Topic: Tags not showing up in Foobar2K. (Read 1825 times) previous topic - next topic
They show up in MusicBrainz.
They show up in MediaMonkey.
And they show up in Explorer.
But they won't show in Foobar2000.
Whysat???
Won't show up in fb2k where?
What's shown in the Properties, tab Properties, of one of the files? (You can select all the lines and paste them here.)
Originally there was nothing, but then I re-added it all to my library and it is showing.
*feels dumb*
But for future reference, what type of tags does Foobar use when editing the file properties tab?
EDIT: Does Foobar support M4A? Cus I think the files I saw in Explorer that weren't in Foobar may have been some weird form of M4A files. When I add folders, certain files don't show up. But when I add all the files in a folder, it will show M4A under the codec but a question mark under the bitrate.
mp3 ?... read here: http://www.foobar2000.org/FAQ#tagging_files
Yes, basically m4a = mp4, and mp4 is definitely supported. Do these files play? If not, are they possibly ALAC (apple lossless) format? If so, you need the ALAC decoder component.
I have the decoder but it will says "corrupted file or unsupported format."
DRM perhaps?
Did you get these M4As from iTunes? If so, most likely.
