Topic: Playlist View issues with ColumnsUI (Read 539 times) previous topic - next topic
After 18 years of using fb2k with Default UI, yesterday I took the plunge and created my setup in ColumnsUI for the first time... pretty major potential change for me.  One major issue though:
Normally I keep several different playlist viewer tabs with different settings each.
- one with album groupings and artwork
- one with no artwork or groupings, so that I can view random song playlists without anything split up
- one with %path% and some other fields visible, to use when I'm organizing music.
In all of them I used custom strings for the various columns, for example in the date column I use: $if2($cut(<<%original release date%>>,4),$cut(<<%date%>>,4))  and in the track number column I use $if2(<<<%discnumber%>>>,' ')  %Tracknumber%
Is there a way to get playlist views like this in columnsUI?
- The default playlist view doesn't seem to allow different configurations in different tabs.
- In JSP3, the JS Playlist sample seems to handle different configs, but I can't figure out how to add my custom column strings.
- Also in JSP3, Smooth Playlist looks great but I can't figure out how to customize it.
Anyone have any tips?   It'd be a shame to revert to Default UI just because of this.  Thanks!
Re: Playlist View issues with ColumnsUI
Well I think I just figured out how to add custom columns in JS Playlist...
Preferences > Display > Columns UI > Layout > Active preset > New
Created New Layout 1.2.3...
foobar Menu > View > Layout
Columns UI Documentation
https://wiki.yuo.be/columns_ui:manual
Historical and Columns UI color functions
https://wiki.hydrogenaud.io/index.php?title=Foobar2000:Titleformat_Reference#Historical_and_Columns_UI_color_functions
SHURE SRH1840, SENNHEISER HD660S, Beyerdynamic DT 1990 PRO, HIFIMAN HE5se, Ultrasone Performance 880, AKG K712 PRO, SONY MDR-1AM2, Bowers & Wilkins P7, Bose QuietComfort 45, SONY WH-1000XM3 (made a Upgrade/Balanced Cable by myself) Shall I write more?
Interesting - never would have thought about making a copy of the whole UI with just that change!
The Playlist Viewers to use are Playlist View (default) and JS Playlist x2.,3.
Awesome, thanks so much!
