Topic: Hard discs: no error correction required? (Read 25016 times) previous topic - next topic
On p.31 of the book Mastering Audio: The Art and the Science (by Bob Katz; 2002 Focal Press; ISBN: 0240805453), the author notes: "Hard discs [...] generally do not require error-correction, since their error rates are extremely small." The book is geared toward the recording industry. How true is this comment for playback as well as recording?
What about error rates for flash-based memory devices? There is some "consensus" that, e.g., hard-drive-based PDAPs (portable digital-audio players) sound better than flash-based PDAPs. But I'm not sure the correlation/causation for Katz's argument, in its context, is relative here.
On a somewhat-related topic regarding PC-based audio, a friend and fellow audiophile/DIYers noted:
"What makes the huge difference is that by using the PC for volume control, I was able to remove the preamp completely, and that is where the CD player [i.e., external/stand-alone unit, as in a typical home-audio system, and not a PC-based ROM drive] loses the race.  It takes a few tricks to do volume control on the PC right, but once you do, you have no bit loss at the lower volume settings." See his system as well as more technical remarks here:
http://didnt.doit.wisc.edu/audio/DDDAC16/d...16usb_ASIO.html
http://didnt.doit.wisc.edu/audio/DDDAC16/dddac16usb.html
So, in conclusion:
Perhaps if media companies managed the DRM "issue(s)" better, and allowed consumers direct purchase of the digital master's "source code", we would all have some really high-quality stuff.
Hard drives do still require error correction, and all of them have it.
Woah, Hard disks, error correction, volume control on the PC and DRM in one thread.
Don't know if HDDs have error correction per se, but they do use coding schemes to store the data.
Where to begin?...
Many top end PCs / Laptops use just flash memory for speed, no hard disk, by your analogy they must sound worse than hard disk based pcs, makes no difference. If a system is working correctly - be that an iPod with Hard disc or iPod nano with flash, the audio data from the hard disk or flash is identical, errors only happen when something is not working correctly, for flash and hard disks that should be a rare occurance. Audio components close to a hard disc might suffer, as there is a metalic object spinning around.
When you format a hard disk, you are setting up a frame work to detect errors. It could be that some pro audio equipment formats a disk with little error correction, apart from a small % extra space, nothing is gained.
There is no difference between the two. Anyone who tells you that flash or disk choice has any impact on quality has no idea what they're talking about.
Hes just using the amp in the sound card instead of an external amplifier.  I don't see how this is an advantage or disadvantage for the PC.  Actually, that whole point doesn't make much sense at all.
And looking at his page, he seems to believe all that kmixer nonsense.  Was this the same guy who told you about flash and HD's?
Hard disks have very robust built in error correction and coding mechanisms. The chances of a hard drive reporting an incorrect value for a read bit (instead of not reading it at all) are extremely, extremely small. It happens, and upsets scientific computing people, but it doesn't happen often enough for it to have any effect what so ever on audio quality.
Hmm, no. If anything, flash based players should have cleaner power, and better sound quality - all other things being equal. If you mean "expensive" by "hard drive" and "cheap and cheerful" by "flash-based" then, yeah, flash based players are likely to suck, comparitively.
Yes: the latest flash-based memory should (theoretically) sound better. The reasons I think HD-based units may beat out flash players are as follows:
- HD players are (and have "traditionally" been) incorporated into any particular manuf's top-end model  (perhaps because of extra capacity). The top-end models may get extra "topological attention" WRT audio circuit design. For example: because HD-based PDAPs are usually larger, perhaps the designer can use (fit in) discrete electronic components -- which typically sound better -- rather than integrated circuits. I think this is along the line with your comment re "expensive" vs. "cheap".
- HD designs are still superior to flash (but the latter may soon catch up and supersede)
I assume you mean generic data EC (error-correction) -- via the OS and effective for all data I/O'ing thru the HD -- and not "audio-specific" EC, such as Reed–Solomon.
While I'm sure OS-based EC is quite robust, effective and efficient for most computer apps and processes, I'm wondering whether an ad hoc (audio- or music-specific) EC approach wouldn't work better.
