A direct copy&paste from Shy's post on the Musepack forum:
Musepack SV8 has been finalized and the first stable release is out. The new stream version offers many improvements over SV7, to users and application developers alike.
Changes:
- Container-independent format. An SV8 MPC is a container file for a Musepack stream. Raw stream encoding is possible.
- Packetized stream allows muxing into audio and video containers (e.g. MKA, MKV, NUT)
- Sample-accurate, fast seeking independent of file length
- Sample-accurate cutting
- Chapters
- No internal clipping. --noxlevel flag removed, not needed anymore
- Bitstream compressed by highly optimized canonical huffman tables - 2% smaller files and faster decoding
- Streamable
- Cleaned up and rearranged code - libmpcdec, libmpcenc, libmpcpsy
Package contents:
mpcenc - Musepack SV8 encoder. Accepts WAV and lossless source files.
mpcdec - Musepack SV8 decoder. Decodes MPC to WAV or checks for stream errors.
mpcgain - ReplayGain calculator using our new ReplayGain library.
mpcchap - SV8 chapter editor, for embedding chapters into MPC files using info in chapterfile.ini or cue files.
mpccut - SV8 stream cutter, for losslessly cutting stream segments based on selected start/end samples.
mpc2sv8 1.0.0 - Musepack SV7 to SV8 converter. Losslessly converts MPC files encoded by an SV7 encoder.
SV8 specification (http://trac.musepack.net/trac/wiki/SV8Specification)
Special thanks to:
Nicolas Botti, the main person behind SV8 development, for a massive amount of work during a period of several years.
Peter Pawlowski, for important performance and stability related contributions.
grimmel, for SVN and Trac maintenance and hosting.
Genju, for non-stop binary compilations, testing and support.
Igor Janos / MONOGRAM, for SV8 DirectShow decoder and splitter development, and support.
Andree Buschmann, for code optimizations through his Rockbox efforts,
and everyone who contributed patches, offered advice and helped make the format stable and robust.
Download:
Windows package (http://files.musepack.net/windows/musepack_windows_2009-02-26.zip)
Linux package (http://files.musepack.net/linux/musepack_linux_2009_02_28.tar.gz)
Source code (http://files.musepack.net/source/musepack_src_r435.tar.gz)
Windows users can use the latest foobar2000 (http://www.foobar2000.org/) which already fully supports SV8's features.
While SV8 outperforms SV7, it's not yet as widely supported, as it is newly released. If you have SV7 files, make sure your application/s supports the new version before converting to SV8 and deleting SV7 files.
THANK YOU!
Quite nice to see SV8 hit finalization. Hopefully this will get some people to put the SV8 support to replace their SV7 support.
I have absolutely nothing of import to add except my exhilaration to hear that my most beloved of lossy formats has finally overcome the SV7 barrier. Great work, guys!
awesome!
Good work guys.
I want to add support for Musepack in NUT to FFmpeg. Is there a 16-bit wFormatTag for MPC8 or does it need to use a FOURCC?
Nice!
Just a small glitch: mpccut.exe goes into infinite loop when mpc file has broken frames. (It was a file converted from a broken SV7 file).
QUESTION: there is no publicly available tool to recover SV7 files with broken frames, is there?
(I mean recover = trying to re-sync and continue decoding past the broken frame). Could it be put on a wishlist please?
Great news! Seeking through hour-long funeral doom tracks will be possible now
It's great to see improvement on an excellent codec.
To kdo:
1. To put it bluntly, we're not touching SV7 anymore. One reason SV8 was born is SV7's failure to deal with such errors. Sorry, it's also not easy at all to do from my understanding of SV7.
2. I reproduced your mpccut bug. We'll fix it ASAP
Congratulations to Musepack, Seed, and other developers who have worked ceaselessly on this project. This is a cause for celebration!
When I first joined this forum, SV8 was already a dream for some... today, it has become reality.
time to update http://wiki.hydrogenaudio.org/index.php?title=Musepack (http://wiki.hydrogenaudio.org/index.php?title=Musepack)
when development of SV8 began?
Great news!
Congratulations to Nicolas and everyone who contributed!
Hi dev
Frank Klemm's SV8 code had to be discarded. r2d and Lefungus began working on SV8 in the summer of 2005
Hi dev
... long development
technical / quality - what new is in SV8, it`s lame quastion, i know, but from what i read musepack is a bit restricted technicly comparing to vorbis but on the other hand i see that there is no pre-echo in musepack and that many people are very fond of it, what i like to know where is the truth in referance to quality comparing latest musepack and ogg vorbis
thx
Rockbox 3.2 will be out in late March. Can SV8 make it?
I don't think anyone is working on merging it right now, so probably not unless some steps in to do it.
dev:
Regarding quality, Vorbis is better than MPC at 128 kbps, IMO. As you go higher than 160 kbps I think most ears won't tell between the 2. At 200 kbps, MPC, AAC and Vorbis are basically the same for most untrained ears. The trained ears can find flaws in all 3. As always, "mpcenc.exe --insane" produces excellent results.
