Topic: Foobar crashes without any notice (Read 2067 times) previous topic - next topic
When playing certain songs, Foobar crashes without any notice (or crash log).
You can hear about half a second and then suddenly Foobar closes. I've loaded an Empty DSP Chain and it still crashes.
There aren't any log files either.
The trouble started when my computer crashed.
What files to I need to copy in order to save my settings, DSP Chains layouts, playlists etc.?
EDIT:
Reinstalling didn't work! This time it showed this page: http://help.foobar2000.org/troubleshooter/components/f98357de9e4e3b87+07a20c6410be93b4+6d0730961e1fb610
When started in safe mode, everything works.
Re: Foobar crashes without any notice
Have you uninstalled foo_channel_mixer.dll : Channel Mixer 0.9.6.7, foo_uie_lyrics3.dll : Lyric Show Panel 3 0.5 and updated foo_httpcontrol.dll : HTTP Control 0.97.14-fb2kc?
Yes I did, didn't change a thing unfortunately.
can you give a list of all the plugins you have installed?
Foobar Preferences > Components | click the copy report button and paste it in your reply.
Here you go:
Core (2017-07-10 05:24:08 UTC)
    foobar2000 core 1.3.16
foo_albumlist.dll (2017-07-10 05:22:48 UTC)
    Album List 4.5
foo_burninate.dll (2015-09-04 14:53:49 UTC)
    Audio CD Writer 3.0.3
foo_cdda.dll (2017-07-10 05:22:22 UTC)
    CD Audio Decoder 3.0
foo_channel_mixer.dll (2011-06-01 17:18:00 UTC)
foo_converter.dll (2017-07-10 05:22:28 UTC)
    Converter 1.5
foo_discogs.dll (2017-03-11 10:16:24 UTC)
    Discogs Tagger 2.13
foo_dsp_BassExciter_EN.dll (2011-01-15 12:32:28 UTC)
    Real Bass Exciter EFX Module (en-US) 1.0.12
foo_dsp_effect.dll (2017-09-17 09:22:00 UTC)
    Effect DSP 0.21.1
foo_dsp_eq.dll (2017-07-10 05:22:46 UTC)
    Equalizer 1.2
foo_dsp_fsurround.dll (2012-07-07 06:29:42 UTC)
    FreeSurround 0.9.0
foo_dsp_std.dll (2017-07-10 05:22:42 UTC)
    Standard DSP Array 1.3.1
foo_fileops.dll (2017-07-10 05:21:24 UTC)
    File Operations 2.2.2
foo_freedb2.dll (2016-03-30 11:45:14 UTC)
    Online Tagger 0.7
foo_httpcontrol.dll (2013-04-26 16:12:30 UTC)
foo_input_std.dll (2017-07-10 05:22:04 UTC)
    FFmpeg Decoders 3.2.4
    Standard Input Array 1.0
foo_jesus.dll (2010-09-23 00:34:06 UTC)
    Autosave & Autobackup 10
foo_masstag.dll (2015-07-17 14:31:17 UTC)
    Masstagger 1.8.4
foo_musicbrainz.dll (2017-09-18 17:53:19 UTC)
    MusicBrainz Tagger 0.3.1
foo_out_asio.dll (2014-09-08 13:28:16 UTC)
    ASIO support 2.1.2
foo_playcount.dll (2013-02-01 08:40:46 UTC)
    Playback Statistics 3.0.2
foo_quicktag.dll (2010-09-01 08:15:08 UTC)
    Quick Tagger 1.0.3
foo_rgscan.dll (2016-03-30 11:44:24 UTC)
    ReplayGain Scanner 2.2.2
foo_run.dll (2009-06-07 13:15:18 UTC)
    Run services 0.3.7
foo_ui_columns.dll (2011-02-27 20:22:58 UTC)
    Columns UI 0.3.8.8
foo_ui_std.dll (2017-07-10 05:22:34 UTC)
    Default User Interface 0.9.5
foo_uie_lyrics3.dll (2017-05-18 19:48:16 UTC)
foo_uie_wsh_panel_mod.dll (2015-07-17 14:02:19 UTC)
    WSH Panel Mod 1.5.6
foo_unpack.dll (2017-07-10 05:22:22 UTC)
    ZIP/GZIP/RAR Reader 1.8
foo_upnp.dll (2015-02-26 15:12:37 UTC)
    UPnP/DLNA Renderer, Server, Control Point 0.99.49
foo_wave_seekbar.dll (2014-03-08 14:22:36 UTC)
    Waveform seekbar 0.2.45
foo_winamp_spam.dll (2015-06-02 16:03:47 UTC)
    Winamp API Emulator 0.99
foo_youtube.dll (2017-09-17 09:44:24 UTC)
    Youtube Source 2.0.1
I would personally start by removing plugins one by one starting with the ones with the oldest dates. once the crashing stops look for the latest versions of the plugins to have removed and added them back one by one.
Hopefully that will narrow down the plugin causing it or fix the problem.
Is there a way to attach an debugger to the application? I think that would make it easier to fix the problem
EDIT:
When attached to VS and playing that song that crashes foobar:
foobar2000.exe has triggered a breakpoint.
Call stack:
    foo_youtube.dll!065a81f6()   Unknown
    foo_youtube.dll!065a8513()   Unknown
    foo_youtube.dll!06412459()   Unknown
    foo_youtube.dll!0657841c()   Unknown
    foo_youtube.dll!0657806e()   Unknown
    foo_youtube.dll!063f9088()   Unknown
    foo_youtube.dll!064dda55()   Unknown
    foo_youtube.dll!06508f3e()   Unknown
    foo_youtube.dll!0650841e()   Unknown
    foo_youtube.dll!0650f8ad()   Unknown
    foo_youtube.dll!064f0ea2()   Unknown
    foo_youtube.dll!064eb1ad()   Unknown
    foo_youtube.dll!0657243e()   Unknown
    foo_youtube.dll!0669be5a()   Unknown
Which is strange since it isn't a youtube song.
I am contacting the developer of the foobar component.
The developer said that version v2 introduces the playback of video's from every file, not only from supported URL's. I think he is working on a fix.
You can temporary turn off that new 'feature': Check the 'Allow video playback only for supported URLs' (preferences Advanced -> Tools -> Youtube Source -> Video) item.
