HydrogenAudio
CD-R and Audio Hardware => CD Hardware/Software => Topic started by: apastuszak on 2020-09-15 02:57:00
Title: Is there any reason to do a secure rip when AccurateRip exists
Post by: apastuszak on 2020-09-15 02:57:00
I'm using XLD on my Mac to rip CDs.  I ripping set to use XLD Secure Ripper.
But now I am wondering.  Is there any reason I can't just use burst mode.  If the rip after burst mode passes AccurateRip verification, doesn't that mean I have a good rip?
Title: Re: Is there any reason to do a secure rip when AccurateRip exists
Post by: itisljar on 2020-09-15 07:26:01
If the confidence is at least 3, then no, burst is enough.
Post by: Porcus on 2020-09-15 07:28:42
dBpoweramp, from the creator of AccurateRip, does burst first - and if then it is verified with AccurateRip, that is it. Sensible.
I can remember I once wanted it to do different, but I'm not sure if it were even an issue: I once re-ripped on a different computer (but same drive), and wanted to avoid verifying against "myself-only". Those were cases where my submission was the only one on record.
Oh, and there is a chance that burst & verify might let through some defective pressings where error detection would have come up with red flags - but if so: what is then a "correct rip"?
Post by: Elias on 2020-09-15 12:42:36
AccurateRip is as secure as it gets, so no, there's no need for secure rip, whatever software you're using.
Post by: apastuszak on 2020-09-15 14:15:38
Secure ripping REALLY puts a strain your drive.  I just killed a cheap external drive and I think secure ripping may be the issue.  So, if I can burst rip, that would help remove a lot of strain on the drive.
Post by: Elias on 2020-09-21 13:38:35
Yeah that too of course, so AccurateRip is obviously the preferred method. As long as it checks and verifies with the other rips available in the database, it's a correct reading, and you don't need to destroy your CD-ROM drive just to be sure it's a correct rip.
