I have read on forums of people who manage to rip badly scratched CD's with EAC but complain of time taken. My question is I would be happy to wait a long time if I could configure EAC to do it, but my configuration allows error correction to run through the five bars of lights before it just aborts the track as read errors.
I have access to many poor condition CD's how do I configure EAC to continuewith the rip without aborting after the run through the five bars- hope this makes sense.
If it's making it all the way through the 5 bars, the CD may simply be unrippable. Not everything is possible, you know.
Under EAC options (on the extraction pad), disable the checkbox that says something about "skip extraction on read or sync errors" ... ;-)
Actually, EAC is not especially good at scratched CDs. It is good at seing that they are scratched, what classic rippers can't do, not really at ripping them. When the five bars light up, it means that it's not going to perform a good job.
Try first to repair the scratches with brasso, or SkipDoctor (see the FAQ).
Never tried SkipDoctor, any good? I have found that Brasso works fairly well. Scratches that follow the circumference of the CD usually don't have much hope though. Had one like that recently (short TV tunes, so about 20 tracks were bad). I'd rub it down with Brasso, and maybe extract a random damaged track succesfully. Repeat, maybe get another one. Eventually got all but two over a couple days work. It's a good idea to try ripping after every Brasso application since you could always make the problem worse too. I've also found that occasionally ripping at full speed in Audiograbber can sometimes get a track with minimal popping noise, which can then possibly be fixed (found DeGlitch the other day, good free program). Working on my entire collection over the past few weeks has taught me a great deal about ripping with EAC and scratched CD's, that's for sure.
[a href="index.php?act=findpost&pid=235030"][{POST_SNAPBACK}][/a]
There's CDex using 'Paranoia, Full' as another resort. Of course if the drive caches audio CDex may not help much.
I ripped one of the lads Incubus albums today (I'm 53) and noticed that the last 2 tracks ripped with 15 errors each going through the 5 bars and continuiing to the next bad sector and then through the 5 bars again.
Now as I said each track ripped with about 10 - 15 errors in the log. The thing is when I played them back they seemed to play OK. That is with my dodgy ears, is it possible to rip, show that many errors and still sound OK. Or is it subjective and depending on listeners ears.
yes it is possible. I had loaned a friend Ozzy Osbourne's Live and Loud. Turns out that the cd somehow got under the vinyl flooring in his truck. Needless to say, it became quite scratched by the sand, dirt and general foot pressure there.
Anyways, tried ripping in an LG 8120b. This was a no go. But... My Hitatchi hd8500 DVDrom was able to extract it. It took more than 9 hours and the log was full of errors, but it still came out sounding perfect.
Never heard of using Brasso, but a friend of mine swears by TurtleWax for CD repair.
[a href="index.php?act=findpost&pid=235135"][{POST_SNAPBACK}][/a]
From my experience: if EAC goes through 5 bars but does it rather quickly, there are good chances the problematic spot is still listenable. (that is, you don't hear any errors). I had probably a couple of dozen cases like this, and in each case I coudn't hear anything.
However if you hear the drive starting and stopping on each try, the progress is very slow in general, I"m 100% positive this spot is unreadable. You may as well go ahead and cancel the process. About a dozen of cases like this. I've used to wait till it finishes but now I feel it's just a waste of time.
I have a badly scratched CD (Gamma Ray - Blast from the Past). To be more exact, the CD is alright except the the track 10 where there is an awful small but deep scratch and it can't be grabbed on almost every ripper I tried. I used EAC, CDex and many others and althought it sometimes grabbed the whole song, yes with errors, there were a long passages where there was no signal at all. The last choice I made was an AudioGrabber with dynamic sync width and it grabbed the whole song with introduced errors but there's signal even in the worst passages. It can be listened when you don't point at details. I still have no opportunity to try CD doctors or stuff like that.
Basically if a scratch is bad enough that it can't be read, the data has been destroyed and no program no matter how good can recover the data. If i ever get a track like that, I loan another copy off a friend or rent it from the library and take a clean rip from there. If its a very rare cd then theres not much i can do.
I usually try cleaning the cd with toothpaste on any scratches but if the scratch is on the label side of the disc there is no hope.
I wish i had known how fragile cd's actually are, back when my oldest cd's were just left lying around.
To lower the number of "re read" bars to one go to
EAC options, extraction tab, then error recovery quality and set it too low.
This will speed up extraction on badly scratched CDs, hopefully
PLease correct me if im wrong
I'm not trying to scare-monger or anything, but I killed my old DVD writer (HP DVD100i) by leaving it ripping a badly damaged CD overnight. Since I did that, it took my drive about a minute to access a CD, and it couldn't read much without having read errors.
