Is there any commandline, program, or something otherwise that would allow me to store both mp3s created by LAME, and dumped lossless files too (not WAV) but rather FLAC or monkeys audio? that'd be great. thanks
Either MAREO (http://mareo.monkeydev.org/) or WACK (http://www.uninformative.com/wack/) will allow you to sequentially encode to two or more formats.
WACK (http://www.uninformative.com/wack/) will allow you to save to both image and track formats in the same run, and has the facility to scale MP3s using album gain information.
MAREO (http://mareo.monkeydev.org/) is specifically for creating track files in various formats (or image files, but not both).
Great, i'll give whack a spin. Only other question -- which lossless format should I choose (or which do you use)?
I'm stuck here and not sure if you can answer it. I've tried WAV, FLAC, and Monkey but i'm indecisive
I use Monkey's Audio - but I've been deliberating about changing to WavPack for a while.
The recent realisation (many thanks to Roberto and guruboolez) that Monkey's Audio error handling is lacking (http://www.hydrogenaudio.org/forums/index.php?showtopic=33226&view=findpost&p=316496) may force me to make a change sooner rather than later.
I would take a look at the comparison in the wiki (http://wiki.hydrogenaudio.org/index.php?title=Lossless_comparison) though.
Edit: added link to Roberto's post regarding his test for error handling.
And here's (http://www.hydrogenaudio.org/forums/index.php?showtopic=35158) yet another one.
Darn, MAREO and WHACK are impossible for me to configure from the tutorials they offer online. I wish they were more simplistic. I'll try the third one.
I want LAME -aps and FLAC geez
and tag it to:
C:\Lossless\Artist - Album - Year\Number - Artist - Song ...for FLAC
and C:\Documents and Settings\Evan\My Documents\My Music\Artist - Album - Year\Number - Artist - Song ...for -aps LAME id3 v2
but i'm having difficulty with the ini files and tutorials hmph
flac.exe and lame.exe are both in C:\Program Files\Exact Audio Copy
WACK is pretty easy to setup, i followed the guide on their website and ran my first extraction with it with no problems to Lame mp3 and MPC. And i dont even have the encoder .exe's in the EAC directory i have them all in a separate folders and organized by type and version #.
I agree, they are way too complicated. A user should be able to figure out a program by simply using it. If not, it's bad design and you have a problem. A well done GUI could solve all that configuration mess.
[a href="index.php?act=findpost&pid=317213"][{POST_SNAPBACK}][/a]
Absolutley. WACK would be kick ass with a nice GUI.
earphiler:
Try flackattack (http://www.hydrogenaudio.org/forums/index.php?showtopic=28922&hl) it's user friendlier than Wack, but you have to rip to FLAC + other lossy codec, I myself really like it.
Inytar
Half off topic, because converting to 2 different lossless formats at a time, but here goes.
Which app (React or Wack) will allow me to have EAC rip my CDs to both a La single-image with cue file and to tagged one-file-per-track FLAC files, and of course have them stored in their own appropriate directory structure, all in one movement? I suppose expecting it to do a little PAR2ing on the La disc images will be too much to ask?
If I understand correctly, neither Flacattack nor Mareo will do the trick. And wouldn't you know: the latter two are the only multi-codec apps I have experience with.
WACK will definately let you do that. I believe REACT will also (but I'm less familiar with REACT).
I'm not sure about running PAR2 - you may be able to run it under the REPLAYGAIN section, much as Jebus does with ID3 to tag the files in his WACK package on Rarewares.
I am not PC literate and only heard about MP3 a few months ago when my nehpew gifted me a MP3 player from Apple. With Synthtic Soul and Ponchorage's help I managed to make WACK work with EAC and create Extreme versions of MP3 using LAME 3.96.1 and .wv files using WavPack.
So far I have done this to about 400+ CDs and only about 5 CDs have not been successful. This was due to EAC detecting too many errors in secure mode.
Also I must caution you guys that sometimes the process fails in the middle and for this purpose you might have to run WACK in the dos mode.
