in plugin "albumlist":
open its config dialog, double click the item in the listbox, then edit the value, click "ok", but the listbox still display the former value, don't refresh automatically.
this is the source code(include bug):
case IDC_VIEWS | (LBN_DBLCLK<<16):
unsigned idx = uSendMessage((HWND)lp,LB_GETCURSEL,0,0);
if (idx != (unsigned)(-1))
edit_view_param p;
p.b_new = false;
p.name = cfg_view_list.get_name(idx);
p.value = cfg_view_list.get_value(idx);
if (run_edit_view(p,wnd))
cfg_view_list.modify_item(idx,p.value);
break;
should be modified as the follow:
case IDC_LIST_FILENAME | (LBN_DBLCLK<<16):
HWND list = uGetDlgItem(wnd,IDC_LIST_FILENAME);
unsigned m = cfg_view_list.get_count();
edit_view_param p;
p.b_new = false;
string8 temp;
cfg_view_list.format_display(idx, temp);
uSendMessage(list, LB_DELETESTRING, idx, 0);
uSendMessageText(list, LB_INSERTSTRING, idx<(m-1)?idx:-1, temp );
uSendMessage(list,LB_SETCURSEL,idx,0);
break;