Just a warning, I know the HP 100i wasn't exactly a great drive (!), but I wouldn't risk damaging my new drive just to rip a scratched CD.
Ed
[{POST_SNAPBACK}][/a] (http://index.php?act=findpost&pid=235167")
Brasso works great as a polish. Also does a good job of cleaning the CD too since it contains petrolium distilate. Check out these two sites:
[a href="http://www.burningissues.net/how_to/scratchrepair/scratchrepair.htm]http://www.burningissues.net/how_to/scratc...ratchrepair.htm[/url]
http://www.mcgee-flutes.com/scratches.html (http://www.mcgee-flutes.com/scratches.html)
Want to hear something crazy I tried tonight? I have four CD's that have a few tracks that can't be read, and I've tried everything. So I went to the store and picked up some 2000 grit sandpaper (from the automotive section of Canadian Tire) and Turtle Wax Rubbing Compound. I sanded the worst of the CD's with a bit of water and the sandpaper, cleaned it with water, rubbed the thing down real good with some rubbing compound and paper towel, cleaned with water again, then rubbed it down three times with Brasso and a soft cloth, buffing with a soft fleece cloth. I was a bit worried, since the CD was looking a bit like frosted glass when held up to the light, lol. But it ripped perfectly with EAC, and there were ZERO errors. I was amazed. Just finished listening to the offending tracks and they are flawless. And all these things were cheap to buy.
To all: If you try this, use caution and don't blame me if something goes wrong. Make sure your desparate enough, and make sure to get as many tracks off the album to a lossless format as possible first.
Brasso is OK but takes a lot of work & won't get every CD extracted without errors. The best way is fine sand paper & then possibly brasso for the thinest pass. I personal haven't been able to find more than 2200 grit sand paper so I am stuck with brasso for now.
There are products made specifically for repairing scratches in plastic. I recently purchased a Micro-Mesh KR-70 restoration kit and used it to fix a scratch in the display window of my Nomad Jukebox. It contains several grades of sandpaper, down to 6000 grit, a foam backing block, a bottle of polish, and instructions. I see it most frequently where supplies for private pilots and aircraft are sold. Its used to fix scratches in airplane windows. Expect to pay about $20. One kit would be enough for many CDs.
I just tried it on a CD that had a moderately bad scratch. A few nights ago I was working on another problem with this CD with the following results.
I was able to rip it to MP3 files with Plextools and my Plexwriter Premium. No errors but it took longer than normal.
I then tried to make an image file and cue file with EAC. About 60% though the disc EAC slowed down to where it took a minute or two for each 0.1%. I finally canceled it.
I was able to make a copy with Plextools again taking longer than normal to read but no errors reported.
Tonite I scanned the disk for errors with Plextools before doing anything to it and again at different stages of sanding and polishing.
In the original condition
C1 C2 CU
Avg/sec 142.2 126.6 0.0
Max/sec 277.0 850.0 0.0
Total 27394.0 379928.0 0.0
After sanding with 3600 then 4000 grit
C1 C2 CU
Avg/sec 144.1 15.4 4.5
Max/sec 378.0 481.0 267.0
Total 433353.0 46229.0 13501.0
After sanding with 6000
C1 C2 CU
Avg/sec 265.9 22.4 81.2
Max/sec 483.0 342.0 659.0
Total 499021.0 67320.0 244537.0
After polishing
C1 C2 CU
Avg/sec 122.6 0.1 0.0
Max/sec 232.0 51.0 0.0
Total 368630.0 280.0 0.0
(Is there a better way to make a table than a code block??)
After the polishing I was able to make an image file with EAC. It took 5:50 and reported no errors.
Two more notes
If I look at the disk it is obvious I could do a better job with practice. There are still scratches visible from the sanding steps.
This disk is from the 80s. Other disks I have scanned have as many errors as this one has after the sanding and polishing
[a href="index.php?act=findpost&pid=236499"][{POST_SNAPBACK}][/a]
The good thing about that approach is "it may not stress the drive as much."
The bad thing about that approach is if EAC is configured to give up so early in error correction you'll never know if it is possible to get an error-free copy on a scratched CD, and subsequently and/or possibly end up with a stack of un-ripped CDs that may have been rippable without audible errors.
After the polishing I was able to make an image file with EAC. It took 5:50 and reported no errors.[a href="index.php?act=findpost&pid=237803"][{POST_SNAPBACK}][/a]
Strange, according to your table, the more you polish it, the more you get errors.
While Brasso is pretty good, I agree it's still far from perfect. It's only good for light scratches really, and even then there is no guarantee. The stuff is cheap though, and definitely better than toothpaste, lol.
