Topic: foo_convolve - Impulse response convolver (Read 333096 times) previous topic - next topic
Re: foo_convolve - Impulse response convolver
Reply #150
Great plug Garf.  Is it a zero-latency design?  If no, is the clean audio path (Mix Adjust = 0%) latency compensated?  There is strong phase issue with my own impulses for (say) Mix = 50% (it's possible they need editing).
BTW, I'd also love it if I could use different impulses for each sample rate (in my case it's for headphone or room corrections).
Author of -Wavpack4Wavelab- and -CheckWavpackFiles-
Reply #151
I have downloaded the Convolver component, with the hopes of auditioning some IR guitar cabs, but I have no idea how to use it. It appears to be installed but I can't find any mention of it apart from the under the "Installed Components" window. Can anyone help me please?
Reply #152
Preferences > DSP > right panel > double clic
Reply #154
aliendough:  You might want to try the newer foo_dsp_convolver available here:  https://hydrogenaud.io/index.php/topic,85107.0.html
Has improvements over the other one and the settings are easily handled like most Foobar DSP's, i.e. add to the "Active" DSP component list and click the "..." button.
Reply #155
I tried to download the convolver plugin, but I don' t know how to inastall it. It appears in the list of componets but it is dark and I can't see Dsp in the list to the left.
Can anybody help me ?
Reply #156
Are you talking about foo_dsp_convolver as I linked to above?  Once you have downloaded foo_dsp_convolver.fb2k-component, go to your "Components" window in Foobar preferences, hit the "Install" button, and select the file.  Then "Apply" to restart.  Same as other standard components.  Then it will show up as "Convolver (gapless)" in your Available DSPs list.
Reply #157
I was talking of the standerd plugin. I have now succeded in installing it.
Reply #158
After installing the Convolver component & setting is as an active DSP, I am not hearing any difference.
Should I define an impulse file ?
If yes, which one & where can I get it ?
Should I also change the level adjust to something different than 0.0 dB ?
Reply #160
How does one route channels to and from the convolver.
For instance for Virtual Surround, each of the five audio channels (5.1  6 channel file) needs an IR for each ear, and all of them need to be mixed together for binaural 2 ch. output.
I would imagine there would be similar routing requirements for crossover type applications.
Reply #161
This convolver cannot process multichannel at all.
Reply #162
I've just started using this plugin with the impulse file from AutoEQ for my HD600. The results are very impressive. I'm not sure how this plugin hasn't been on my radar earlier.
Reply #165
There is a 64-bit version of the stereo convolution dsp compiled by Case here: https://foobar.hyv.fi/?view=foo_dsp_stereoconv
I use that one too, but I need this one for EQ. The other one has a crossfeed effect (depending on the impulses you put in). Can the Stereo Convolver be used for EQ?
Reply #166
I had some time to test - foo_dsp_stereoconv gives much different results from foo_convolve, even when using the same impulses and volume-matched. From the looks of it, using mono impulses meant for EQ with the Stereo Convolver makes the music entirely mono.
Reply #167
@Cannonaire , I am using MConvolutionEZ from MeldaProduction (free package available). In my opinion this is one of the best convolver today. Ver 15 is also for 32bit OS, while Ver 16 is only 64bit.
Reply #168
The only best convolver is afir filter in FFmpeg. Anything else is crap.
Reply #169
Is that a component for foobar? If so, please link it if you can. I would love to try it. I need whatever I end up using to be a DSP in foobar.
Reply #170
MConvolutionEZ is a VST plugin;  the Foobar vst3 host you need to run it with is of course an actual dsp;  I don't know if that matches what you're looking for, but it would extend your effect possibilities endlessly.
Reply #171
I will look into using the VST host. I haven't used them before, but it's likely I'll need to use it to replace a different component I use anyway. Thank you!
I'm still wondering though - Peter seems to have updated all of his other components for v2.0/x64. Did he abandon this one? It seems like a Convolver would be a basic function for EQ in a player as versatile as foobar.
