Topic: Mp3 playback problem (Read 3302 times) previous topic - next topic
Lately I had a problem with a .mp3 file that in no other .mp3 player occured. At least not in Winamp. With Mp3directcut I cutted out the problem sample. It's about 200kb. You can find it at:
http://members.lycos.nl/xvid/audio/
Any chance this will be fixed? Cause I love foobar, but this file makes me prefer winamp.
A secure audio ripper for linux: code.google.com/p/rubyripper
It "breaks" in Winamp, too, just not a noticably.  The Fraunhofer decoder may just be more elegant at recovering from errors.  Hardly foobar's fault that the file is broken, though.
i can make it decode "correctly" (as in: ignore error in the frame, produces no noticeable sound interruption to me), but it will also make a lot of other damaged files produce bleeps instead of silent frames.
I'm reluctant to suggest this (a knackered file is a knackered file, after all), but perhaps a solution would be to provide the ability to flag a file in the database as "ignore decoding errors" or something similar?
Personally, I'd never use it, but it's just a thought
The problem is, there's a near-infinite number of things that could be added.  It's a matter of balancing time, and adding only those worth adding.
That said, it's Peter's call.
What is the error? What makes the erroneous frame different from a normal frame? I think that the quickest solution would be to have some way for foobar to alter the file to "fix" the frame in the eyes of decoders, especially if it doesn't sound like there's an error there.
Having some error correction options for MP3s in foobar would be an interesting, and possibly "killer" feature.
