Topic: SoX batch that trims beginning and end of file? (Read 3597 times) previous topic - next topic
Could someone help me with this? I would like a simple drag-and-drop batch file that trims a few samples at the beginning and end of a wav-file.
Any suggestion what the command line should be? Can't seem to sort it out myself.
With SoX 14.4.0,
sox in.wav out.wav trim 10s -20s
does it (where 10 and 20 are the number of samples to be removed from the beginning and end, respectively).
There's an example drag and drop batch file in the standard SoX windows distribution, so you copy and modify it per chi's suggestion.
Perfect, thanks.
Ended up with this:
cd %~dp0
mkdir trimmed
FOR %%A IN (%*) DO sox %%A "trimmed/%%~nxA" trim Xs -Xs
pause
Works like a charm.
