HydrogenAudio
Hosted Forums => foobar2000 => Support - (fb2k) => Topic started by: NetRanger on 2022-09-22 16:16:15
Title: OptimFROG encoded files and foobar2000
Post by: NetRanger on 2022-09-22 16:16:15
Is there a way to get OptimFROG encoded files (*.ofr) to play in foobar2000 v2 x64?
Out of the box so is it not possible and i haven't found a component for it neither.
Title: Re: OptimFROG encoded files and foobar2000
Post by: The Link on 2022-09-22 16:19:52
Did you try the component from the homepage? http://losslessaudio.org/Downloads.php at the bottom
It's really old though, not sure if it works.
Post by: NetRanger on 2022-09-22 16:42:38
Should have said that it was for v2 x64..... that component doesn't work
Post by: Bogozo on 2022-09-22 16:59:52
You can use Command-Line Decoder Wrapper (https://www.foobar2000.org/components/view/foo_input_exe)
Post by: NetRanger on 2022-09-22 17:37:21
Looking at the FFmpeg Decoder Wrapper component now to see if i can get it to work.
Will have a look at Command-Line Decoder Wrapper if i can't get it to work with the above.
Post by: Bogozo on 2022-09-22 17:52:46
There is no OptimFrog decoder in ffmpeg.
Post by: NetRanger on 2022-09-22 17:59:24
Just noticed that. :(
Post by: Gus. on 2022-09-22 18:07:15
FFmpeg Decoder Wrapper was the first thing I tried, and even added .OFR to the config:
https://github.com/GyanD/codexffmpeg/releases
XMPlay with OptimFROG plugin will play a sample I found (luckynight.ofr):
https://www.un4seen.com/
AIMP x64 also plays it out of the box (aimp.ru)
Post by: marc2k3 on 2022-09-22 18:29:21
Looks like the source code is there so porting to 64bit could be possible?? I'm not even trying though. I'm certain input components are beyond me.
Post by: NetRanger on 2022-09-22 18:56:44
Just emailed Florin and asked him to update his official component to support v2 x64
Post by: marc2k3 on 2022-09-22 19:33:35
So I changed my mind and had a go. I have the sample file from here playing in 64bit fb2k...
http://samples.mplayerhq.hu/A-codecs/lossless/
I ran in to one sticking point. New input components are supposed to implement a remove_tags function but I have no idea what to do with it so it does nothing.
edit: a screenshot of my changes, I'm not uploading to github...
https://i.imgur.com/8iGdpwo.png
TEST WITH EXTREME CAUTION (64bit only)
Post by: Gus. on 2022-09-22 20:52:23
It plays luckynight.ofr, clean portable Foobar 2.0 x64 beta 9, even shows OptimFROG under playlist "Codec" header.
Post by: NetRanger on 2022-09-22 21:12:06
@marc2k3 - Thanks a lot for the updated component. It works fine. Have tested with  5+ OFR encoded files.
Post by: marc2k3 on 2022-09-22 21:22:44
I have an updated version.
This correctly displays OptimFROG Decoder under Preferences>Playback>Decoding. Previously, it just displayed OptimFROG
Remove tags has been implemented. It seems writing an empty file_info object does the job.
Post by: NetRanger on 2022-09-22 21:45:35
@mark2k3 -  Thanks for the updated version. :)
Post by: marc2k3 on 2022-09-22 23:25:04
ARGH. Another update, hopefully the last.
Includes x86 and x64 dlls with embedded art reading/writing. fb2k v2 only.
Post by: NetRanger on 2022-09-23 00:46:24
Keep 'em coming. ;)
Post by: marc2k3 on 2022-11-14 09:21:10
I've stuck the source on github.
https://github.com/marc2k3/foo_input_ofr
There are no downloads - the attachment 2 posts above is still the latest.
Post by: NetRanger on 2022-11-14 13:42:56
@mark2k3
Maybe you should make it available on your github foobar2k components page also
Post by: marc2k3 on 2022-11-16 01:14:35
It's hardly worth it. This component doesn't need a page to describe how to use it.
Anyway, I've posted an updated release here....
https://github.com/marc2k3/foo_input_ofr/releases
I just tidied up some dead code. No real changes.
Post by: NetRanger on 2022-11-16 10:22:52
@mark2k3
Thnx for making it available on your Github. A description is not needed as u say.
