Converting all affected files would be waaay to much work...
i tried the ffmpeg decoder:
configured it to handle aac files:
and set it to top of decoder invoking order:
but no difference at all - is there anything else i need to do, or a way to check if it is using ffmpeg?
EDIT:
just opened the console - it says:
Launching ffprobe:
"D:\Program Files\ffmpeg\bin\ffprobe.exe" -of xml -show_format -show_streams -show_chapters -hide_banner "<...path...>\TroyBoi - No Substitute ft. Y.A.S (256 kbit_s).aac"
Launching ffmpeg:
"D:\Program Files\ffmpeg\bin\ffmpeg.exe" -i "<...path...>\TroyBoi - No Substitute ft. Y.A.S (256 kbit_s).aac" -map 0:0 -f w64 -acodec pcm_f32le -
so ffmpeg seems to be running.
i quickly ran the ffprobe command via cmd which outputs:
<?xml version="1.0" encoding="UTF-8"?>
<ffprobe>
[aac @ 000001536d1bcb80] Estimating duration from bitrate, this may be inaccurate
Input #0, aac, from '<...path...>\TroyBoi - No Substitute ft. Y.A.S (256 kbit_s).aac':
Duration: 00:04:03.79, bitrate: 246 kb/s
Stream #0:0: Audio: aac (LC), 44100 Hz, stereo, fltp, 246 kb/s
<streams>
<stream index="0" codec_name="aac" codec_long_name="AAC (Advanced Audio Coding)" profile="LC" codec_type="audio" codec_time_base="1/44100" codec_tag_string="[0][0][0][0]" codec_tag="0x0000" sample_fmt="fltp" sample_rate="44100" channels="2" channel_layout="stereo" bits_per_sample="0" r_frame_rate="0/0" avg_frame_rate="0/0" time_base="1/28224000" duration_ts="6880770114" duration="243.791458" bit_rate="246339">
<disposition default="0" dub="0" original="0" comment="0" lyrics="0" karaoke="0" forced="0" hearing_impaired="0" visual_impaired="0" clean_effects="0" attached_pic="0" timed_thumbnails="0"/>
</stream>
</streams>
<chapters>
</chapters>
<format filename="<...path...>\TroyBoi - No Substitute ft. Y.A.S (256 kbit_s).aac" nb_streams="1" nb_programs="0" format_name="aac" format_long_name="raw ADTS AAC (Advanced Audio Coding)" duration="243.791458" size="7506918" bit_rate="246339" probe_score="51"/>
</ffprobe>
which seems to be also contradicting statements to the other players info... "Duration: 00:04:03.79, bitrate: 246 kb/s", 'duration="243.791458" bit_rate="246339"'.
However foobar2000/the ffmpeg component seems to ignore these infos anyway, as it still displays a question mark and no seekbar.