...There is some "consensus" that, e.g., hard-drive-based PDAPs (portable digital-audio players) sound better than flash-based PDAPs...
That makes no sense at all!!!
You should do some research on Boolean Algebra and, then, you will understand.
Well, yes, it's built into the hard drive, though. It's not generally necessary to include any kind of error protection in the stored file.
Just back everything up.
J. D. (jj) Johnston
Do you mean in the firmware of the HD drive (in some native chip)? This makes sense on a meta level. I think the OS also does some error checking as the data I/O's the HD.
There are certain "Consumer Electronics" hard drives, used in PVR machines, that have little or no error correction to ensure smoother recording and playback.
http://www.xtendedplay.co.uk/faq.php#8
Edit: Segate CE drives have the suffix "ACE" or "SCE" in the model number.
http://www.seagate.com/www/en-us/products/...ics/db35_series
I'm on a horse.
Thanks for replying with references! I am partial to Seagate drives, due to personal experience with them, so I may experiment with the DB35 Series. A PDF (White paper) link on the page you ref'd above goes into some more details:
http://www.seagate.com/content/pdf/whitepa...45_DynaPlay.pdf
Specifically, the WP notes:
Improve stream integrity through time-limited commands
Uninterrupted, smooth video delivery is a fundamental customer expectation for any application recording television in the home. Hard drives designed for PC applications are optimized for data integrity through enhanced error detection and correction routines. Consumer video recording devices, however, need to be optimized for stream integrity to avoid problems caused by over-execution of error checking, which can cause problems in consumer video recording devices. The Seagate DB35 series drives offer time-limited commands, which allow manufacturers to adjust error detection and correction in favor of a consistent, smooth video stream. In the rare instance that an error in the video data is detected, the consumer would likely experience a virtually imperceptible drop of a video frame, but would continue to enjoy an uninterrupted stream of entertainment content.
Manufacturers can adjust time-limited commands to preferred specifications, using standard commands to define the drives’ timeout performance in error checking. Alternatively, Seagate can configure the drives’ time-limited commands settings before the drives ship. Seagate DB35 Series hard drives with time-limited commands capability support a wide range of OEM middleware, operating systems, motherboards and design standards.
Found this site that gives at least some basic descriptions of the error correction used in hard drives.
It seems to be pretty similar to CD's: Reed-Solomon error correction code is written with each sector by the hard drive firmware, and then read and computed on a read operation, and used for correction if necessary, again at the hard drive level.  Multiple reads (a la EAC  ) are done if needed, and if all goes well, the OS is never aware that any correction was necessary.
Error detection and correction is done by OS. Your OS will detect a corrupt file that it can't correct and let you know about it. Then you replace it from the back-up files you (wisely) kept stored somewhere else.
What the heck?  No they shouldn't.  Both will sound the same until one of them fails, at which point it will most likely not sound like much at all.
Boolean Algebra is anitiquated terminology. Not sure how that term came to be applied in the first place but it is more-correctly know as Boolean Arithmetic:
http://en.wikibooks.org/wiki/Practical_Ele...lean_Arithmetic
That link calls it boolean algebra.  Regardless, the point of bringing it up was to subtly remind you that we're talking about digital media.
Perhaps we should not call them flash but, more prosaically, "solid-state memory devices". In any event, some content from this source is what I had in mind -- as in this excerpt:
"[...] what's the benefit of a high-speed SSD when the entire system cannot support it? The evolution of CPUs in terms of performance has far surpassed the development of the data storage system. The HDD is actually limiting the potential of a computer system when they are not able to keep up with the performance of the other components, particularly the CPU. If an HDD is replaced by a high-speed SSD, the performance would significantly improve. The resulting system would be a high-powered set-up that can go beyond the demands of high-speed business or military environments."
BTW, the sonic difference(s) I am speculating exist between an optimial solid-sate device and an optimal HDD are not as great as, say, the diff. between (all things being equal) a Red Book CD and a DVD-Audio disc.
