Topic: [Suggestions / Wishlists] for future updates (Read 119177 times) previous topic - next topic
Re: [Suggestions / Wishlists] for future updates
Reply #625
Any word if regex is planned for title formatting? I've asked prior to v2 but hopefully, it can for this new version.
Reply #626
Export playlist(s) function with dialog to choose which ones.
Reply #627
To make Refacets able to show album art same as Facets could
PC - Teac UD-505 - Adam Audio A4V - DCA ÆON Open X
Android phone - Fiio UTWS5 - TinHifi P1 Max.
Reply #628
Refacets need also dynamic color . Very ugly in white.
Reply #629
foobar2000 v2.0 Playlist View: Could you please add Subgroup feature?
(It seems that there are many requests)
https://i.imgur.com/QGFOenh.png
SHURE SRH1840, SENNHEISER HD660S, Beyerdynamic DT 1990 PRO, HIFIMAN HE5se, Ultrasone Performance 880, AKG K712 PRO, SONY MDR-1AM2, Bowers & Wilkins P7 Mobile Hi-Fi, Bose QuietComfort 45, SONY WH-1000XM3 (made a Upgrade/Balanced Cable by myself) Shall I write more?
Reply #630
foobar2000 v2.0 Playlist View: Could you please add Subgroup feature...
Add this in Preferences / Playlist View / Custom grouping scheme
[$swapprefix(%album artist%)] [- %album%] ['('[Disc [%DISCNUMBER%][/%TOTALDISCS%]]')']
Neither an audiophile, nor album snob. Why do ratings threads always have someone saying they don't believe in rating music?
Record Label Icons: 600x600 pngs appropriate for any color background:
freeimage.host/johnbuck/?list=images&sort=name_asc&page=1
Reply #631
But not Subgroup.
Are you using foobar2000 v1.6.xx SImPlaylist (Subgroup)?
Reply #632
it's great to be here. The Features I would like to see in foobar2000:
1) I would like to be able to configure different file types in different directories to be handled specifically. For example having a .flac Image database requires me to set foobar2000 to read the .cue files, but also having multitrack flac albums even without a playlist (m3u for example) would require me to locate these in a different directory and tell foobar2000 to manage them differently than the flac-image .cue-files.
2) I love to use the component Kernel Streaming support 1.22 with my Creative Soundblaster Audigy 2 ZS Platinum Pro and other PCI Cards. The quality is great, even better than using exclusive mode.
I would love to see this being ported to the 64 Bit Version.  In comparison exclusive mode is very analytic but Kernel Streaming support sounds more natural like being on a stage with a natural spectrum. It is very audiophile. This keeps me away from changing to the x64 version.
Reply #633
Would there be any sense for fb2k to use FILE_ATTRIBUTE_TEMPORARY for temp files when converting? I don't know the whereabouts of it, or whether the files will be so big that they are flushed to disk anyway, but wouldn't that reduce I/O when that option is checked?
Reply #634
HI.
It seems to me that one of the things that is most missing in FB for Mac is the ability to group tracks in playlists according to certain titleformatting strings.
The playlist takes up almost the entire screen to show data that repeats the same for each track, while grouping the fixed data for each album like it does with FB on windows would not only make the playlists take up less space, but also make the tracklist easier to read.
Reply #635
If possible, I would like to see all of the library options from the original Facets (such as and especially "send to selection playlist, keep playing playlist" added to ReFacets.  Without these, there are things that aren't possible any more.  This and lack of SimPlaylist are the things keeping me from using x64.  Thanks.
Reply #636
Please add update new version flac 1.4.3.
Reply #637
The ability en embed .cue files in .flac files would be great (it used to be possible in pre-2.0 versions)
Reply #639
Favicon for a radio station.
I request the Developer to consider adding to the "Internet Radio" panel the column with a path to favicon of the radio station from the radio-browser database and display this favicon using the "Album Art Viewer" panel.
In case the user specified a path to a local favicon file, display that file instead of the favicon from radio-browser.
For example, a radio with favicon from the radio-browser is: https://www.radio-browser.info/history/7481adce-989e-4692-bfcf-07774ed1ced9.
Thank you.
Reply #640
Rating stars for the Internet Radio panel
For the "Internet Radio/Known stations" panel, add a column with the rating stars of the "Playback Statistics" component.
The rating changes in the playlist, and in the panel "Internet Radio" is only displayed for the sorting.
Reply #641
Enhance update checking
* Instead of opening the Information dialog to report "No new version available at this time," display "No update found." in the lower right of the main window for several seconds.
* When an update is found (matching the architecture and the "Check for beta versions" setting), populate the Information dialog with (1) a link to new version and (2) a link to the change log.
* Add a setting, in days, for automatic update checks.
Reply #642
great ideas, I second them.
Reply #643
Built-in subwoofer digital crossover
  • adjustable crossover frequency
  • able to mixdown subwoofer output to mono
  • able to route the subwoofer output to a secondary DAC or device
  • adjustable crossover slope
Reply #644
I need a community of friends who will be able to modify or recreate the popular EasyChords winamp plugin which is currently in development known as Chords!. because with this plugin we can know what chords are used when playing a song.
Reply #645
If possible, I'd like to see a [filter search] in active playlist view, rather than creating another playlist via [Playlist search] or [Library search].
Reply #646
Seconded!
Reply #647
I use  foobar for many years and found it the best and easiest to use for so many things! Arranging playlists, renaming tracks and filenames, adding cover art, editing metadata is great too, searching for artist track titles via web and discogs, etc. Thanks for such a great and feature packed music player.
However, you knew that was coming eh? I control basic foobar functions via Rainmeter. But with the update of foobar to x64 I have lost that control. Like many other users probably having trouble finding or adapting new x64 plugins.
As there was a new plugin developed for Rainmeter called MediaPlayer, I have tried to get that to do what the older CAD plugin does. It's not going too well so far, though the dev of that plugin is great and is fixing issues very quickly.
The only issue that has arisen, is the lack of support for certain track info's. Things like track position, duration, album name and year are my most wanted.
Could we have support for all playing info (or at least, all info that can be) is communicated to the System Media Transport Controls aka the SMTC API, for easy usage by 3rd party applications displaying such things or even Windows itself. Complete SMTC support would be great, but failing that, even just the basics as I mentioned, I would be happy with.
Tbh, the foo_cad_plus plugin was the best for my needs, and I would love to see that updated to 64bit. Maybe one day it will...?
foobar2000  x64
Reply #648
Toggle DSPs
In DSP Manager, It would be helpful to:
1. Toggle instead of having to remove and re-add each DSP.
2. Toggle each DSP when adjusting its settings, perhaps by adding a toggle in the lower left corner on the buttons row.
Reply #649
PLEASE
