Topic: Resurrecting/Preserving the Helix MP3 encoder (Read 214587 times) previous topic - next topic
Re: Resurrecting/Preserving the Helix MP3 encoder
Reply #600
@KevinB52379, could you please give this GCC x64 build a try? All my previous GCCx64 offerings had the 'msvcrt' dependency whereas this one has the 'ucrt' dependency which the Clang compiles also depend on. Will it make any difference? I guess we're about to find out!
https://www.rarewares.org/files/mp3/hmp3-dev-5.2.4-20240612-UCRT64.zip
I appreciate your efforts, I really do...but unfortunately, this compile is one that causes one of the worst system freezes/hanging I've seen to date.  The "Abort" and "Pause" button don't even appear on the dialog box during conversion with foobar.  The file progress list never changes, however the progress bar does, albeit slower than a Helix compile that works fine on my system.
Thanks for trying though :)
Reply #601
Ah well, some you win and some you don't!! Thanks for trying it out.
Reply #602
When experimenting with web radio usage, it turned out that hmp3 would create very bursty output, with many MP3 frames being emitted every few seconds. That's because by default, hmp3 fetches ~3 seconds of input data, then encodes and outputs that audio, then fetches another big chunk of audio. For file-based use cases, that's desirable to avoid I/O-overhead.
For web radio, that's potentially problematic. Thus hmp3 now switches to a "low delay" mode when outputting to stdout. In this mode, input audio is consumed and encoded in small chunks (as few bytes as the encoder expects for a complete MP3 frame), which lowers the delay and creates a more evenly spaced stream of packets.
https://github.com/maikmerten/hmp3/commit/2b03a33c760693dc29d6e6854211684452ff703b
Reply #603
Lastest dev builds:
win32XP: https://www.rarewares.org/files/mp3/hmp3-dev-5.2.4-2b03a33c-20240615-win32XP.zip
GCC x64: https://www.rarewares.org/files/mp3/hmp3-dev-5.2.4-2b03a33c-20240615-x64.zip
CLang x64: https://www.rarewares.org/files/mp3/hmp3-dev-5.2.4-2b03a33c-20240615-Clang.zip
Reply #604
Did the encoding complete in expected time window when it causes the system to hang?
(i.e. did the encoding time consumption of hang/no-hang situation roughly the same?)
If you use single thread will the system still hang?
Reply #605
The elapsed time/time remaining never shows up, neither do the "Pause" and "Abort" buttons.  The progress bar is the only thing that changes, and it is much, much slower than versions that works for me...it does however successfully create mp3s once the encoding is done and the system becomes responsive again.
Reply #606
Has development on the Helix mp3 encoder stopped?  There hasn't been any posts here lately.
FYI - I recently got a new computer (Lenovo IdeaCentre 3 desktop) with 32gb of DDR4 RAM, Intel UHD 770 graphics and an Intel Core i7-14700.
Using the 64 bit Helix encoder from Rarewares, I can encode 5071 songs in under 9 and a half minutes (files are on the SSD and encoding to the same SSD).
Reply #607
There isn't really anything that needs to be done to the encoder at the moment. And you never provided any logs or debug information to help figure out what in your old system caused the system freeze. It was not your CPU, other users with the same hardware didn't have the issue. It was none of the other software you mentioned (I installed a virtual environment where I tested the screen reader, process lasso and your antivirus - they couldn't make the system freeze combined with hmp3).
Reply #608
I think that, in terms of functionality and performance, the goals set for the common user have been achieved. Case and Maikmerten have IMHO brought this encoder up to "competition" standard, which means a lot of work and time invested!
As far as buggyness is concerned.. I use the current main branch build 5.2.4, namely Wombat's compile from 1.6 and Joshua's PGO compile from 9.6 via fb2k converter on various Intel platforms and configurations up to 11th generation (Tiger Lake). The result from a casual usage perspective is that I can't contribute with any bug report, starting with both stability and performance, unfortunately.. ;)
If I understood it correctly, there is a realtime conversion optimization for web radio needs currently in the works at Developer Branch, which can potentially contribute to more hmp3 expansion. This is obviously of more "strategic" than user interest.
So.. be happy with the build you currently use and report a bug if any. That's it, i think.
Sorry for small Off-Topic/Request:  Personally, I would be delighted if hmp3 and 64-bit versions of the other encoders appear in Case's Free Encoder Pack sometime in the future ;)
Reply #609
I admit the reason I didn't do much debugging is because I was frustrated, not at you, but at the situation, and I apologize for that.
I'll be honest Case, I admire what you've done, and appreciate all the hard work you'v eput into Helix MP3 encoder (as well as the other contributors).  I think the hard work you all have put in have made Helix an excellent MP3 encoder, and I admit it is the primary MP3 encoder I use.
The version that is the fastest for me on the Intel Core i7-14700 is Joshua's clang PPO version of 5.2.4.
I will also admit over the last couple of weeks I was having issues with that system (random restarts and system shut downs).  Was pretty sure it was a hardware issue and the system was out of warranty and since it was an HP it has proprietary parts so repair would be difficult.
When I was asking about further developments to helix, it wasn't because I was unhappy or anything, on the contrary I am very pleased with the encoder and the work put into it.  Sorry if I sounded like I was being impatient or unhappy with the progress.
