HydrogenAudio
CD-R and Audio Hardware => CUETools => Topic started by: greyguy on 2019-05-30 21:13:27
Title: Template function 'if variable value equal to fixed string then do X'?
Post by: greyguy on 2019-05-30 21:13:27
Hello,
first of all I have recently started exploring the topic of audio ripping and am still getting familiar with CUETools.
Therefore, please forgive me if I write impossible nonsense here or (even worse) things that are already possible.
It's not like I didn't try. I've probably been sitting here for more than 2 hours and playing around with the template function and also learned several things with help of the wikis.
Well, I'd like to know if it might be possible to compare a fixed value with the result of a variable via the template function and execute an action depending on the result?
I imagine it like this:
$ifstringequal(%genre%,Soundtrack,' ('OST')')
or in total:
$ifstringequal(%artist%,Various Artists,VA - )[%year% - ]%album%$ifstringequal(%genre%,Soundtrack,' ('OST')') %CODEC%
Folder name: VA - 1994 - Pulp Fiction (OST) FLAC
Greetings
Martin
Title: Re: Template function 'if variable value equal to fixed string then do X'?
Post by: korth on 2019-06-02 15:27:37
No.
Also keep in mind that CUETools template syntax is "based on" foobar2000 title formatting syntax. This simply means the foobar2000 title formatting syntax was a source of inspiration. Do not assume functions and variables available in foobar2000 are available in CUETools.
Post by: greyguy on 2019-06-03 05:58:13
Ok, thanks for clarifying.
It would be great if the developers would consider adding such a feature then.
Maybe even in the form of support for a scripting language like LUA or JS. I think that would open up a lot of potential.
