Topic: Default UI - Spectrum visualization - 120 Band - View is truncated at bottom (Read 793 times) previous topic - next topic
Hello,
When i want to use the "120 Band" setting of the "Spectrum visualization" the bottom of the Window is truncated.
The view of all other bands are okay and not truncated.
You can see it at the attached picture, the "-60 dB" is only visible halfway through.
Hope you can fix it
Best wishes
My environment:
* foobar2000 v1.6.8 beta 3
* Windows 10 21H1
* DPI 125%
Re: Default UI - Spectrum visualization - 120 Band - View is truncated at bottom
The issue affects other bands depending on whether the window is wide enough to display bottom labels or not. Using normal DPI too.
I can just about fit all 160 and get the labels displayed when running full width on my 2560x1440 monitor.
