded at 01D00000h - 01D0F000h
foo_speex                        loaded at 01D10000h - 01D28000h
foo_stfu                        loaded at 01D30000h - 01D37000h
foo_syfm                        loaded at 01D40000h - 01D4A000h
MSVCR70                          loaded at 7C000000h - 7C054000h
foo_tfmx                        loaded at 01D60000h - 01D69000h
foo_tlbRC                        loaded at 01D70000h - 01D8D000h
foo_uie_albumart                loaded at 01DA0000h - 01DAC000h
MSVCP71                          loaded at 7C3A0000h - 7C41B000h
foo_uie_albumlist                loaded at 01DB0000h - 01DBF000h
foo_uie_ascii_buttons            loaded at 01EC0000h - 01EC6000h
foo_uie_simple_spectrum          loaded at 01ED0000h - 01EDB000h
foo_uie_tabs                    loaded at 01EE0000h - 01EEA000h
foo_uie_trackinfo                loaded at 01EF0000h - 01EFB000h
foo_uie_volume                  loaded at 01F00000h - 01F0A000h
foo_ui_columns                  loaded at 01F10000h - 01F47000h
foo_ui_std                      loaded at 01F50000h - 01F67000h
foo_unpack                      loaded at 01F70000h - 01FA1000h
foo_vis_bacon                    loaded at 01FB0000h - 01FC8000h
foo_vis_manager                  loaded at 01FD0000h - 01FD8000h
foo_vis_simple_spectrum          loaded at 01FE0000h - 01FEA000h
foo_vis_stereo                  loaded at 01FF0000h - 02078000h
foo_vis_vu_meter                loaded at 02080000h - 02088000h
foo_vorbisenc                    loaded at 02090000h - 0218A000h
foo_wavpack                      loaded at 02190000h - 021A2000h
foo_web                          loaded at 021B0000h - 021C9000h
foo_wma                          loaded at 021D0000h - 021E9000h
WMVCore                          loaded at 086C0000h - 08904000h
WMASF                            loaded at 070D0000h - 0710B000h
foo_xa                          loaded at 021F0000h - 02201000h
foo_winamp_spam                  loaded at 02210000h - 02218000h
Powrprof                        loaded at 74AD0000h - 74AD8000h
appHelp                          loaded at 77B40000h - 77B62000h
CLBCATQ                          loaded at 76FD0000h - 7704F000h
COMRes                          loaded at 77050000h - 77115000h
cscui                            loaded at 77A20000h - 77A74000h
CSCDLL                          loaded at 76600000h - 7661D000h
browseui                        loaded at 75F80000h - 7607C000h
USERENV                          loaded at 769C0000h - 76A73000h
ntshrui                          loaded at 76990000h - 769B5000h
ATL                              loaded at 76B20000h - 76B31000h
NETAPI32                        loaded at 5B860000h - 5B8B4000h
shdocvw                          loaded at 77760000h - 778CC000h
CRYPT32                          loaded at 77A80000h - 77B14000h
MSASN1                          loaded at 77B20000h - 77B32000h
CRYPTUI                          loaded at 754D0000h - 75550000h
WINTRUST                        loaded at 76C30000h - 76C5E000h
IMAGEHLP                        loaded at 76C90000h - 76CB8000h
WININET                          loaded at 771B0000h - 77256000h
WLDAP32                          loaded at 76F60000h - 76F8C000h
xpsp2res                        loaded at 20000000h - 202C5000h
DBGHELP                          loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 7C910D5Ch, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+000002CDh)
Address: 0043B39Ch, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 1000294Bh, location: "utf8api", loaded at 10000000h - 1000D000h
Symbol: "stricmp_utf8" (+0000003Ah)
Address: 7C80262Ah, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "WaitForSingleObjectEx" (+000000DAh)
Address: 7C802600h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "WaitForSingleObjectEx" (+000000B0h)
Address: 00445574h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0043B300h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000117h)
Address: 7C910570h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 77C2C2DEh, location: "msvcrt", loaded at 77C10000h - 77C68000h
Symbol: "free" (+000000C3h)
Address: 77C2C21Bh, location: "msvcrt", loaded at 77C10000h - 77C68000h
Symbol: "free" (+00000000h)
Address: 004394C4h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00445468h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 77C35C94h, location: "msvcrt", loaded at 77C10000h - 77C68000h
Symbol: "except_handler3" (+00000000h)
Address: 77C12070h, location: "msvcrt", loaded at 77C10000h - 77C68000h
Symbol: "__non_rtti_object::`vftable'" (+00000C78h)
Address: 00424AA9h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00446428h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0043B36Ch, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0043B3A0h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0043946Ch, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00439990h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0043986Ch, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00445464h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 004361DCh, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 77C2C2E3h, location: "msvcrt", loaded at 77C10000h - 77C68000h
Symbol: "free" (+000000C8h)
Address: 004347C0h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0043B388h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00429019h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00446614h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0043B4F0h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0043A1C8h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0043A1B4h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00428EA3h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 004012D5h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00402BD3h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 01F07148h, location: "foo_uie_volume", loaded at 01F00000h - 01F0A000h
Address: 004134C6h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 01F311F9h, location: "foo_ui_columns", loaded at 01F10000h - 01F47000h
Address: 01F309A6h, location: "foo_ui_columns", loaded at 01F10000h - 01F47000h
Version info:
foobar2000 v0.8.3
UNICODE
