Topic: understanding DTS (Read 6449 times) previous topic - next topic
understanding DTS
I just installed a m-audio 2496. I also installed foobar.
Using SPDIF
I downloaded a 44100 test dts audio file.
When I play it in foobar I hear it well and the info at the bottom says dts 44100khz. But my yamaha receiver only shows it playing like a 2 channel.
If the sound is DTS encoded shouldn't it show it like multichannel?
When I play a movie with AC3 the amp does show it like multichannel.
Please explain
understanding DTS
You probably need to set foobar to make sure your receiver is being told to output 5.1
On my Onkyo receiver these are called "listening modes", and are set independently for each input.
elevatorladylevitateme
understanding DTS
If it could help others here is what I did
To enable dts 44110 audio passthrough
In M-audio control panel make sure in hardware spdif settings, mode is set to professional and data type to non-audio.
For WMP go to tools options devices speakers. properties and make sure to choose directsound delta ap spdif in sound playback.
check play wm audio professional content...
performance I checked 24bit
In Foobar make sure not to use the foo_dts.dll
understanding DTS
To expand on this: My understanding is foo_dts.dll is for *decoding* DTS in foobar prior to passing it on downstream; so if you want to output the undecoded , raw bitstream of a .dts file
to an external decoder (such as in a modern AV receiver), you don't use it.  You do have to use foo_spdif, though (or at least, I   do).
understanding DTS
Plus, unless the file says so, DTS tracks don't have to be 5.1 as far as I'm aware.