Sanding is probably the only way to really deal with scratches properly, especially deep ones. The kit that bobwood mentions sounds intruiging. The CD I did last night still looks a bit frosted, and I wish I could do a better job of polishing the sanding marks out. 2000 grit was the finest paper I could find, though I'm going to hunt around tomorrow to see if I can find anything finer since the rubbing compound simply isn't enough.
Depsite not looking so great to the eye, I was able to play the CD without errors in several devices, including a really old Technics CD player that is really finicky when it comes to scratches. Only the very end of the last track skipped a bit. Before treatment the CD was totally unplayable in that player.
[a href="index.php?act=findpost&pid=237836"][{POST_SNAPBACK}][/a]
Thats because in my multiple attempts to get the columns of my table alligned, I managed to leave out the numbers for the polished scan. I have corrected the post.
Sanding is probably the only way to really deal with scratches properly, especially deep ones. The kit that bobwood mentions sounds intruiging. The CD I did last night still looks a bit frosted, and I wish I could do a better job of polishing the sanding marks out. 2000 grit was the finest paper I could find..
[a href="index.php?act=findpost&pid=237894"][{POST_SNAPBACK}][/a]
Hi. This is what works for me. I found 2500 grit at a car refinishing place. It was emery paper and was perfect for wet sanding. To buff out the milkiness that this grit leaves I use a piece of felt.
Still, 2000 with buffing should make it redable by a computer drive. Try the felt and remember to wet sand
EAC is useful for telling you when a disc needs resurfacing or for correcting mild scratches for sure,but there are limits to what it can do.
PS FWIW I have wet sanded well over 100 cd's anyway and have never wrecked a cd in such a way that it could not be easily ripped, although the residual milkiness post buffing messed up in my car player a few times. You can always rip and burn an image if this happens
Hehe, the second CD didn't go too well. I actually managed to make it unreadable using wet sanding and buffing. So I phoned around and discovered a local game rental store that has an industrial CD resurfacing machine. I figured what the heck and took all four down. I made a real mess of that one CD too, just for the heck of it (I had already made it unreadable after all). I was blown away when I got them back the next day. They looked like brand new and ripped flawlessly! So if your desperate and don't mind spending the cash ($4.99 CDN per CD here) this is definitely a great solution. Still a little bit on the expensive side, but if you factor in the final quality and especially your time (in my case trying to track down finer grit sandapers), I'd say it's money well spent.
[a href="index.php?act=findpost&pid=237784"][{POST_SNAPBACK}][/a]
I just learned that lesson the hard way.
If anyone should get the idea to experiment with different household chemicals, avoid nail polish remover. In my attempt to remove a minor scratch, I destroyed the entire CD.
Try to use different drive if you can (possibly on the friend's computer). CD drives are not same in terms of extraction quality. I have CD's unrippabble without errors on ones, and perfecty on others.
but is there a free software that let me correct glitches outside eac
This post is old, so not sure if I should start a new one now, but I'm wondering if anyone has experience extracting badly scratched CDs with Plextools, rather than EAC.
I've done almost 300 discs with EAC now, and I know, based on the logs, which ones are scratched enough to be very likely to have errors. Some of these CDs literally had to be ripped over a period of many DAYS!
I've played with plextools before, but i'm not sure if I can do image extraction with cuesheets in the same way EAC can. I actually do own a CD-Resurfacing machine (this one is a bit like an industrial polisher, you use wax with a couple of buffing and polishing wheels).
Unfortunately, the vast majority of the bad CDs I have have been DJed with for many years, and have holes and pitting in the topside foil layer. I can still rip them, and most of them sound okay, but there are a few that are particularly bad after extracted.
I'd buy new copies of these CDs if I could, but apparently they are very rare now!
I am actually willing to purchase a new CD-Rom drive that would be optimal for this... suggestions? Plextor Premiums, or their newest DVD-Writers seem to do well.
Any advice on software alternatives to EAC for extremely scratched CDs would be much appreciated.
[a href="index.php?act=findpost&pid=284318"][{POST_SNAPBACK}][/a]
Have you tried Burst Mode? Its better for scratched CDs then Secure mode, but I suggest you use Shift+F6 for test and rip + AccurateRip (if your disk is in the database). If you get 2 matching CRCs your rip is accurate. I use secure mode to identify CDs with difficulty ripping then burst mode to get good rips.
Eli: Okay... I know that on occasion, burst mode can work better for some CDs. I think that the ones I've got now are way beyond that, though.
There is pitting in the topside foil on a lot of my CDs. (I have no idea what caused this, other than general abuse).
I've tried Plextools, but using the highest form of error correction, it is extremely, extremely slow. The second highest is more reasonable. So far its results haven't been a whole lot better than EAC, but it can be faster, and produces more accurate logs. (Accurate to the point of being extremely difficult to review. Every single try on every error on every frame is logged... that means that some of PlexTools' logs are hundreds of kilobytes in length.)
