Topic: How high w/WMA STD to sound CD LIKE? (Read 5156 times) previous topic - next topic
How high would the bitrate for Standard WMA (9.2  not Pro ) would you have to go up to , to achieve transparency? I ask this because I want to use wma (no flames please) and because wma in tests seems not fare as well at mp4, lame, etc... that I wondered then how much higher in a CBR or VBR bit rate range I would have to go to square against say.... .AAC
Depends on your music and your ears.  I'd imagine ~160-192k is probably pretty safe for VBR.
How high would the bitrate for Standard WMA (9.2  not Pro ) would you have to go up to , to achieve transparency? I ask this because I want to use wma (no flames please) and because wma in tests seems not fare as well at mp4, lame, etc... that I wondered then how much higher in a CBR or VBR bit rate range I would have to go to square against say.... .AACThanks
Your own ears are the best test. I would start at 96 bitrate and compare to original. Then, try 128 and compare.  Keep going up in bitrate until you can't hear a difference, When you can't hear a difference, then you have the right bitrate.
Thank you both  I went with the WMA VBR 135-215
