Topic: 2.0 Convert FLAC to AAC lose track numbers (Read 848 times) previous topic - next topic
Hello
on foobar2000 2.0 , with Free Encoder Pack 2023-04-30, I convert FLAC to Apple Lossless
in some cases, the converted files lose the track number.
It happens when Track Number appear in Foobar2000 as 1/, 2/, 3/ (, is a separator and not appear) etc.  it works well when track number appear as   1/1.1/, 1/1.2/, 1/1.3  etc.
Disc value is null in both case, but Part of the disc is null in the first case and with the Disc number in the second.
Re: 2.0 Convert FLAC to AAC lose track numbers
I was still looking and found another case of track number not converted.
source was by example 1/19 where 1 os the track number and 19 the number of tracks on disc. After convert, it is at Null.
Can't really replicate your issue. Also are you dealing with AAC as your title says, or ALAC as your post says?
Note that your FLAC files shouldn't have track numbers written that way. There's a separate tag field for total tracks.
Although they shouldn't: tags like that sometimes show up. dBpoweramp would/could do it once upon a time when I started ripping my CDs.
I ripped my CDs with Winamps in 2009, once upon a time ...
80% of CD are working but other lose the track number on converstions
I have found another case, where Disc number is 1/1 instead of just 1.
Other cause, but same result, no track number after convert.
I think I will have to go on a Mass sanitize on Discnumber and Part of set.
You could provide a sample track for examination. And also tell exact settings you use to convert with.
Disc number "1/1" converted to Apple (AAC) or Apple Lossless codec does not prevent track numbers from getting copied.
I can even type "potato" as a track number in FLAC and it gets happily copied over to both formats you have mentioned.
i have found a way to solve it: importing the folder, going to properties, TOOLS, "auto track numbers"  and then convert  in applelossless (with name format %genre%/%album%/%track number% - %title% )
example
Gerry Mulligan Quartet & Chet Baker - [The Ultimate Jazz Archive 29 (Disc 4) CD2/4 #01] Freeway
Audio sample was over 30 seconds. Removed. Added image of properties
%tracknumber%
https://wiki.hydrogenaud.io/index.php?title=Foobar2000:Titleformat_Reference#.25tracknumber.25
or
Track Number: 1
Disc Number:2
Total Discs4
SHURE SRH1840, SENNHEISER HD660S, Beyerdynamic DT 1990 PRO, HIFIMAN HE5se, Ultrasone Performance 880, AKG K712 PRO, SONY MDR-1AM2, Bowers & Wilkins P7, Bose QuietComfort 45, SONY WH-1000XM3 (made a Upgrade/Balanced Cable by myself) Shall I write more?
when converting to name format %genre%/%album%/%tracknumber% - %title%, it gives a file : 1- - Freeway.m4a without a track number property set.
after  "Tools-auto number" it gives file :  1 - Freeway.m4a with a track number set.
Track number is simply 1 then, instead of 1/ , and Total track is 14 where it was not set.
