HydrogenAudio
Lossy Audio Compression => AAC => Topic started by: Jedinhopy on 2017-08-05 19:36:06
Title: I can't use libav like this:
Post by: Jedinhopy on 2017-08-05 19:36:06
aac-libav-0.8.17-win32:
ffmpeg aac -i input.wav output.aac -quality 00001 cutoff 22050 bitrate 387kbps.
Title: Re: I can't use libav like this:
Post by: rizukitomi on 2017-08-09 18:12:58
Internal aac encoder in libav still experimental until now, unlike ffmpeg, so you have to add command " -strict -2 " or " -strict experimental " for it to work...
Post by: Jedinhopy on 2017-08-10 08:44:56
Did i get this? :
Libav (pre-3.0 FFmpeg) AAC encoder.
Post by: Jedinhopy on 2017-09-02 09:57:08
Anyone?
Post by: saratoga on 2017-09-02 18:19:17
http://wiki.hydrogenaud.io/index.php?title=AAC_encoders
Yes that is the libav encoder.
Post by: Jedinhopy on 2017-09-02 22:30:11
Now i only have to learn how to use it.
Post by: saratoga on 2017-09-02 22:42:42
The reason its marked as experimental is that it doesn't work very well.  You probably should not be using it.
