Topic: u-law encoder (Read 5978 times) previous topic - next topic
u-law encoder
I need to encode a large amount of wav files (22.05 kHz/16-bit/1 channel) to u-law wav files.  Is there any open source library that can do the job?  I am planning to write a command-line encoder and then call it with a shell script.
Thanks in advance.
Michael Lee
u-law encoder
Sox could do the job.
u-law encoder
Thanks!  SoX is exactly what I need!
u-law encoder
I'm not sure you really want to do that. U-law is fine for 8 kHz speech, but not for 16 kHz and above. The reason is that the dynamic range in the spectrum (energy difference between low and high frequencies) is too high, which creates annoying noise at higher frequencies. I think there's a mu-law standard for wideband but it uses 12 bits/sample (i.e. not a huge gain). Of course, there's always Speex that will get you better quality at lower bit-rate (disclaimer: I'm the Speex author).
u-law encoder
I have to do that for a project which involves computer telephony hardware supporting only 8 kHz u-law WAV files and VOX files.
u-law encoder
In this case, I strongly suggest that you do some pre-emphasis on the signal first (if you can). It can be something simple like filtering by H(z)=1 - 0.7*z^-1 before converting to u-law and then applying 1/H(z) after decoding.
