Topic: TripleFlac (Read 1900 times) previous topic - next topic
TripleFlac
Good evening,
I would need the TripleFlac executable. Could someone pass it to me?
Thank you!
Re: TripleFlac
The heck is that?
TAPE LOADING ERROR
Re: TripleFlac
Based on the information found online that tool checked FLAC files against AccurateRip. You don't need to hunt down an ancient program that apparently never even had a home, you can use for example foobar2000 to check any format against AccurateRip.
Re: TripleFlac
foobar2000 yes; CUETools can also do that even with odd offset if it has an EAC log or the appropriate tags; and then there is PerfectTunes from the creator of AccurateRip.
Tripleflac served a purpose once, but it is obsoleted indeed.
Re: TripleFlac
Thx you all for your precious contribution !!