Mike Giacomelli:
Regarding RockBox, there have been talks in the last 2 days. I am not an RB dev so I'm not making any statements. There is at least one RockBox developer who knows how to do it (and he created the MPC format) When time allows, an RB dev *will* pick it up. I can't tell when
Regarding RockBox, there have been talks in the last 2 days. I am not an RB dev so I'm not making any statements. There is at least one RockBox developer who knows how to do it (and he created the MPC format) smile.gif When time allows, an RB dev *will* pick it up. I can't tell when
Considering that the freeze for 3.2 is probably going to happen in about a week, I don't see it making it into 3.2.
EDIT: Shortened quote, added info for clarity.
Shy, Mike and I talked on IRC yesterday. I have turned to some devs and we'll see how quick it'll be. Anyway, the SVN builds of RockBox have been very stable for me regarding SV7 playback. I've been using RockBox for a long time. No need to rush things for 3.2
I am so happy! Go Musepack!
Building instructions for the source code would be nice.
Theres instructions with the tar. And anyway, since there is a unix configure script and an MS Visual Studio project file, the build process is pretty self explanatory, whatever your platform . . .
Mike: I can't find any instructions in the tarball (musepack_src_r435.tar.gz). There's no configure script either (only a configure.in, no install.sh, autoconf craps out). There are CMake files but the list of dependencies for Musepack to build isn't clear.
My mistake. I was reading the readme, but you're right, it appears to be wrong.
Too bad, coz I believe Rockbox is one of the major Musepack user groups.
There's someone working on porting SV8 to RockBox and they are getting all the help we can give. Please be patient
Great work!
Anyway, a small bug: mpccut and mpc2sv8 crash if the destination path is incorrect, like c:\c:\x.mpc.
Is possible to batch convert SV7 -> SV8 with foobar2000, Like replace a playlist of mpc files in their original folders?
in_mpc_0.99g don't work.
r2d's plugin (http://r2d.musepack.net/files/musepack_bin_20071201.zip) from the end of 2007 still works
It's not recommended to overwrite all SV7 files since one might be broken and you won't notice the error message during conversion. To convert to another folder use this .bat (http://files.musepack.net/windows/mpc2sv8bat.zip)
I'll tinker with a new plugin if I can find the time (which unfortunately is in short supply)
I created a configure script OK with
[!--sizeo:2--][span style=\"font-size:10pt;line-height:100%\"][!--/sizeo--]make -f Makefile.cvs[/size] then ran
[!--sizeo:2--][span style=\"font-size:10pt;line-height:100%\"][!--/sizeo--]./configure[/size] fine but
[!--sizeo:2--][span style=\"font-size:10pt;line-height:100%\"][!--/sizeo--]make[/size] fails....
myself@hostbox:~/source/musepack_src_r435$ make -f Makefile.cvs
autoreconf -vif
autoreconf2.50: Entering directory `.'
autoreconf2.50: configure.in: not using Gettext
autoreconf2.50: running: aclocal --force
autoreconf2.50: configure.in: tracing
autoreconf2.50: configure.in: creating directory config
autoreconf2.50: running: libtoolize --install --copy --force
libtoolize: putting auxiliary files in AC_CONFIG_AUX_DIR, `config'.
libtoolize: copying file `config/config.guess'
libtoolize: copying file `config/config.sub'
libtoolize: copying file `config/install-sh'
libtoolize: copying file `config/ltmain.sh'
libtoolize: Consider adding `AC_CONFIG_MACRO_DIR([m4])' to configure.in and
libtoolize: rerunning libtoolize, to keep the correct libtool macros in-tree.
libtoolize: Consider adding `-I m4' to ACLOCAL_AMFLAGS in Makefile.am.
autoreconf2.50: running: /usr/bin/autoconf --force
autoreconf2.50: running: /usr/bin/autoheader --force
autoreconf2.50: running: automake --add-missing --copy --force-missing
configure.in:5: installing `config/missing'
libmpcdec/Makefile.am: installing `config/depcomp'
autoreconf2.50: Leaving directory `.'
myself@hostbox:~/source/musepack_src_r435$ ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking for /usr/bin/ld option to reload object files... -r
checking how to recognize dependent libraries... pass_all
checking for ar... ar
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking replaygain/gain_analysis.h usability... no
checking replaygain/gain_analysis.h presence... no
checking for replaygain/gain_analysis.h... no
checking host system type... (cached) i686-pc-linux-gnu
configure: creating ./config.status
config.status: creating Makefile
config.status: creating include/Makefile
config.status: creating libmpcdec/Makefile
config.status: creating libmpcenc/Makefile
config.status: creating libmpcpsy/Makefile
config.status: creating libwavformat/Makefile
config.status: creating mpc2sv8/Makefile
config.status: creating mpcchap/Makefile
config.status: creating mpccut/Makefile
config.status: creating mpcdec/Makefile
config.status: creating mpcenc/Makefile
config.status: creating mpcgain/Makefile
config.status: creating wavcmp/Makefile
config.status: creating include/config.h
config.status: executing depfiles commands
config.status: executing libtool commands
Making all in include
make[1]: Entering directory `/home/myself/source/musepack_src_r435/include'
make all-am
make[2]: Entering directory `/home/myself/source/musepack_src_r435/include'
make[2]: Nothing to be done for `all-am'.
