Topic: Problem controlling foobar2000 playback with python (Read 791 times) previous topic - next topic
I have been trying to play songs on foobar2000 using a python program. But when I run this code, it just adds the song to a foobar playlist. It doesn't play the song. I want it to start playing the song when I run the code.
This is my code :
import subprocess
foobar_location = 'D:\\Music\\Foobar\\foobar2000.exe'
song_location = 'D:\\Music\\Rock and Pop\\Linkin Park\\Linkin Park - A Thousand Suns\\16 Blackbirds (Bonus Track).wav'
subprocess.call([foobar_location, song_location])
When I run the code, this is what happens in foobar:
I am really new to this, and I don't know if I need any extra foobar components or plugins to do this.
Re: Problem controlling foobar2000 playback with python
fb2k has some additional command line options you can use to customize the action that should be taken when you start it:
You can see it by running foobar2000.exe /? or as reproduced below:
Available switches:
  /add <list-of-files> - appends the specified files to the current playlist instead of replacing the playlist content and playing them immediately
  /immediate - suppresses the delay when adding files
  /play, /pause, /playpause, /prev, /next, /rand, /stop - playback controls
  /exit - exits foobar2000
  /show, /hide - shows or hides the main foobar2000 window
  /config - opens the Preferences dialog
  /command:<menu command> - invokes the specified main menu command
  /playlist_command:<context menu command> - invokes the specified context menu command on current playlist selection
  /playing_command:<context menu command> - invokes the specified context menu command on currently played track
  /context_command:<context menu command> <files> - invokes the specified context menu command on the specified files
Stay sane, exile.
Available switches:
Thanks for that!!
I found an option in Shell integration that allowed me to play the song on startup