BTW, the sonic difference(s) I am speculating exist between an optimial solid-sate device and an optimal are not as great as, say, the diff. between (all things being equal) a Red Book CD and a DVD-Audio disc.
For me that would be <0    ...
... and all things would be equal.
Can't speak for others though.
Ken
BTW by "optimal" I assume you mean one that works (i.e. returns the stored values, reliably)
BTW, the sonic difference(s) I am speculating exist between an optimal solid-sate device and an optimal HDD are not as great as, say, the diff. between (all things being equal) a Red Book CD and a DVD-Audio disc.
As long as a storage medium is capable of reliably sending all the (audio) bits in time to the DA converter(s), it shouldn't have any influence on the sound.
Red Book CD and DVD-Audio don't contain necessarily the same audio format (samplerate and wordlength) so you can't compare them without being more specific.
Hard drives can be noisy. If solid-state devices don't need noisy cooling, they might be much quieter. That could be an interesting sonic difference.
Nope, AFAIK, this is done transparently by the HD/Controller. The OS will only get a "read error" from the controller if the HD fails to read or recover the sector. Defective sectors are silently remapped to "spare" positions on the disk, again without any intervention by the OS, though you can usually get some statistics by reading the HD's SMART data. This is all done below even the filesystem level, which is why you almost never see defective sectors in scandisk on modern drives. Reading the SMART data (Value "Reallocated Sector Count") will give you the real count.
I'm talking about standard consumer drives here. Also, it doesn't apply to old drives AFAIK.
More specifically, they have just as much error detection and correction *data* stored on the platters as the non-PVR targeted drives.
However, the firmware has been tweaked to prefer PVR-friendly realtime I/O strategy (A) over the more PC-friendly aggressive data-recovery strategy (B):
(A) PVR-friendly - When a read or write error is detected, abort the operation *quickly* and report an error to the caller, as the caller (presumably a streaming data recorder, such as a PVR) is expecting real time I/O capabilities and prefers to handle errors itself as a trade-off for fast response to disk I/O calls.
(B) PC-friendly - When a read or write error is detected, retry the read/write several times and more aggressively try to save marginally corrupted data by moving it to a spare sector.  While this can lead to the drive becoming unresponsive for a significantly longer period of time than in (A), the fact that your spreadsheet was read into memory AND the data was recovered from a marginally corrupted sector to a good sector was never noticed by you, which is a good thing.  Also, from time to time, run additional I/O-sapping calibration and correction routines so as to ensure the best error-correction capabilities are always available.
Summary: it's better to experience a 2-3 second glitch in playback of streaming data (presumably a stream type that allows quick re-lock onto the stream) than to have the screen freeze and the hard drive stutter for 30 seconds of clacking due to the delay from several re-calibrations trying to read (and perhaps re-map) several bad sectors found in a row...
-brendan
But when dealing with audio recording, IF this happens during recording, there is possibility that when using these "optimised" hard drives we couldn't be sure the reproduction will be flawless, because HDD would, in theory, write the data on possibly corrupted part of a drive, and just keep recording on, and later on there will be problems with reading the same exact data...?
I understand how it works with mpeg video streams, mpeg video has autocorecting algorythms inside the stream which will try to correct the badly read bits... but wavs don't have these, as I remember...
I feel that I am qualified to answer this one: I'm a Microsoft certified Tech with a decade and a half of experience in the industry.
1) Hard Disk Drive certainly do have error detection / correction
2) You can delay (any) hard disk drive from implementing it's write-back caching routine, thus data drop / lag, with OS settings.  We used to set up a lot of secondary SCSI drives this way to avoid frame-drops in video capture 'back in the day'.
3) If you [really] want to hear whether Hard Disk Drives 'sound different' than solid-state drives, simply copy a .FLAC or .WAV to a USB 2.0 thumb-drive and keep a copy on your hard disk drive.  Listen to them both, back and forth (drag and drop into WinAmp), as many times as you want... hear any difference?  No, neithor do I...
What an odd discussion thread...
Andrew D.
www.cdnav.com
That's why a lot of professionals still use Digital Reels.