make[2]: Leaving directory `/home/myself/source/musepack_src_r435/include'
make[1]: Leaving directory `/home/myself/source/musepack_src_r435/include'
Making all in libmpcdec
make[1]: Entering directory `/home/myself/source/musepack_src_r435/libmpcdec'
/bin/bash ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT huffman.lo -MD -MP -MF .deps/huffman.Tpo -c -o huffman.lo huffman.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT huffman.lo -MD -MP -MF .deps/huffman.Tpo -c huffman.c -fPIC -DPIC -o .libs/huffman.o
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT huffman.lo -MD -MP -MF .deps/huffman.Tpo -c huffman.c -o huffman.o >/dev/null 2>&1
mv -f .deps/huffman.Tpo .deps/huffman.Plo
/bin/bash ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT mpc_decoder.lo -MD -MP -MF .deps/mpc_decoder.Tpo -c -o mpc_decoder.lo mpc_decoder.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT mpc_decoder.lo -MD -MP -MF .deps/mpc_decoder.Tpo -c mpc_decoder.c -fPIC -DPIC -o .libs/mpc_decoder.o
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT mpc_decoder.lo -MD -MP -MF .deps/mpc_decoder.Tpo -c mpc_decoder.c -o mpc_decoder.o >/dev/null 2>&1
mv -f .deps/mpc_decoder.Tpo .deps/mpc_decoder.Plo
/bin/bash ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT mpc_reader.lo -MD -MP -MF .deps/mpc_reader.Tpo -c -o mpc_reader.lo mpc_reader.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT mpc_reader.lo -MD -MP -MF .deps/mpc_reader.Tpo -c mpc_reader.c -fPIC -DPIC -o .libs/mpc_reader.o
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT mpc_reader.lo -MD -MP -MF .deps/mpc_reader.Tpo -c mpc_reader.c -o mpc_reader.o >/dev/null 2>&1
mv -f .deps/mpc_reader.Tpo .deps/mpc_reader.Plo
/bin/bash ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT requant.lo -MD -MP -MF .deps/requant.Tpo -c -o requant.lo requant.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT requant.lo -MD -MP -MF .deps/requant.Tpo -c requant.c -fPIC -DPIC -o .libs/requant.o
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT requant.lo -MD -MP -MF .deps/requant.Tpo -c requant.c -o requant.o >/dev/null 2>&1
mv -f .deps/requant.Tpo .deps/requant.Plo
/bin/bash ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT streaminfo.lo -MD -MP -MF .deps/streaminfo.Tpo -c -o streaminfo.lo streaminfo.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT streaminfo.lo -MD -MP -MF .deps/streaminfo.Tpo -c streaminfo.c -fPIC -DPIC -o .libs/streaminfo.o
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT streaminfo.lo -MD -MP -MF .deps/streaminfo.Tpo -c streaminfo.c -o streaminfo.o >/dev/null 2>&1
mv -f .deps/streaminfo.Tpo .deps/streaminfo.Plo
/bin/bash ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT synth_filter.lo -MD -MP -MF .deps/synth_filter.Tpo -c -o synth_filter.lo synth_filter.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT synth_filter.lo -MD -MP -MF .deps/synth_filter.Tpo -c synth_filter.c -fPIC -DPIC -o .libs/synth_filter.o
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT synth_filter.lo -MD -MP -MF .deps/synth_filter.Tpo -c synth_filter.c -o synth_filter.o >/dev/null 2>&1
mv -f .deps/synth_filter.Tpo .deps/synth_filter.Plo
/bin/bash ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT mpc_bits_reader.lo -MD -MP -MF .deps/mpc_bits_reader.Tpo -c -o mpc_bits_reader.lo mpc_bits_reader.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT mpc_bits_reader.lo -MD -MP -MF .deps/mpc_bits_reader.Tpo -c mpc_bits_reader.c -fPIC -DPIC -o .libs/mpc_bits_reader.o
