Topic: Error Converting FSB to MP3 (Read 1047 times) previous topic - next topic
Hi
I'm still relatively new to foobar2000.
When converting some FSB files to MP3, I received an error message regarding a select number of them.
Here's an example:
Source: "C:\Users\user\Music\Transformers\Transformers - Fall of Cybertron\L01_01_MX_ON_THE_ARK_1.fsb" / index: 1
  An error occurred while writing to file (The encoder has terminated prematurely with code -1 (0xFFFFFFFF); please re-check parameters) : "C:\Users\user\Music\Transformers\Transformers - Fall of Cybertron\L01_01_MX_ON_THE_ARK_1.mp3"
  Additional information:
  Encoder stream format: 44100Hz / 6ch / 16bps
  Command line: "C:\Program Files (x86)\foobar2000\encoders\lame.exe" -S --noreplaygain -b 320 - "L01_01_MX_ON_THE_ARK_1.mp3"
  Working folder: C:\Users\user\Music\Transformers\Transformers - Fall of Cybertron\
  Conversion failed: The encoder has terminated prematurely with code -1 (0xFFFFFFFF); please re-check parameters
I was converting 150 FSB files, but only around 47 of them gave me this message.
Any solutions to this?
Thank you
Re: Error Converting FSB to MP3
Your source file has 6 channels. MP3 only supports stereo. Add "Downmix channels to stereo" DSP to your encoder preset.
I already had that specific DSP enabled and it still doesn't work.
There was nothing remotely different between those 47 FSB files and the other 103, so I don't know why they won't convert when they did.
You added it to the encoder preset? Because enabling a DSP for playback has no effect on conversion.
