Topic: Biography Discussion (Read 148288 times) previous topic - next topic
Re: Biography Discussion
Reply #825
^ You could try enable "Album name auto-clean" setting (in Options > Server Settings tab (blue) > Miscellaneous tab) - description of it is written at the bottom.
Reply #827
this definitely seemed like it would be the answer based on its description, thank you! unfortunately i couldn't get it to work even after resetting the cache and forcing updates.
as an experiment i made a new tag field called "album_clean" and manually created a tag for "Meddle" vs "Meddle (German)", went to server settings>title format and changed %BIO_ALBUM% to "$if2(%album_clean%, %album%)" which works as expected (but still doesn't clean the tag if it falls back to %album%). i'm wondering if perhaps the "utils.ReplaceIllegalChars" function is broken in v2 (32 bit)?
Reply #828
No such thing exists in Spider Monkey Panel. That's in JScript Panel only (v2.5 and above). And it's for replacing illegal characters in windows file/folder names - nothing to do with the subject at hand.
Reply #829
oh gosh thank you, somehow i hadn't noticed i was exploring around the jscript folder not the SMP folder, oops!  :-[
in any case though, given my limited (to say the least) understanding of javascript the SMP js files are even more cryptic to me. i am guessing that it must be something i'm doing wrong but i'm not sure what else to do besides manually creating a separate clean album title tag. the "clean album title" checkbox doesn't seem to have any effect even if the match % numbers are turned way down.
thanks again for the clarification Marc (and for all of your other work), if anyone has any suggestions i'm open to them! :)
edit: I managed to get it working by adding "replace(/\([^)]*\)/g, ' ')" to the albumClean function in names.js!
Reply #830
Could you make a x64 Jscript 3 version? I miss this beautiful biography on foobar2000 x64.
