Topic: the best abr line... (Read 2877 times) previous topic - next topic
It seems like the general consensus is that "--abr 134 -h --nspsytune --athtype 2 --lowpass 17.5 --ns-bass -6 --scale 0.95" gives the best sounding mp3s at that level. But how would I go about changing the settings if I were to implement a 18.5khz lowpass. Raising the abr would be okay if it is nesacary. I just don't know to how much. If you give a preset, please put the swithches behind that preset as well. Thank you very much for any help.
Probably your best bet is just to use --dm-preset <bitrate>, as you use a higher bitrate, the lowpass value will increase, as well as other setting changing to increase quality dynamically.
There are no 1 set of switches for the --dm-preset abr settings because they dynamically change depending on the bitrate specified.
Okay so if you don't mind whats behind the
abr 128, 160, 192?
Someone told me to look for my self in the cvs. But be damned if I even knew what was. :confused:
