Topic: [Suggestions / Wishlists] for future updates (Read 103944 times) previous topic - next topic
Re: [Suggestions / Wishlists] for future updates
Reply #500
Hi :)
\foobar2000\profile\dsp-presets folder is very convenient.
But, I want you to remove the character limit and frame limit of DSP chain presets.
https://i.imgur.com/mGcdMPn.png
Hi :)
foobar2000 v2.0 beta 13 32bit 64bit:
DSP Manager > Active DSPs > DSP chain > presets
Standard installation: \AppData\Roaming\foobar2000-v2\dsp-presets\.fb2k-dsp
Portable installation: foobar2000\profile\dsp-presets\.fb2k-dsp
.fb2k-dsp name can now be edited.
It has a long name. Reflected after editing.
https://i.imgur.com/YB1G1xd.png
SHURE SRH1840, SENNHEISER HD660S, Beyerdynamic DT 1990 PRO, HIFIMAN HE5se, Ultrasone Performance 880, AKG K712 PRO, Bowers & Wilkins P7, SONY MDR-1AM2, Bose QuietComfort 45, SONY WH-1000XM3 (made a Upgrade/Balanced Cable by myself) Shall I write more?
Reply #501
Hello,
I would really like foobar2000 to support seeking when playing files over HTTP(S) when the server reports Content-Length.
Even if it's done inefficiently, like multiple requests following a single seek.
And downloading whole mp3 until the seek point is OK, just want it to work exactly like from a disk, but over HTTP using Range header.
Ideally, on the first seek request foobar2k would make a second connection to check if the server actually supports Range/206, and if it doesn't would disable seeking for this file.
Huge thanks in advance!
Reply #502
A Screensaver function would be nice.
To save my oled burning in and waisting energy it would be nice if the program weakens the brightness to a lower level after xx min.
Reply #503
Seems to me that's outside the scope of foobar. That's more of an OS thing.
Reply #504
Any plans for:
-  'stream selector' element to Default User Interface toolbar and
- new audio output device management features - unwanted devices can be disabled, bit depth and DSP can be configured per-device (both from v2) to be implemented in v1.6....?
Reply #505
I am basically spamming at this point, but Please! hear me out, there are full width character versions for all the illegal unicode characters, in this unicode website there is a list of all full-width characters, putting in the term "Fullwidth" in the search field will bring up the list. Please! look into this topic.
Reply #506
Is there any chance to implement a native playback rate (tempo/Pitch independent) in the final 2.0 release?
Reply #507
Hi, everyone.  As a longtime user of the software, I would like to make a few comments about the new versions.  I have sufficiently tested the new version 2.0 both as 32 bit and as 64 bit.  since i don't use either the playback statistics or the album list, i think it's a pity that they can't be deactivated.  these are very resource hungry especially when starting the software.  I find the new ReFacets useless because there are no album covers and no possibility to combine several tags.  the 64-bit version is currently out of use because I can't find a playlist view that comes close to the el playlist.  so that's enough criticism.  I also find great praise for Peter: still the best audio player in the world.  thank you frank
Reply #508
I would like to see foobar2000 autosave its playlist position more often, at least once at the end of every track.
Sometimes I let foobar2000 play for hours on end and then Windows blue screens, and the playlist position is reset to many songs before when I relaunch foobar2000. It's annoying.
Reply #509
Native 2.0 support for foo_dsp_effect is being worked on. Major updates are being done to cater the backlog of things people wanted added to it.
Reply #510
Playback statistics linked (again) to  artist + album + disc number + track number + track title information.
Reply #512
I do this once in a bloodmoon to ruin my listening experience in exchange for comedic effect.
Reply #513
...but those of us who play music for dance need it.  Prior to v2 (I believe) it is only supported in DUI not CUI.
Reply #514
Configurable Tag caching to put performance problems on big libraries to an end on 64 bit systems with enough RAM.
https://hydrogenaud.io/index.php/topic,123044.0.html
Reply #515
hurdur, now you know why I made them to begin with. And why ideally they shouldn't be used by anyone because they ruin "the artist/developer's original *artistic vision*"
Whatever the hell that means anymore.
Reply #516
Peter, can you reconsider?
X
If the converter has created multiple output folders from one source folder - could you please add a suboption to copy files to the multiple target folders?
Simple use case:
1. Album with Symphony No. 1 and 2 - FLAC source in one folder
2. Tagets will be in "DEST\Symphony No. 1\" and "DEST\Symphony No. 2\"
As it currently is, fb2k has copied files only to the first folder.
Reply #517
I guess this is the place to make requests for V2.
