Topic: config_var help (Read 3169 times) previous topic - next topic
config_var help
I want to add per look saved values into my dll's portion of the .cfg file
so something like this where the indented stuff is the look specific values
foo_looks.dll
someinternal_val
foo_looks.ski // look specific
----->spectrum 0
----->layout 0
fooAMP.ski // look specific
----->showalbumart 1
Each look would be able to save its own information into a sub section corresponding to the look's name
So far I've just used the config api for my internal storage - all vars are static declared.
So my starter questions.
1.  Can you add/delete config vars on the fly
ie.
cfg_int* layout = new cfg_int(1);
2.  How can I achieve the sub section management so that I can add/remove entire sub blocks and also have each look be able to grab values from its block?  config_var_struct looked like it might be what I wanted but that would only allow for subvalues of a single type, correct?
Any help appreciated.
config_var help
//IMPORTANT:
//cfg_var objects are intended ONLY to be created statically !!!!
I think it's the same for config_var objects.
If you want structured data, you'll have to write your own subclass of cfg_var, unless you can fit the data into some struct. In that case you could use cfg_struct_t<T>.
In case you need some inspiration, look at the masstagger sources to see how masstagger scripts are stored. There's also the foosion_helper library on my plugin page for anyone who dares. It includes a cfg_var subclass that can store string tuples.
config_var help
//IMPORTANT:
I thought the static only was for config_var_callback_autoreg?  If all have to be static then my plan is already sunk since I'd want to be able to add/delete on the fly as looks are loaded/unloaded and based on the scripts they call for saving/removing cfg variables.
I'll take a look at the source code you mentioned - what's you page link?
config_var help
You could create a single variable that would contain a variable sized structure. Validating the contents of the structure shouldn't really be a problem, as the configuration file is protected against tampering. So, unless you save garbage yourself...