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT mpc_bits_reader.lo -MD -MP -MF .deps/mpc_bits_reader.Tpo -c mpc_bits_reader.c -o mpc_bits_reader.o >/dev/null 2>&1
mv -f .deps/mpc_bits_reader.Tpo .deps/mpc_bits_reader.Plo
/bin/bash ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT mpc_demux.lo -MD -MP -MF .deps/mpc_demux.Tpo -c -o mpc_demux.lo mpc_demux.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT mpc_demux.lo -MD -MP -MF .deps/mpc_demux.Tpo -c mpc_demux.c -fPIC -DPIC -o .libs/mpc_demux.o
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT mpc_demux.lo -MD -MP -MF .deps/mpc_demux.Tpo -c mpc_demux.c -o mpc_demux.o >/dev/null 2>&1
mv -f .deps/mpc_demux.Tpo .deps/mpc_demux.Plo
/bin/bash ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT crc32.lo -MD -MP -MF .deps/crc32.Tpo -c -o crc32.lo `test -f '../common/crc32.c' || echo './'`../common/crc32.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT crc32.lo -MD -MP -MF .deps/crc32.Tpo -c ../common/crc32.c -fPIC -DPIC -o .libs/crc32.o
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT crc32.lo -MD -MP -MF .deps/crc32.Tpo -c ../common/crc32.c -o crc32.o >/dev/null 2>&1
mv -f .deps/crc32.Tpo .deps/crc32.Plo
/bin/bash ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT huffman-bcl.lo -MD -MP -MF .deps/huffman-bcl.Tpo -c -o huffman-bcl.lo `test -f '../common/huffman-bcl.c' || echo './'`../common/huffman-bcl.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT huffman-bcl.lo -MD -MP -MF .deps/huffman-bcl.Tpo -c ../common/huffman-bcl.c -fPIC -DPIC -o .libs/huffman-bcl.o
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I../include -I../include -fpic -fvisibility=hidden -g -O2 -MT huffman-bcl.lo -MD -MP -MF .deps/huffman-bcl.Tpo -c ../common/huffman-bcl.c -o huffman-bcl.o >/dev/null 2>&1
mv -f .deps/huffman-bcl.Tpo .deps/huffman-bcl.Plo
/bin/bash ../libtool --tag=CC --mode=link gcc -fpic -fvisibility=hidden -g -O2 -no-undefined -version-info 7:0:1 -o libmpcdec.la -rpath /usr/local/lib huffman.lo mpc_decoder.lo mpc_reader.lo requant.lo streaminfo.lo synth_filter.lo mpc_bits_reader.lo mpc_demux.lo crc32.lo huffman-bcl.lo
libtool: link: gcc -shared .libs/huffman.o .libs/mpc_decoder.o .libs/mpc_reader.o .libs/requant.o .libs/streaminfo.o .libs/synth_filter.o .libs/mpc_bits_reader.o .libs/mpc_demux.o .libs/crc32.o .libs/huffman-bcl.o -Wl,-soname -Wl,libmpcdec.so.6 -o .libs/libmpcdec.so.6.1.0
libtool: link: (cd ".libs" && rm -f "libmpcdec.so.6" && ln -s "libmpcdec.so.6.1.0" "libmpcdec.so.6")
libtool: link: (cd ".libs" && rm -f "libmpcdec.so" && ln -s "libmpcdec.so.6.1.0" "libmpcdec.so")
libtool: link: ar cru .libs/libmpcdec.a huffman.o mpc_decoder.o mpc_reader.o requant.o streaminfo.o synth_filter.o mpc_bits_reader.o mpc_demux.o crc32.o huffman-bcl.o
libtool: link: ranlib .libs/libmpcdec.a
libtool: link: ( cd ".libs" && rm -f "libmpcdec.la" && ln -s "../libmpcdec.la" "libmpcdec.la" )
make[1]: Leaving directory `/home/myself/source/musepack_src_r435/libmpcdec'
Making all in libmpcenc
make[1]: Entering directory `/home/myself/source/musepack_src_r435/libmpcenc'
gcc -DHAVE_CONFIG_H -I. -I../include -I../include/ -g -O2 -MT analy_filter.o -MD -MP -MF .deps/analy_filter.Tpo -c -o analy_filter.o analy_filter.c
mv -f .deps/analy_filter.Tpo .deps/analy_filter.Po
gcc -DHAVE_CONFIG_H -I. -I../include -I../include/ -g -O2 -MT bitstream.o -MD -MP -MF .deps/bitstream.Tpo -c -o bitstream.o bitstream.c
bitstream.c: In function ‘writeMagic’:
bitstream.c:176: warning: ignoring return value of ‘fwrite’, declared with attribute warn_unused_result
bitstream.c: In function ‘writeBlock’:
bitstream.c:203: warning: ignoring return value of ‘fwrite’, declared with attribute warn_unused_result
bitstream.c:204: warning: ignoring return value of ‘fwrite’, declared with attribute warn_unused_result
bitstream.c:214: warning: ignoring return value of ‘fwrite’, declared with attribute warn_unused_result
bitstream.c: In function ‘writeSeekTable’:
bitstream.c:245: warning: ignoring return value of ‘fwrite’, declared with attribute warn_unused_result
mv -f .deps/bitstream.Tpo .deps/bitstream.Po
gcc -DHAVE_CONFIG_H -I. -I../include -I../include/ -g -O2 -MT encode_sv7.o -MD -MP -MF .deps/encode_sv7.Tpo -c -o encode_sv7.o encode_sv7.c
mv -f .deps/encode_sv7.Tpo .deps/encode_sv7.Po
gcc -DHAVE_CONFIG_H -I. -I../include -I../include/ -g -O2 -MT huffsv7.o -MD -MP -MF .deps/huffsv7.Tpo -c -o huffsv7.o huffsv7.c
mv -f .deps/huffsv7.Tpo .deps/huffsv7.Po
gcc -DHAVE_CONFIG_H -I. -I../include -I../include/ -g -O2 -MT quant.o -MD -MP -MF .deps/quant.Tpo -c -o quant.o quant.c
mv -f .deps/quant.Tpo .deps/quant.Po
rm -f libmpcenc.a
ar cru libmpcenc.a analy_filter.o bitstream.o encode_sv7.o huffsv7.o quant.o
ranlib libmpcenc.a
make[1]: Leaving directory `/home/myself/source/musepack_src_r435/libmpcenc'
Making all in libmpcpsy
make[1]: Entering directory `/home/myself/source/musepack_src_r435/libmpcpsy'
gcc -DHAVE_CONFIG_H -I. -I../include -I../include/ -g -O2 -MT ans.o -MD -MP -MF .deps/ans.Tpo -c -o ans.o ans.c
ans.c: In function ‘NS_Analyse’:
ans.c:292: warning: passing argument 10 of ‘FindOptimalANS’ from incompatible pointer type
ans.c:297: warning: passing argument 10 of ‘FindOptimalANS’ from incompatible pointer type
mv -f .deps/ans.Tpo .deps/ans.Po
gcc -DHAVE_CONFIG_H -I. -I../include -I../include/ -g -O2 -MT cvd.o -MD -MP -MF .deps/cvd.Tpo -c -o cvd.o cvd.c
mv -f .deps/cvd.Tpo .deps/cvd.Po
gcc -DHAVE_CONFIG_H -I. -I../include -I../include/ -g -O2 -MT fft4g.o -MD -MP -MF .deps/fft4g.Tpo -c -o fft4g.o fft4g.c
mv -f .deps/fft4g.Tpo .deps/fft4g.Po
gcc -DHAVE_CONFIG_H -I. -I../include -I../include/ -g -O2 -MT fft_routines.o -MD -MP -MF .deps/fft_routines.Tpo -c -o fft_routines.o fft_routines.c
mv -f .deps/fft_routines.Tpo .deps/fft_routines.Po
gcc -DHAVE_CONFIG_H -I. -I../include -I../include/ -g -O2 -MT psy.o -MD -MP -MF .deps/psy.Tpo -c -o psy.o psy.c
psy.c: In function ‘Psychoakustisches_Modell’:
psy.c:1031: warning: passing argument 2 of ‘CalcShortThreshold’ from incompatible pointer type
psy.c:1039: warning: passing argument 2 of ‘CalcShortThreshold’ from incompatible pointer type
psy.c:1164: warning: passing argument 2 of ‘CalcShortThreshold’ from incompatible pointer type
psy.c:1172: warning: passing argument 2 of ‘CalcShortThreshold’ from incompatible pointer type
mv -f .deps/psy.Tpo .deps/psy.Po
gcc -DHAVE_CONFIG_H -I. -I../include -I../include/ -g -O2 -MT psy_tab.o -MD -MP -MF .deps/psy_tab.Tpo -c -o psy_tab.o psy_tab.c
mv -f .deps/psy_tab.Tpo .deps/psy_tab.Po
gcc -DHAVE_CONFIG_H -I. -I../include -I../include/ -g -O2 -MT profile.o -MD -MP -MF .deps/profile.Tpo -c -o profile.o profile.c
mv -f .deps/profile.Tpo .deps/profile.Po
rm -f libmpcpsy.a
ar cru libmpcpsy.a ans.o cvd.o fft4g.o fft_routines.o psy.o psy_tab.o profile.o
ranlib libmpcpsy.a
make[1]: Leaving directory `/home/myself/source/musepack_src_r435/libmpcpsy'
Making all in libwavformat
make[1]: Entering directory `/home/myself/source/musepack_src_r435/libwavformat'
gcc -DHAVE_CONFIG_H -I. -I../include -g -O2 -MT input.o -MD -MP -MF .deps/input.Tpo -c -o input.o input.c
mv -f .deps/input.Tpo .deps/input.Po