The feature "remember layout for this playlist" is a welcome addition to foobar2000. However, it seems I can't copy a layout and apply it to other playlists. The best I can do is switch the grouping scheme, but that doesn't load custom columns.
Request: It would be awesome if foobar V2 had a proper playlist layout manager. I would like to setup a full playlist layout and then apply that layout to multiple playlists. And if I update a layout, it would update all the playlists.
This. It also doesn't remember column resizing consistently as reported elsewhere.
Reply #518
Since version 1.6.7 foobar can read per-track REM COMMENT in cuesheets. My wish is that it could also read per-track FLAGS or even better - an arbitrary field which could then be retrieved using $info(X), $meta(X) or similar function e.g.:
$info(FLAGS)
$info(ISRC)
$info(REM DISCNUMBER)
$info(REM TOTALDISCS)
$meta(REM CATALOGNUMBER)
$meta(REM DISCSUBTITLE)
Reply #519
adding another "Please add sub grouping to playlist view (DUI) a la SimPlaylist" request. It's vital for how I use foobar.
Reply #520
hello
foobar mac os
in PREFERENCES -> SHELL INTEGRATION -> ALWAYS SEND FILES TO NEW PLAYLIST
there could be option that takes e.g. 8 characters of Artist/Album or Title/Track Artist and use it
for new playlist name
bests
Reply #521
sory i forgot to mention that it could take also file or directory name for playlist name
thx
Reply #522
Foobar can open shortcuts to audio files when you double-click on them, but not when you drag the shortcuts into the playlist. That means for example, that when I drag a bunch of audio files into foobar, any shortcuts will be skipped. I would need to navigate to the real location of each shortcut to drag it into the playlist. Or I would need to use the enter key, but that is no good when I'm trying to edit an existing playlist.
Therefor I wish that foobar would support dragg & drop of shortcut files.
Reply #524
@Peter I've been using version 2.0 for a while now and have just transitioned to version 2.0 Beta 19 for everyday use because all the major bugs I was experiencing seem to be quashed. 👍
These are my suggestions to improve the UI/UX (and a lot of these are features from SimPlaylist and have already been iterated by me or others through the forum. I'm just adding them to one comprehensive summary here)
Playlist view
  • Dim color of unrated stars. Just to clarify my terms, I believe the proper name of the unrated star glyph is the White Star, and the rated star glyph is known as the Black Star. Please please please dim the color of the unrated star glyphs [ala SimPlaylist]. When every track has some kind of rating, it becomes very difficult to distinguish the ratings (unrated vs rated glyphs) when all the glyphs are the same color. Dimming the color of the unrated star glyphs makes readability of the rated star glyphs much better. Add a toggle option for this in the preferences if it's a potentially controversial change?
    Screenshot of SimPlaylist showing the dimmed unrated star glyphs.
    Playlist view (no dimming of unrated star glyphs)
  • Multiline form field for editing patterns. Preferences > Editing patterns field. Please consider changing this to a multiline field similar to SimPlaylist. SimPlaylist allows for carriage returns/indentation in the titleformating pattern. This is very useful as people who create complex titleformating patterns in foo_tfsandbox or a text editor may use carriage returns/indentation to help with readability. However, as it is now, pasting these patterns into Playlist View is impossible without sanitizing the indentation/carriage returns/commented lines, and of course then the human readability of the pattern is lost forever.
  • Add option to sort custom columns. Implement a method in the preferences to quickly sort custom columns. Perhaps via a right click context menu option. Currently we have to reorganize them manually one a time which is laborious for for large sets of custom columns.
  • Add a scrollbar to the columns context menu. Currently the custom columns menu will add a white up and down icon respectively to navigate a columns context menu containing overflow items. This is extremely laborious as it requires manually clicking the up or button menu each time, especially to navigate to the "More" entry. This would be much easier by replacing the up/down icons with a context menu scrollbar.
  • Add custom padding option for columns. Add an option in the preferences where users can specify how much padding (in pixels?) is added between columns and rows. This would help in readability for users that may want a Gmail-esque "comfortable" mode that adds padding between the text strings of cells.
  • Groups > Pin when scrolling [ala SimPlaylist]. The group header is pinned when scrolling.
  • Nested groups [ala Simplaylist]. Add the ability to have more than one group -- nested groups.
  • Dim text within brackets or parentheses [ala SimPlaylist]. Add a toggle option for this in the preferences (if this could be a controversial change?)
ReFacets
  • Columns auto-size option
  • Statistics > Rating [stars column]
    This is a feature from the original Facets
  • Sorting columns and filters. Implement a way in the preferences to quickly sort filters and columns. Perhaps via a right click context menu option
