Ozok: When encoding from FLAC to Opus, there seem to be some tag-problems. "Track Number" and "Total Tracks" are forgotten + "Track Number" gets a new tag in the opus file, <TRACKNO>. Also, the "Composer"-field in the FLAC was blank, in the Opus file it gets filled with "Unknown". I'd rather have the Composer-tag blank than filled with "Unknown" Same thing happens Flac->Flachttps://ftp.mozilla.org/pub/mozilla.org/opus/win32/ Lame removes "Total Tracks". Also happens with QAAC, FAAC and OGG Vorbis MPC did not manage to encode 24/92 FLAC. (When i manually set bit-depth and sampling rate it works. Maybe it should automatically downsample files that MPC does not support?)[size="1"][10.02.2013 12:26:43] Started deleting temp files... [10.02.2013 12:26:43] Temp Folder: C:\Users\Olav\AppData\Local\Temp\TAudioConverter\ [10.02.2013 12:26:43] Deleted 1 file(s). [10.02.2013 12:26:43] Finished deleting temp files. [10.02.2013 12:26:43] Trying to detect bit depth: B6 - Year of tha Boomerang.flac [Depth is: 24] [10.02.2013 12:26:43Number of commands per process are as follows: [10.02.2013 12:26:43] Encoder1: 2 [10.02.2013 12:26:43] Encoder2: 0 [10.02.2013 12:26:43] Encoder3: 0 [10.02.2013 12:26:43] Encoder4: 0 [10.02.2013 12:26:43] Encoder5: 0 [10.02.2013 12:26:43] Encoder6: 0 [10.02.2013 12:26:43] Encoder7: 0 [10.02.2013 12:26:43] Encoder8: 0 -------------------------------------------- [10.02.2013 12:26:43] Starting encoding process [10.02.2013 12:26:43] Command lines: -y -i "C:\Users\Olav\Desktop\B6 - Year of tha Boomerang.flac" -threads 0 -vn -acodec pcm_s24le -f wav "C:\Users\Olav\AppData\Local\Temp\TAudioConverter\B6 - Year of tha Boomerang.wav" --quality 5.00 --unicode --artist "Rage Against The Machine" --album "Evil Empire" --tag "comment"="Music On Vinyl 180g LP" "C:\Users\Olav\AppData\Local\Temp\TAudioConverter\B6 - Year of tha Boomerang.wav" "C:\Users\Olav\Desktop\B6 - Year of tha Boomerang.mpc" -------------------------------------------- ----Encoding Summary---- -Number of processes: 2 -Copy tags: True -Extract artwork: False +Audio -Encoder: MPC -Quality: 5.00 -Bit Depth: Original +Effects -Disabled Temp: C:\Users\Olav\AppData\Local\Temp\TAudioConverter\ Output: C:\Users\Olav\Desktop\TAC(0.7.7.1045)(portable)\ ----Encoding Summary---- [10.02.2013 12:26:47] Cannot find output file C:\Users\Olav\Desktop\B6 - Year of tha Boomerang.mpc[/size] Flac->MPC forgets almost all the tags When encoding QAAC tvbr, TAudioConverter says TVBR 90 (for instance) is "TVBR 90 kbps", which is not true at all. Remove "kbps" from "TVBR: 90 kbps"? Flac->Alac removes "Comment" and "Total Tracks" In all samples i have not touched settings that has to do with tagging. It's stock v0.7.7
