hi
who know how to set up psytel aac in order to get constant bitrate?
thanks
There are some hidden switches to turn off using the bit reservoir, and some other tricks to get CBR AAC.
But why do you want that anyway? Quality tends to get worse in CBR.
hi
i wish to compare aac with wma9 at canstant bitrate.
becuase wma9 can get very right canstant bit rate, so i hope to compare them at same conditions.
do you know how to set those hidden switchs?
regards.
You can try searching them here:
http://www.hydrogenaudio.org/forums/showth...=6860#post21966 (http://www.hydrogenaudio.org/forums/showthread.php?s=&postid=21966&t=6860#post21966)
I'm not feeling that courageous today.
"Same conditions" as opposed to letting the encoder do what it was designed to do, then making an evaluation, is a fallacy.
Use this link http://home.wanadoo.nl/~w.speek/ivan&menno.htm (http://home.wanadoo.nl/~w.speek/ivan&menno.htm). Download this program, run it, and select 128 or 128- production to encode. They are CBR settings.
Hummm... I would believe he wants REAL CBR. The -br switch in AACenc generates some kind of ABR that only Ivan can understand. :-/
It seems obvious to me that AAC was not designed with 'Real' CBR in mind. In that case forcing it to do 'Real' CBR would probably degrade the results a lot?
I'd rather say "Allowing ABR would increase the quality of results a lot"
No.. AAC can have "pure" CBR - FhG encoders generate file of, say, 128000 bps bitrate - exact in a bit!
But that requires heavy modifications in the codec, and - this way the quality could be a little bit higher
hi, ivan
how about your aac codec?
could you give some switches for pure cbr setting?
regards.
Just to clarify, in case anybody isn't reading this right--'this way' stands for doing ABR instead of CBR
I feel all weird 'clarifying' other people's posts for them, but I don't think I can go wrong here and I have this compelling, um, compulsion to clarify for some reason