I still also think there was an issue with my screen magnification software Zoomtext that played a part too.  Because when I used the built in windows magnifier, I didn't have this freeze problem.
Reply #610
I will just enter the discussion to inform @KevinB52379 that there is a big discussion over these new Intel processors, it seems that they have some defects, and Intel is scrambling with microcode updates to fix it - it has thermals misconfigured, as far as I understood, so it often crashes and behaves erratically.
More info can be found at various youtube channels that review hardware, I found pretty lengthy explanation at GamersNexus youtube channel. If you are the guy who had problems with encoder encoding slowly and /or stopping, it could be just that - CPU bug. BIOS updates should arrive soon, so you can try these first.
TAPE LOADING ERROR
Reply #611
Kevin, are you using / were using variable refresh rate monitor?
gold plated toslink fan
Reply #612
Unfortunately (or fortunately since I am ware of the issue?) I found out about these issues a few days ago (after I bought the Lenovo).  I became aware of it because os the GamersNexus on Youtube (I'm subscribed to them because I find their videos interesting).
I am guessing I avoided the oxidation issue, because I have a 14th gen and that issue seems to impact early 13th gen processors.
As for the voltage issues, there was a BIOS update when I set up the computer, and then there was another one a day or two later (this one I am guessing has the micro architecture changes and the voltage fix).
Thankfully I only had the computer a day or two before this BIOS update came out.
I ran a utility called StressMyPC with aggressive CPU testing for a couple hours or so and no system freeze or reboot.
Last night I ran Cinebench and it completed without issues (I ran all tests).
I am planning on running Prime95 for a couple of hours or so and see how that goes.
I did consider returning the PC and getting an AMD based system again (my previous desktop was a Ryzen 7 5700g).  But, I didn't find out this issue until after the purchase, and my mom did it as a gift, so I didn't want to cause trouble.
I had just returned a computer to Amazon because the seller advertised it as new, but it was opened to upgrade it (which was not disclosed in the item listing) and worse of all the computer was Gray Goods (The computer was designed to be sold and used in the United Arab of Emirates and I could NOT buy a warranty from Lenovo).  Naturally I returned this computer for full refund and left negative feedback to seller).
My final action is going to be buying an extended warranty through Lenovo for at least 3 years because if the processor becomes unstable, I want to get it fixed even if it's over a year out.
Reply #613
Before buying an extended warranty...
https://community.intel.com/t5/Processors/Additional-Warranty-Updates-on-Intel-Core-13th-14th-Gen-Desktop/m-p/1620853
https://www.anandtech.com/show/21499/intel-extends-13th-14th-gen-core-retail-cpu-warranties-by-2-years-in-response-to-chip-stability-issues
Reply #614
I am experimenting with the Helix mp3 encoder for the first time, using the 64-bit 5.2.4 binary hmp3.exe posted at Rarewares, via  Foobar 2.24.1 x64, Free Encoder Pack installed.
It works fine encoding 16-bit, 44.1 kHz FLAC to MP3, settings -HF2 -V150 (32-bit float).  However when I tried converting a 24-bit, 96kHz FLAC, I received an error message:
  "Encoder stream format: 96000Hz / 2ch / 24bps
  Command line: hmp3.exe -HF2 -V150 - "Witch of the Vale - 11 - The Way This Will End.mp3"
  Conversion failed: The encoder has terminated prematurely with code 0 (0x00000000); please re-check parameters."
The same FLAC converted just fine to a 48kHz MP3 using the Lame.exe supplied by Case's Free Encoder Pack using params -S --noreplaygain -V 0, 32-bit float.
What parameters am I missing with Helix to handle the 24-bit 96kHz FLAC?
Reply #615
The sample rate isn't supported. Add a resampler to the DSP config.
Reply #616
 ;D  ;D  ;D
Reply #617
Thanks!  SoX to 48kHz, worked great.  And thanks for your work updating this codec.
Reply #618
Questions:
1.  Could you please give an example of how to use the -A option to specify a sample rate?
2.  If the -A option is used, as opposed to resampling via the Foobar SoX DSP, what resampler is actually used?  Is it inferior to using the external SoX DSP?
Thanks for any help.
Reply #619
Really liking this encoder over LAME 3.100 for a ton of reasons while being very fast for encoding.
OptimFrog PC | TAK -p4m(Phone)
Reply #621
Dev update here: https://github.com/maikmerten/hmp3/tree/dev
allow MPEG1 mode down to 32 kbit/s per channel
Windows x64 GCC 14.2 compile: https://www.rarewares.org/files/mp3/hmp3-5.2.4-dev-028bc2f-20250111-x64.zip
If anyone wants a win32 compile, please let me know.
Reply #622
Just to clarify what's in that dev-build: I removed an artificial lower bound on MPEG-1 bitrates. Previously, one could not encode MPEG-1 modes (32, 44.1, 48 kHz) with less than 48 kbps per channel. Now it also allows for 32 kbps and 40 kbps per channel.
Absolutely no change otherwise.
Reply #623
Was there a reason why Helix had the 48 kbps per channel artificial limit?
LAME: -f -V 0 -Y
 Xing: -V150 -X2 -U2 -HF-1 -TX0
Reply #624
Since the original authors haven't touched the code in over 20 years, we'll probably never know for sure. :)
