Topic: Feature suggestion: add conversion result to playlist (Read 3310 times) previous topic - next topic
This option would make the result files readily available in the same playlist.  One example is the encoder in Adobe Premierie.
Enable the "Show output tracks when done" option in the converter progress dialog.
Once the process is finished, a window with the converted files appears.
From there, you can drag the created files to the playlist, or directly do whatever you intended to do with them.
Edit: Note that 0.9.5 shows a window inside of foobar2000 that is similar to the playlist view, while previous versions would open an Explorer window.
Will try 0.9.5 when it's released.
Could we have an option to add it back to the original playlist?  I do conversion a lot and this would really help.