gcc -DHAVE_CONFIG_H -I. -I../include -g -O2 -MT output.o -MD -MP -MF .deps/output.Tpo -c -o output.o output.c
mv -f .deps/output.Tpo .deps/output.Po
rm -f libwavformat.a
ar cru libwavformat.a input.o output.o
ranlib libwavformat.a
make[1]: Leaving directory `/home/myself/source/musepack_src_r435/libwavformat'
Making all in mpcenc
make[1]: Entering directory `/home/myself/source/musepack_src_r435/mpcenc'
gcc -DHAVE_CONFIG_H -I. -I../include -I../libmpcenc -I../libmpcpsy -I../include/ -DTRUE=1 -DFALSE=0 -g -O2 -MT keyboard.o -MD -MP -MF .deps/keyboard.Tpo -c -o keyboard.o keyboard.c
mv -f .deps/keyboard.Tpo .deps/keyboard.Po
gcc -DHAVE_CONFIG_H -I. -I../include -I../libmpcenc -I../libmpcpsy -I../include/ -DTRUE=1 -DFALSE=0 -g -O2 -MT mpcenc.o -MD -MP -MF .deps/mpcenc.Tpo -c -o mpcenc.o mpcenc.c
mpcenc.c: In function ‘Quantisierung’:
mpcenc.c:692: warning: passing argument 1 of ‘QuantizeSubbandWithNoiseShaping’ from incompatible pointer type
mpcenc.c:695: warning: passing argument 1 of ‘QuantizeSubband’ from incompatible pointer type
mpcenc.c:702: warning: passing argument 1 of ‘QuantizeSubbandWithNoiseShaping’ from incompatible pointer type
mpcenc.c:705: warning: passing argument 1 of ‘QuantizeSubband’ from incompatible pointer type
mpcenc.c: In function ‘EvalParameters’:
mpcenc.c:1026: warning: ignoring return value of ‘freopen’, declared with attribute warn_unused_result
mpcenc.c:1211: warning: ignoring return value of ‘fgets’, declared with attribute warn_unused_result
mpcenc.c: In function ‘mainloop’:
mpcenc.c:1711: warning: passing argument 7 of ‘Allocate’ from incompatible pointer type
mpcenc.c:1712: warning: passing argument 7 of ‘Allocate’ from incompatible pointer type
mv -f .deps/mpcenc.Tpo .deps/mpcenc.Po
gcc -DHAVE_CONFIG_H -I. -I../include -I../libmpcenc -I../libmpcpsy -I../include/ -DTRUE=1 -DFALSE=0 -g -O2 -MT pipeopen.o -MD -MP -MF .deps/pipeopen.Tpo -c -o pipeopen.o pipeopen.c
mv -f .deps/pipeopen.Tpo .deps/pipeopen.Po
gcc -DHAVE_CONFIG_H -I. -I../include -I../libmpcenc -I../libmpcpsy -I../include/ -DTRUE=1 -DFALSE=0 -g -O2 -MT stderr.o -MD -MP -MF .deps/stderr.Tpo -c -o stderr.o stderr.c
stderr.c: In function ‘stderr_printf’:
stderr.c:69: warning: ignoring return value of ‘fwrite’, declared with attribute warn_unused_result
mv -f .deps/stderr.Tpo .deps/stderr.Po
gcc -DHAVE_CONFIG_H -I. -I../include -I../libmpcenc -I../libmpcpsy -I../include/ -DTRUE=1 -DFALSE=0 -g -O2 -MT wave_in.o -MD -MP -MF .deps/wave_in.Tpo -c -o wave_in.o wave_in.c
mv -f .deps/wave_in.Tpo .deps/wave_in.Po
gcc -DHAVE_CONFIG_H -I. -I../include -I../libmpcenc -I../libmpcpsy -I../include/ -DTRUE=1 -DFALSE=0 -g -O2 -MT winmsg.o -MD -MP -MF .deps/winmsg.Tpo -c -o winmsg.o winmsg.c
mv -f .deps/winmsg.Tpo .deps/winmsg.Po
gcc -DHAVE_CONFIG_H -I. -I../include -I../libmpcenc -I../libmpcpsy -I../include/ -DTRUE=1 -DFALSE=0 -g -O2 -MT crc32.o -MD -MP -MF .deps/crc32.Tpo -c -o crc32.o `test -f '../common/crc32.c' || echo './'`../common/crc32.c
mv -f .deps/crc32.Tpo .deps/crc32.Po
gcc -DHAVE_CONFIG_H -I. -I../include -I../libmpcenc -I../libmpcpsy -I../include/ -DTRUE=1 -DFALSE=0 -g -O2 -MT huffman-bcl.o -MD -MP -MF .deps/huffman-bcl.Tpo -c -o huffman-bcl.o `test -f '../common/huffman-bcl.c' || echo './'`../common/huffman-bcl.c
mv -f .deps/huffman-bcl.Tpo .deps/huffman-bcl.Po
gcc -DHAVE_CONFIG_H -I. -I../include -I../libmpcenc -I../libmpcpsy -I../include/ -DTRUE=1 -DFALSE=0 -g -O2 -MT fastmath.o -MD -MP -MF .deps/fastmath.Tpo -c -o fastmath.o `test -f '../common/fastmath.c' || echo './'`../common/fastmath.c
mv -f .deps/fastmath.Tpo .deps/fastmath.Po