I've read about Feurio, but so far, not much difference. It's faster, but I don't know if there are really any advantages of it over EAC burst mode... and I've also heard of BlindRead, which I haven't yet tried.
edit: spelling
In my experiene the error correction rarely/never can overcome certain errors. If they are as bad as you say and even your prof cd repair cant fix it I think the only solution is to look for someone else with the CDs
I've got an old Art of Noise CD that's in such bad shape that the only thing I could find that could do a decent job of reading it is my Panasonic SL-SW860 with it's anti-skip on. My LTR-52327S and EAC can read some of the tracks ok, but most slow secure mode to a virtual stand-still and/or have terrible glitches in burst mode. I ended up just recording the line-out from the 860 onto my SBLive with Audacity which worked pretty well.
Interesting idea, to use an actual stereo audio CD player, but not exactly an idea solution. Recording in analogue... ugh.
You know what? I've actually gone through three copies of some of these CDs already. It's a big set, and many of the oldest CDs are very, very hard to find now because they have been discontinued. (Although I did buy the ones I could). They are compilations intended for DJs, so probably almost every one in existence has been used and abused likewise.
Maybe I need to find a DJ that was all excited, and bought this CD set, and then never bothered to find any work. Sometimes I can get lucky, and I'll have early track on one CD that is damaged, and a latter track on another CD that is damaged. Then I can use CoolEdit and stitch the two files together to make a kind of frankenstein CD image.
In theory, this should be identical to the original, because I specified the exact sample to cut from, and such. I felt like an amateur neurosurgeon
[a href="index.php?act=findpost&pid=285606"][{POST_SNAPBACK}][/a]
You can always find a CD resurfacing place if it's rare and you can't rebuy it. Repairing (~$4-$5) would definitely be cheaper than rebuying anyway.
I totally intend to do this with my old "The Greatest Hits of Hance" compilation from '92. Definitely can't get it anymore and, oh, the nostalgia of my first CD. And did they ever know how to pick 'em...still sounds fresh today.
<img>
[a href="index.php?act=findpost&pid=285354"][{POST_SNAPBACK}][/a]
Man...the graphic hadn't loaded on that when I wrote my reply above. How on earth can anything read it at all? It looks like the actual data layer has a jillion holes in it...nothing can repair that.
A little OT, but virtually my entire cd collection is scratch free. For the past few years, I've learned to buy a cd - rip to flac - then put it back in its case and never need to use it again. Ill just burn a copy from the cue sheets if i want to listen elsewhere.
[a href="index.php?act=findpost&pid=285616"][{POST_SNAPBACK}][/a]
i think most of us do this now (i actually perfer wavpack, but the general idea still), the problem is that weren't so wise from the start, and now our older (and generally rarer) cd's are damaged beyond repair. if i only knew about ha 5 years ago....
[a href="index.php?act=findpost&pid=285611"][{POST_SNAPBACK}][/a]
That poor disk appears to have been through hell and back, both sides were equally scratched, and of course the scratches on the label side caused permanent damage to the data. After an extensive resurfacing with a "disk doctor" type tool I got the bottom of the disk half-way ok, and between the 40 seconds of buffering and the CD players seemingly
very effective error correction it was able to play just fine. If I run a C1/C2 error scan on my computer it'll abort with an error.
That poor disk appears to have been through hell and back, both sides were equally scratched, and of course the scratches on the label side caused permanent damage to the data. After an extensive resurfacing with a "disk doctor" type tool I got the bottom of the disk half-way ok, and between the 40 seconds of buffering and the CD players seemingly very effective error correction it was able to play just fine. If I run a C1/C2 error scan on my computer it'll abort with an error.
[a href="index.php?act=findpost&pid=285622"][{POST_SNAPBACK}][/a]
Now THAT is exceptional glitch removal.
I'm amazed if anything is able to play it without skipping all over, let along without glitches. Anyways, PFS, I actually OWN an industrial CD resurfacing machine. It's probably not the best one in existence, a bit like a motorized bench-polisher for plastics, but it does a pretty good job at removing scratches from the play surface.
Unfortunately, when I bought the machine (for this daunting job), I couldn't see how much of the damage was on the label side. It's nowhere NEAR as bad as that Art of Noise CD, but the same idea.
It's really strange though... you can tell after polishing the play side, that the remaining bumps and scratches are on the data side of the disk. But you can't actually see scratches to the outside of the label. It's almost like the scratches are from the inside out.
DJs often subject their discs to temperature extremes (up here in the great white north, especially). Could freezing, or heating repeatedly affect a CD in such a fashion? Or is it probably just damage from being handled?
