Topic: v2 beta bug report(s) (Read 610 times) previous topic - next topic
- ReFacets:
1. Create a view (preferences)
2. Use that view (as part of Multiple colums)
3. Rename that view (preferences)
-> new name not synced with view table header
4. Rightclick view header
-> (old) view name not in contextmenu, so not deselectable.
-> New view name present in context menu, but not checked.
Re: v2 beta bug report(s)
- On update foobar deletes custom addons in program file's components folder
(Happened on update from b6 to b7. Forgot to test on update to b8)
The components folder is reserved for fb2k core components only.
You should have a user-components folder which has been the supported way since fb2k v1.1 10+ years ago.
https://wiki.hydrogenaud.io/index.php?title=Foobar2000:How_to_install_a_component
Thanks for your answer.
Some more info/details:
Pre v2 did not delete components in that folder, so this was very unexpected to see.
In my case, it's a multiuser system and saved other users from installing/updating commonly used plugins (decoders, dsp, visualization, lyrics,...) by not using the per user user-components folder(s)
I started testing with b6, btw.
Various ReFacets annoyances fixed in beta 9, thanks for reporting.
We are the bork. Your software bugs will be added to our own. Resistance is futile.
Good day everyone!
I'm noticing 2 things with beta 9 that might be bugs.
#1 %playback_time% doesn't show the current time marker for a playing song any more. Did support/syntax for this change?
#2 the default playlist doesn't scroll to the next song when seeking the next song to play.
Keep up the good work and thanks!
Beta 9 is recognized as a virus!!!
You've already proved you have no idea what you're talking about in this thread.
https://hydrogenaud.io/index.php/topic,123006.msg1016113.html#msg1016113
Case gave an explanation which you complete ignored and then you stated
Being a user with no programming skills/knowledge  I am worried
Worried? Fine, don't use it. Leave the rest of us adults alone.
