Bug: plugins need to be rebased
2008-05-08 01:46:23
Hello, First let me say that I very much enjoy your product.Module Name Size Mapping Timestamp Working set (p) Base address Image base address -------------------------------------------------------------------------------------------------------------------------- shared.dll 0x2A000 Image 4/19/2008 10:28 AM 20 K 0x10000000 0x10000000 foo_albumlist.dll 0x65000 Image 4/19/2008 10:29 AM 360 K 0xC20000 0x10000000 foo_cdda.dll 0x38000 Image 4/19/2008 10:29 AM 192 K 0xCE0000 0x10000000 foo_converter.dll 0x67000 Image 4/19/2008 10:29 AM 340 K 0xE50000 0x10000000 foo_dsp_std.dll 0x46000 Image 4/19/2008 10:29 AM 224 K 0xED0000 0x10000000 foo_input_std.dll 0x128000 Image 4/19/2008 10:29 AM 972 K 0x1E50000 0x10000000 foo_rgscan.dll 0x5A000 Image 4/19/2008 10:29 AM 316 K 0x1F80000 0x10000000 foo_ui_std.dll 0xD3000 Image 4/19/2008 10:29 AM 708 K 0x21B0000 0x10000000 The above poorly formatted table shows some of the DLLs that are loaded into the foobar2000.exe address space on my machine. It was obtained with Sysinternals Process Explorer. You will notice that in the image base address column, all are linked with a base address of 0x10000000, the default value. We then see that only one of the listed DLLs has an actual base address in foobar2000.exe's address space of 0x10000000, since only one of these DLLs can occupy this location in the process's address space. At load time if the image base address of a DLL is occupied already, the loader must re-base the DLL on the fly, rewriting all the jumps in the code segment to be relative to a new (empty) position in the virtual address space of the process. You can decrease the startup time of your application by pre-rebasing the DLLs yourself following Microsoft guidelines for choosing the base address of your modules, rather than using 0x10000000 for everything. Certainly you will have no control over 3rd party plugins which are loaded in-process but perhaps you can leave 0x10000000 open for them also. Here is an article http://msdn.microsoft.com/en-us/library/ms810432.aspx going into some more detail. Perhaps if the next version of foobar2000 has rebased DLLs the entire world combined will save a kWh per year in energy by not doing the extra math every time foobar2000 loads! Many thanks.
