HydrogenAudio
Hosted Forums => foobar2000 => 3rd Party Plugins - (fb2k) => Topic started by: ojdo on 2021-03-30 16:11:10
Title: IDENTIFY: was/is there playlist "synchronisation" component?
Post by: ojdo on 2021-03-30 16:11:10
Is (or was there) a component that
I think I once saw such a component; point 2 might have been only semi-automatic (e.g. use of context menu). But neither forum search nor wiki turned up a promising candidate.
Background/Use case: playback hand-picked subsets of my library (hosted on a public SMB share) through VLC for Android. Manually maintaining dozens of playlist files sounds painful.
Title: Re: IDENTIFY: was/is there playlist "synchronisation" component?
Post by: regor on 2021-03-30 17:28:16
https://hydrogenaud.io/index.php?topic=120394.msg993372#msg993372
Playlist manager
It's all done automatically plus many more features. Although I can not support fpl playlist without user intervention, since the format is not open and there is no SMP method to save fpl playlists to path. m3u8 is supported BUT there is a huge load speed penalty.
Post by: Koshingg on 2021-03-30 18:26:45
1.You have 3 choices : a component https://foosion.foobar2000.org/components/?id=plman&version=1.0.2 (autoplaylists have yellow color).
The second option : a script JS Smooth Playlist Manager (you need to install a component , foo_spider_monkey_panel https://github.com/TheQwertiest/foo_spider_monkey_panel/releases/download/v1.4.1/foo_spider_monkey_panel.fb2k-component, After install, add a panel to your layout - Spider monkey panel, and then load the script JS Smooth Playlist Manager.) This script is located in foobar2000\user-components\foo_spider_monkey_panel\samples\js-smooth
Option number 3 : a script https://hydrogenaud.io/index.php?topic=120394.msg993797#msg993797 it's a playlist manager, you need this component : foo_spider_monkey_panel and then after you add a panel (Spider Monkey panel) to your layout, you load this script named playlist_manager. This playlist manager is cool because , for example you can change the color of the font for autoplaylists, let's say red, and many other things. If you want this script you have to ask the developer to sent you the script, you can send him an email here: regorxxx@protonmail.com.  (Well, it seems the developer of the script , regor, was a bit faster and answered already, haha , I wrote the message but I didn't get to sent it and then after more than 1 hour I sent the message but he already answered) So, this playlist manager is definitely the best option , you should try it.
2.... automatically stores its tracks as a static (m3u8) playlist file on disk?
This can be done by this playlist manager that I told you about earlier (Option number 3)