gcc -DHAVE_CONFIG_H -I. -I../include -I../libmpcenc -I../libmpcpsy -I../include/ -DTRUE=1 -DFALSE=0 -g -O2 -MT tags.o -MD -MP -MF .deps/tags.Tpo -c -o tags.o `test -f '../common/tags.c' || echo './'`../common/tags.c
mv -f .deps/tags.Tpo .deps/tags.Po
/bin/bash ../libtool --tag=CC --mode=link gcc -DTRUE=1 -DFALSE=0 -g -O2 -o mpcenc keyboard.o mpcenc.o pipeopen.o stderr.o wave_in.o winmsg.o crc32.o huffman-bcl.o fastmath.o tags.o -lm ../libmpcpsy/libmpcpsy.a ../libmpcenc/libmpcenc.a
libtool: link: gcc -DTRUE=1 -DFALSE=0 -g -O2 -o mpcenc keyboard.o mpcenc.o pipeopen.o stderr.o wave_in.o winmsg.o crc32.o huffman-bcl.o fastmath.o tags.o -lm ../libmpcpsy/libmpcpsy.a ../libmpcenc/libmpcenc.a
make[1]: Leaving directory `/home/myself/source/musepack_src_r435/mpcenc'
Making all in mpc2sv8
make[1]: Entering directory `/home/myself/source/musepack_src_r435/mpc2sv8'
gcc -DHAVE_CONFIG_H -I. -I../include -I../include -g -O2 -MT mpc2sv8.o -MD -MP -MF .deps/mpc2sv8.Tpo -c -o mpc2sv8.o mpc2sv8.c
mv -f .deps/mpc2sv8.Tpo .deps/mpc2sv8.Po
gcc -DHAVE_CONFIG_H -I. -I../include -I../include -g -O2 -MT crc32.o -MD -MP -MF .deps/crc32.Tpo -c -o crc32.o `test -f '../common/crc32.c' || echo './'`../common/crc32.c
/bin/bash ../libtool --tag=CC --mode=link gcc -g -O2 -o mpc2sv8 mpc2sv8.o crc32.o -lm ../libmpcdec/libmpcdec.la ../libmpcenc/libmpcenc.a
libtool: link: gcc -g -O2 -o .libs/mpc2sv8 mpc2sv8.o crc32.o -lm ../libmpcdec/.libs/libmpcdec.so ../libmpcenc/libmpcenc.a
make[1]: Leaving directory `/home/myself/source/musepack_src_r435/mpc2sv8'
Making all in mpcchap
make[1]: Entering directory `/home/myself/source/musepack_src_r435/mpcchap'
gcc -DHAVE_CONFIG_H -I. -I../include -I../include -g -O2 -MT dictionary.o -MD -MP -MF .deps/dictionary.Tpo -c -o dictionary.o dictionary.c
mv -f .deps/dictionary.Tpo .deps/dictionary.Po
gcc -DHAVE_CONFIG_H -I. -I../include -I../include -g -O2 -MT iniparser.o -MD -MP -MF .deps/iniparser.Tpo -c -o iniparser.o iniparser.c
mv -f .deps/iniparser.Tpo .deps/iniparser.Po
gcc -DHAVE_CONFIG_H -I. -I../include -I../include -g -O2 -MT mpcchap.o -MD -MP -MF .deps/mpcchap.Tpo -c -o mpcchap.o mpcchap.c
mpcchap.c:27:30: error: cuetools/cuefile.h: No such file or directory
mpcchap.c:57: error: ‘PTI_TITLE’ undeclared here (not in a function)
mpcchap.c:57: error: ‘PTI_PERFORMER’ undeclared here (not in a function)
mpcchap.c:57: error: ‘PTI_SONGWRITER’ undeclared here (not in a function)
mpcchap.c:57: error: ‘PTI_COMPOSER’ undeclared here (not in a function)
mpcchap.c:58: error: ‘PTI_ARRANGER’ undeclared here (not in a function)
mpcchap.c:58: error: ‘PTI_MESSAGE’ undeclared here (not in a function)
mpcchap.c:58: error: ‘PTI_GENRE’ undeclared here (not in a function)
mpcchap.c: In function ‘add_chaps_ini’:
mpcchap.c:94: warning: ignoring return value of ‘fread’, declared with attribute warn_unused_result
mpcchap.c:133: warning: ignoring return value of ‘fwrite’, declared with attribute warn_unused_result
mpcchap.c:134: warning: ignoring return value of ‘fwrite’, declared with attribute warn_unused_result
mpcchap.c:139: warning: ignoring return value of ‘fwrite’, declared with attribute warn_unused_result
mpcchap.c:143: warning: ignoring return value of ‘fwrite’, declared with attribute warn_unused_result
mpcchap.c:144: warning: ignoring return value of ‘ftruncate’, declared with attribute warn_unused_result
mpcchap.c: In function ‘add_chaps_cue’:
mpcchap.c:155: error: ‘Cd’ undeclared (first use in this function)
mpcchap.c:155: error: (Each undeclared identifier is reported only once
mpcchap.c:155: error: for each function it appears in.)
mpcchap.c:155: error: ‘cd’ undeclared (first use in this function)
mpcchap.c:155: error: invalid operands to binary * (have ‘const int *’ and ‘const int *’)
mpcchap.c:156: error: ‘UNKNOWN’ undeclared (first use in this function)
mpcchap.c:156: warning: initialization makes integer from pointer without a cast
mpcchap.c:182: error: ‘Track’ undeclared (first use in this function)
mpcchap.c:182: error: ‘track’ undeclared (first use in this function)
mpcchap.c:182: error: invalid operands to binary * (have ‘const int *’ and ‘const int *’)
mpcchap.c:183: error: ‘Cdtext’ undeclared (first use in this function)
mpcchap.c:183: error: ‘cdtext’ undeclared (first use in this function)
mpcchap.c:183: error: invalid operands to binary * (have ‘const int *’ and ‘const int *’)
mpcchap.c:207: warning: assignment makes pointer from integer without a cast
mpcchap.c:175: warning: ignoring return value of ‘fread’, declared with attribute warn_unused_result
mpcchap.c:220: warning: ignoring return value of ‘fwrite’, declared with attribute warn_unused_result
mpcchap.c:221: warning: ignoring return value of ‘fwrite’, declared with attribute warn_unused_result
mpcchap.c:222: warning: ignoring return value of ‘fwrite’, declared with attribute warn_unused_result
mpcchap.c:226: warning: ignoring return value of ‘fwrite’, declared with attribute warn_unused_result
mpcchap.c:227: warning: ignoring return value of ‘ftruncate’, declared with attribute warn_unused_result
make[1]: *** [mpcchap.o] Error 1
make[1]: Leaving directory `/home/myself/source/musepack_src_r435/mpcchap'
make: *** [all-recursive] Error 1
from your logfile, it appears you are missing the cuetools dev package.
the official debian packages remove mpcchap, but all you need to do is compile cuetools yourself with a dynamic lib rather than a static lib. also, make sure you have libreplaygain from the musepack svn.
later
Thanks a lot for all the work.
Congratulations. Even if i have never used MPC, it is always wonderful see people do work just for the love of doing it
Dunno if Debian provides a dev package for cuetools, but cuetools itself doesn't install neither the lib nor the header to the system.
That is, if you compile and install cuetools yourself, you'll get only binaries.
By the way, if cuetools would install the lib, it doesn't matter whether it'll be static or dynamic.
I found out. I dragged in the latest code from svn and tried
./configure --enable-shared --disable-static but no headers or libs...
this is what i did (debian unstable):
* checkout cuetools from SVN
* change compilation from static to dynamic
* build
* install (i made debian packages, but you don't need too (libcuefile0, iirc)
later
Ehhrmm. Yes. Exactly how?
Fantastic news guys, well done!
Nice work
I have contacted the developer of the php media parser getID3() (http://www.getid3.org/) to support Musepack SV8.
The developer was so kind to update the scripts in a few hours.
Now getID3() (http://www.getid3.org/) versions 1.7.9 and 2.0.0b5 both support Musepack SV8.
I tried to compile it on OS X, but ran into this error:
ld: duplicate symbol ___Dc in .libs/requant.o and .libs/mpc_decoder.o
collect2: ld returned 1 exit status
make[1]: *** [libmpcdec.la] Error 1
To kdo and all users:
Fixes to reported bugs are in the latest SVN build (http://negju.musepack.net/SVNBuild439.zip)
mpccut will work even on broken files. mpcgain and mpc2sv8 will too. Pay attention to ANY "An error occured while decoding, this file may be corrupted" message from mpc2sv8. It means the converted file was partially broken
I intentionally removed any mpcenc binaries from this archive. The ones on the official SV8 archive are to be used
Arh.......... Sorry i have get this out............
I still remember how many HA members swear by MPC 's quality in the good old days. For those who were old enough to remember it, i cant believe it is now 7 years+ pass by.
SV8 is a dream come true. At some point in time everyone was expecting MPC SV8 will take over the world. Given how it was designed to improve on SV7 's shortcoming.
But it never appeared, and sadly abandon during a point in time. We all thought it was a dream that we will all hide deep in our mind.
Time comes by, Vobris and AAC both have improved tremendously. When we have all forgotten about MPC SV8, and we all thought AAC or Vobirs would some how change the world........
Well, the reality is nothing much has changed. Mp3 still rules the Digital Music Format. Although AAC did make progress with Apple iTunes and Vobris is heavily used in gaming industry, the majority of user are still using Mp3.
Good Luck to SV8. I still think, ( my personal opinion ) that MPC is still the king in 256Kbps to 320kbps range. Given how the world is finally moving away from 128Kbps, MPC may have a chance due to its advantage in processor power required to decode is much less then other competitors.
Would you, please?
I would be really happy to see chapter support in your plugin. I found this new feature quite useful. Of course, one can use cuesheets, however I'd prefer one-file solution. It could be even possible to embed cuesheets in APE tags, but I haven't tried if it works with Musepack. Plus, it is too easy to remove the tags by accident.
never thought i'd see the day.. many thanks to all involved in the development!
-andy-
The official package for windows has been updated:
- mpcgain.exe was fixed to prevent corruption which could be caused in certain cases and to allow wildcards.
- mpccut.exe is now more resilient to errors and can cut broken files.
Download (http://files.musepack.net/windows/musepack_windows_2009-04-02.zip)
Any news regarding Rockbox support?
I was googling just the other day to see a status. I am anxious for Rockbox to meet SV8 as well.
There is no news. The ball is not in our court
As of today SV8 is in the "current" (auto built SVN) builds and will be in the next supported (3.6) release.
Which means 2 to 4 months probably, based on the recent release history.
